Brand new Prius resets after power off (time, radio presets, avg mpg)
Discussion in 'Gen 2 Prius Main Forum' started by AnimalChin, Sep 2, 2008.
  1. AnimalChin
    AnimalChin New Member
    First off Hi! I just picked up my 2008 Prius a couple weeks ago and I am loving it. 55mpg average which is almost 3x what my old car got!
    Appologies if this has been discussed before. I searched around for a while and couldn't find any thread discussing the exact problem I am having.
    Now onto the problem:
    If I power on my Prius after it has been sitting overnight occasionally the entire car resets itself. The radio presets, the average MPG, the trip odometer, and my time is incorrect. It seems like this might indicate a battery issue. My Prius is almost brand new and has about 400 miles.
    I took it into the dealer this weekend since the problem has happened about five times now. They didn't seem to have any clue what was going on which was a little worrysome to me. They checked the starter gaurd and said that was functioning correctly. I now have to take it back to the dealer tomorrow and they'd like to keep it for at least a day to try to recreate the problem and figure out what is going on.
    Has anybody else experianced this problem? Anybody have any idea what is going on? The people at the dealership seem to be pretty stumpped with what might be causing this.
    Thanks for the help!!
  2. rigormortis
    rigormortis Active Member
    1,340
    26
    san jose, ca
    tell them to remove the starter guard and refund you your money for it
  3. AnimalChin
    Toyota Santa Monica does not sell the car without the starter guard installed. Do you think the starter guard is causing the problem?
  4. a priori
    a priori Canonus Curiosus
    3,083
    408
    Chicagoland (West)
    Welcome to PriusChat!
    I'm not an electrician, but it sounds rather plausible to me that the starter guard is the problem. There was another thread right on point just a couple of months back -- also involving Toyota Santa Monica. Follow this link for an interesting read about the product, its costs and benefits, and the various troubles encountered in its sale and/or use.
  5. 9G-man
    9G-man Senior Member
    1,273
    194
    Atlanta, GA
    YES YES YES. That is the problem. Demand it be removed and your money refunded. Call Toyota regional, tell them what that dealer is doing and that it's having an ill effect on the car. These freakin' dealers will baulk at inflating tires beyond "Toyota recommendations" , but install some crap like that, on a car that is very sensitive to it's electrical system status.
    Where is that "recommended" by Toyota.
    If they had told me they don't sell cars without it...I'd say that's right, not to me you don't, and walked.
    Tell them they messed up your car and you want it off, not replaced or anything else. It's criminal that they are ruining peoples brand new car experience.
  6. AnimalChin
    So the 600 dollar starter gaurd is not only a ripoff, it doesn't work and it messes things up. Good deal!!
    They make you sign a paper saying they are installing it before you pre-order but make it sound like it's standard. They won't pre-order it for you unless you sign that paper.
    I guess I'll call them tonight and argue that they broke my car before I even got it...
  7. Patrick Wong
    18,204
    6,505
    It is obvious that 12V power is being disrupted while the car is IG-OFF. The question is what is causing this disruption.
    The "starter guard" is a likely suspect. See post #22 of the following string: http://priuschat.com/forums/prius-m...ittle-switch-not-identified-3.html#post701923
    How frequently do you drive your car and how many miles do you drive daily? If you don't drive the car sufficiently, the 12V battery will discharge. Maybe this is causing the starter guard to disconnect 12V battery power.
  8. a priori
    3,083
    408
    Chicagoland (West)
    I don't know that I would go that far. If the installation was subpar, then they should fix things. Your car should work fine, and the start guard could provide you with benefits. The two questions are these: Is the benefit worth $600? and Can the dealer correctly install the item?
    It is a bit too late to bother with the answer to the first. You'll have some benefit from the start guard (properly installed). This brings us to the second question. This is where I'd push the dealer. They haven't broken the car, but they really are not helping things by using either a defective product or installing a product incorrectly.
