Rear brakes locking up in cold, rainy weather.
Discussion in 'Gen 2 Prius Main Forum' started by Rob Stone, Mar 7, 2008.
  1. Rob Stone
    Rob Stone Junior Member
    49
    Portsmouth Ohio
    I am new here. We have a 2004 Prius. We bought it used. The rear brakes are locking up just before you come to a complete stop. It only does this when it is rainy. It locks up so badly that the rear wheels bounce. I have had it to the dealer and they cleaned the rear brake mechanism. It helped for about 3 weeks then the problem came back. I have been searching the forum for threads to help me out. Can someone point me in the right direction to applicable threads. I am fed up with the dealer, and I am going to eyeball the brakes myself. I am noticing that the brakes are actually getting stuck. The car squats down in the rear as you attempt to pull away from a dead stop in the rain. Then the brakes let go. The car is perfect in dry weather.
  2. Steamboatsig
    Steamboatsig Member
    337
    Los Angeles
    2013 Prius Plug-in
    Do they salt your roads out there in Ohio?
  3. Rob Stone
    49
    Portsmouth Ohio
    Yep, we get salt and the liquid acid stuff on the roadways. I drive it two hours one way to work in Central Ohio. It gets exposed to lots of road grime.
    I put the Prius up on jack stands and pulled the wheels off to have a look at the brakes. The front pads were not bad. The front rotors were fine. No grooves or notches. No warpage. The slider shafts for the calipers were free. Front brakes looked fine, but I put on new pads anyway.
    I pulled off the rear brake drums and inspected the shoes and mechanisms. No discernible notches, scrapes, scratches, cracks, or anything on both sides that would indicate something grabbing or hooking onto anything. I did discover that the driver's side drum was dragging pretty good. I reinstalled the drum and placed two wheel lug bolts on it to hold it in place to do the spin test. It is not warped. It consistently drags like the shoes are adjusted way out, or like the wheel cylinder did not retract all of the way. I will be checking this out shortly. It looks like it got out of adjustment somehow. Wheel bearings are in good shape too. I have new rear shoes ordered from the dealer. I'll have them Monday, but I will play with the adjustment nuts first to see if I can get it to stop grabbing.
  4. Patrick Wong
    18,200
    6,500
    Hi Rob,
    Three thoughts:
    1. Might the driver-side rear brake shoes be binding against the backing plate? Each brake shoe contacts the backing plate at three points which are lubricated with high-temp grease. Perhaps those points have become rusty.
    2. The shoe return spring located below the brake wheel cylinder that pulls the driver's side brake shoes together may have become weak.
    3. What does the driver-side brake drum look like? Any discoloration or cracking inside or outside? Suggest you compare it to the passenger-side brake drum.
    4. According to the repair manual, the correct adjustment for the rear adjuster is 8 notches after the drum locks.
    Good luck,
    Patrick Wong
  5. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Whatever you do, do NOT attempt to bleed the brakes yourself. The Prius has a sophisticated electric assist braking system that could be rendered inoperable if you attempt to bleed them yourself. Please read the attached Adobe pdf's which have the correct procedure, and the brake diagram
  6. Patrick Wong
    18,200
    6,500
    I recognize that Prius has a highly complex brake system and that the THHT or the new service laptop is required to bleed air out of the system, allowing the various solenoids to be opened & closed in correct sequence, etc. However, I have successfully "flushed" new brake fluid through my 2001's brake system when it had ~60K miles without special tools.
    The key is to not allow any air to enter the system north of the brake wheel cylinders. If air enters, then your only recourse is to tow the Prius to your local friendly dealer for the official brake bleeding process.
    My procedure was to use a rubber squeeze bulb to suck out as much of the old fluid from the reservoir as possible. Then I filled the reservoir with new fluid. Starting with the rear and then moving to the front, I attached a vinyl hose to each wheel cylinder bleed valve in turn, with the other end leading to a small container. I had my wife turn the Prius to IG-ON, then depress the brake pedal a tiny amount, holding it steady. I cracked open the bleed valve and a strong flow of fluid resulted. Close bleed valve, release brake pedal, refill brake fluid reservoir, repeat, etc. I went through two small containers of Toyota DOT 3 brake fluid, and felt the above process resulted in replacing 80-90% of the old fluid.
    I'm planning a similar process with my 2004 when it gets to 60K miles (currently at 46K miles).
    Patrick Wong
  7. jayman
    13,439
    641
    Winnipeg Manitoba
    I would strongly caution you against doing that. It's your car, do what you feel is best, but there are key differences in the +2004 Prius braking system
    Toyota uses electric assist brakes in more of their new vehicles, but the majority of them only require the THHT or Panasonic ToughBook if you have air in the master cylinder. My FJ is one such Toyota with electric assist brakes that can still be flushed the "old fashioned way"
    Note that with my FJ, if the master cylinder should run dry, the THHT or Panasonic laptop is needed to command the solenoids
  8. absassoc
    absassoc Junior Member
    Umina Beach NSW Australia
    I received my Bentley workshop manual yesterday and was suprised to see that the US models have rear drum brakes. The one here in Oz have discs with a small concentric drum for the parking brake only.
