Alignment of Interior Parts
Discussion in 'Gen 2 Prius Main Forum' started by Tideland Prius, Mar 13, 2005.
  1. Tideland Prius
    16,597
    Ever noticed, the centre console box is left aligned with regards to the centre console (I think it's aligned with the gap between the display/radio and the metallic vent cover).
    Also, there's a slight bulge on the right side of the transmission tunnel in the rear hence the rear left rubber mat will fit snugly, but the right one will be curved up
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Slow weekend for ya Tideland? ;-)
  3. KTPhil
    KTPhil Active Member
    1,379
    22
    I noticed that the steering wheel is not aligned with the car. It is canted inboard relative to the centerline. You don't notice much since the dash board is "bulged" at the center, and the wheel kinda follows that line. In other words, if you looked straight down through the (non-existent) sunroof, you'd notice the steering wheel isn't parallel with the axle, but is turned in a bit. Bugs you once you notice it.
    Makes it hard for the dealer to align the steering wheel other than on the road (which explains why they screwed mine it up--they aligned it on the rack and never test-drove it).
  4. TCD
    TCD Junior Member
    97
    Northern, NV
    Howdy,
    Both of my front doors are rubbing against the side of the dash, leaving clear wear marks. The dealer says that it's normal...
  5. Tideland Prius
    16,597
    heh. I was sitting the back seat waiting for my parents, that's all. I remember people commenting on the Corolla's radio alignment WRT the centre console so I decided to check the Prius'
  6. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    TCD, I can't say that I've noticed rubbing or visible wear marks. I would tend to believe that it is NOT "normal". Just doesn't make good design sense to manufacture parts that rub together and cause wear on otherwise finished pieces. Try another dealer for a second opinion.
  7. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    I've got the door rubbing problem too. I've also noticed my upper glove box lid is starting to buldge relative to the center vent. Is anyone else's flush?
  8. Tideland Prius
    16,597
    I think mine is okay. But the left grey/silver on my steering wheel has a gap much larger than the one on the right
  9. Rick Grahn
    Rick Grahn New Member
    285
    Illinois
    I have the door/dash rubbing problem...some white rub marks. Only visible when the door is open.
    RG
  10. HTMLSpinnr
    5,341
    920
    251
    After almost 18 months, I've worn through the metalic coating on the vent panel down to the dark inner plastic.
  11. Widdletink
    Widdletink Member
    218
    Claremont, California
    2022 Prius Prime
    I have noticed the rub mark too (that's what happens when you wash your car practically daily, you notice little things :).
    If anyone gets any brainstorms on how to fix or prevent this, please share. My car is 38 days old and I don't want have anything damaged on her if I can help it. Hmm, maybe if I just leave the windows open and dive into her like Batman & Robin...
    Take care,
    Tisza
  12. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    rub marks for the doors.. well.. since the doors simply close and open.. get little rubber circle.. the little stickeys.. you coudl probably find them at a hardware store.. it will create a gap and protect both pieces.. mising paint.. or 1 or 2 little black rubber stockers. i believe they are usualy used as "feet" for items.. glass table tops and such. hardware stores... hmm.. office depot or something might have something... maybe...