  9. rigormortis
    1,340
    26
    san jose, ca
    theres no way that the benefit of starter guard is worth $600. i can think of a lot of things you can get for 600-900.00 that are more benefitial, like on the low end of 165.00 is the glass breakage senor, 600-700 would be a lojack, 900.00 would be the extended warranty deal. 750 or so for the 3m invisible film!!!!
    maybe thats an idea, maybe instead of demanding the dealer refund you your money you could try maybe getting a store credit and walk out with an alarm upgrade, lojacks, stuff like that. maybe they would be more inclinced to fix it if you asked for a store credit??
    i bet if more toyota of santa monica customers wrote letters asking for a refund for thier starter guard purchase, got turned down, and took them to small claims court, they probably would stop selling it
    how to sue a toyota dealer:
    step 1) first you need to write a letter (certified preferred) describing the problem and asking for a refund and if they do not comply tell them you are taking legal action
    step 2) research the owners and 'agent of service' of toyota of santa monica
    step 3) file out all the paper work at your local small claims court and pay the filing fee (30.00), put down the money you are seeking, do not put down court costs such as filing fees or process server fees you can ask for these if you win
    step 4) find a process server to serve your lawsuit. this will run 50.00, make sure you put down the correct 'agent of service'
    go to court, bring witnesses about how the starter guard is defective and causing the car to lose power, etc etc, make sure to show copies of all the documents to the person who responds (the employee of toyota santa monica) before seeing the judge. this is called "discovery'
    when you go to court, the court will have negioaters there, they might be able to negioate a deal with the plaintiff and defendent without having to see the judge.
    you can spike your damage assesstment up by adding on things like costs you had to pay out of pocket to get the device removed, or rental car expenses you had to pay while your car was in the shop
    another thing you can try when you talk to toyota corporate office is threaten to sell the car or allow the car to be repossessed over this
  10. Celtic Blue
    Celtic Blue New Member
    2,224
    139
    Midwest
    Wow! This is unreal. They've decided to soak their customers for about $500 net profit on a part that screws up the car. The greedy b@$+@#%$.
  11. SPEEDEAMON
    SPEEDEAMON Professional Car Nut
    1,556
    606
    Los Angeles
    Hey ANIMAL,
    We're in the same boat. You only paid $600. I had to pay $695. I hope you didn't fall for the BS package offered by the Russian finance manager at SM Toyota.
    I'm wondering if the Starter Guard will void the warranty like RonHowell suggests, especially if it is acting up and is a problem. In any case, our cars are warranted and I plan to fully exercise our rights if and when problems arise.
    Lets stay in touch if we ever have to take legal action.
  12. ekpolk
    ekpolk What could possibly...
    548
    176
    Pensacola & Vero Beach FL
    2018 Prius
    Two Eco
    Sounds like there might be a consumer fraud issue lurking in the background here. Anyone who's been force fed one of these things consulted a lawyer?
    What exactly does this device do that the manufactured in systems don't? Or in other words, what value does "Starter Guard" add to the car?
  13. 9G-man
    1,273
    194
    Atlanta, GA
    Gimme a break.....the thing is a total rip-off that these people should not have accepted in the first place. A $30.00 portable "jump start pack" from wal-mart would be a far greater benefit to the owner, and even someone else too,.or a $9.00 set of jumper cables are a better solution.
  14. rigormortis
    1,340
    26
    san jose, ca
    you don't need a lawyer, just take them to small claims court. you just have to be careful about time limits, like you have to write them a letter and wait 30 days, then from the time you write the letter you might only have a year or to file you claim
  15. AnimalChin
    I wish I went into Toyota Santa Monica a little more informed. I love the car though...
    I'm going to talk to them today.
    1) What is their profit on the Starter Gaurd?
    2) Does installing the Starter Gaurd void my warranty?
    3) When did they start installing the Starter Gaurds on all Prius?
    4) Have they had any complaints thus far regarding the starter gaurd or 12v battery issues?
    5) Wth MATE!?
    In defense of Toyota Santa Monica, they are pretty determined to figure out the problems I am having and are also giving me a rental car for how long it takes to do so.
    @SpeedDeamon, I probably did pay $695, haha. I'll let you know how everything plays out regarding the issues I'm having.
  16. SPEEDEAMON
    1,556
    606
    Los Angeles
    Animal,
    What ever happened with the Starter Guard issues and SM Toyota? I am now having the same problem with you. The car resets itself overnight.
  17. srivenkat
    srivenkat Active Member
    596
    93
    IL
    Did you and Animal end up getting the starter guard taken out or charged-up/replaced the 12V batteries?