    AB-S
  9. ydpplqbd
    ydpplqbd Active Member
    551
    253
    I know this is an old thread. But I am having same issue arising for the first time today. In my case, RR brake is locking up when I am almost stopped (best guess: at about 3 or 4 mph). And, yes it is occurring on a wet, drizzling 40F day. I am on the road now. I expect that I will tear down the brakes tomorrow and likely replace shoes and hardware.
    Any additional suggestions would be greatly appreciated.
    #9 ydpplqbd, Nov 24, 2019
  10. Mendel Leisk
    41,321
    I would often do a "light" maintenance, with rear drums, might be all you need. Basically remove the drum* and blow the dust out (don't breathe), then remove the "shoe hold down spring clips".
    At this point everything's still together, but the shoes are loose, and you can pull them away from the backing plate and carefully apply a little dab of grease at the 3 contact points (per shoe) indicated in the pic. Use something like a knitting needle, and be very careful to not get it on the shoe. I've used some high-temp bearing grease I've had for decades, using it up.
    * If the drum is stubborn, you can screw two m8x1.25 bolts by about 1" long minimum, fully threaded) into the threaded holes on the front of the drum, there for just that purpose. Just go back and forth, screwing them in. Might need to back them right out and blow the rust out once or twice. Eventually you should be able to pop the drum loose.
    Do remember to have the parking brake released, lol.
    Note too: it's a good idea to disconnect the 12 volt neg cable before starting, and when everything is reassembled, pump the brake pedal mulltiple times, firm it up, before reconnecting the cable.
    Full Repair Manual excerpt attached.
    dig4dirt and ydpplqbd like this.
  11. cthindi
    cthindi Member
    177
    85
    Connecticut
    This happens to me as well. Not that I attributed it to rear brakes. Brakes when wet in general tend to grab at low speeds and the car stops suddenly from 3-4 MPH to zero with a jolt.
    My take on it to attribute it to general brake behavior. My take is that on any car wet brakes would tend to grab. However if you are at a reasonable speed brakes get opportunity to dry out because of frictional heating. In case of Prius, most of that is regenerative braking in usual situations. Thus when brakes come into picture, those are still wet and thus grab. Just my theory.
    ydpplqbd and dig4dirt like this.
  12. ydpplqbd
    551
    253
    Today is a bright and sunny day with a high of about 55F today here in northern New Jersey. And, yesterday's brake issue has self-resolved about 95% (IOW, I had two jolts today upon brake application during the whole day when driving (again this condition was occurring on deceleration at about 4 to 5 mph).
    Just got done with the mobile mechanic. The mobile mechanic replaced the rear brake shoes (including lube at appropriate points), installation of new hardware kit and brake drum (one for right side that was locking up). Brake pedal is now high and tight (just as you would expect). Additionally, no more jolts when decelerating/braking at 4 to 5 mph.
    Parts were obtained from Advance Auto as follows:
    Wearever
    Brake Shoes - New - Rear
    Part No. S832
    Warranty: LIMITED LIFETIME REPLACEMENT
    Discount GL44BX -$8.75
    QTY= 1
    $34.99
    [​IMG]Advance Auto Parts - Store 5182[​IMG]
    Carquest Wearever
    Brake Drum - Rear
    Part No. YH140753
    Warranty: 2 YR REPLACEMENT IF DEFECTIVE
    Discount GL44BX -$10.99
    QTY= 1[​IMG]
    $43.99
    Wearever
    Drum Brake Hardware Combi-Kit
    Part No. 17262
    Warranty: 1 YR REPLACEMENT IF DEFECTIVE
    Discount GL44BX -$4.75
    QTY= 1
    $18.99
    Wearever
    DOT 3 Premium Synthetic Brake Fluid, 12 oz.
    Part No. W20013
    Warranty: 30 DAY REPLACEMENT IF DEFECTIVE
    Discount GL44BX -$1.00
    QTY= 1
    $3.99
    Product Subtotal: $101.96
    Discounts: -$25.49
    Shipping Charges: $0.00
    Shipping Discount: $0.00
    Core Charges: $0.00
    Tax: $2.53
    Order Total: $79.00*
    *- total price after 25% discount and sales tax (at 3 5/16% sales tax for Urban Enterprise Zone).
    Used Advance Discount Code ("GL44BX") in order to obtain 25% discount. I was required to spend $100 in order to obtain the 25% discount (reason that I purchased the brake fluid was to put me over the $100 minimum).
    #12 ydpplqbd, Nov 25, 2019
    Mendel Leisk and frodoz737 like this.
