2006 milage getting worse - 45 to 35 - why?
Discussion in 'Gen 2 Prius Main Forum' started by rogersboyz, Sep 1, 2008.
  1. rogersboyz
    rogersboyz New Member
    Irvine, California
    My 2006 with 44K miles used to get 45 mpg. About six months ago, it dropped to 33~38, no matter how lightly I tread on the gas pedal. All service done by the dealer, and nothing tricky done to any of the powertrain systems. Any ideas? Is this a normal occurance due to battery age? Is there any test to see if I have a typical problem? HELP - gas is expensive! Thanks for any help. Jeff
  2. bac
    bac Active Member
    863
    52
    Pennsylvania
    This is not normal. Go to the dealer for a diagnosis, and please let the group know what you find.
    ... Brad
  3. bedrock8x
    bedrock8x Senior Member
    1,483
    137
    At 44K, did you replace the tires six months ago?
  4. removeum
    removeum Member
    407
    El Paso, TX
    :cool:Did you have the vehicle serviced recently? If so check the oil level and make sure it was not overfilled.
  5. hobba
    hobba New Member
    85
    Estero, FL
    Please see my experience with the same problem under the title, "After service Issues". I have unexpectedly lost 10 MPG and have been unable to recover.
  6. Bob64
    Bob64 Sapphire of the Blue Sky
    1,540
    92
    Virginia
    Check oil levels, make sure it is NOT above the full line.
    Check tire pressure.
    Check tire alignment - perhaps you hit something that caused your tires to be mis-aligned - check for uneven wear patterns.
    Drive normally. (You may be shooting yourself in the foot by driving "lightly" on the gas pedal - driving too lightly will set the gears so it sends more energy to the batteries - thus wasting energy)
