Photo of the 2011 Prius
Discussion in 'Gen 3 Prius Main Forum' started by Black2006, Sep 5, 2008.
  1. Black2006
    Black2006 Member
    198
    My apologies, if this has been posted before:)
  2. dogfriend
    7,512
    1,191
    Carmichael, CA
    Would have been even better if they had used the spell check to find that mileage was spelled wrong.
  3. TJandGENESIS
    TJandGENESIS Are We Having Fun Yet?
    5,299
    47
    ★Lewisville, part of the Metroplex, Dallas, in the
  4. JamesWyatt
    JamesWyatt Señior Member
    348
    Allen, TX
    $500 fine for font violations.
  5. thebanker4u
    thebanker4u Junior Member
    Dallas, TX
    Maybe they will make a small sail so you CAN get under overpasses and low flying wrens....
  6. Black2006
    Black2006 Member
    198
    Heh, but then most here seem to want more power and larger size....
    :target:
  7. lessmognh
    lessmognh Love my Prius!
    New Hampshire
    does it float too?:D
  8. wchardin
    wchardin Senior Member
    2,055
    Nashville, TN
    Do you have to hire a crew to take down the mast when you drive in a parking garage or underpass?
  9. ERIC PEPIN
    ERIC PEPIN LIGHT RAIL Q.A INSPECTOR
    Sacramento California
    What does Jesus has to do with a Prius???
    Zealous are everywhere.
    Quoting Bush?????? Bush has lots of blood on his hands having killed many Americans in the Iraq war intended to take a revenge for his father!!!!!
  10. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Note that that is the personal signature of that poster and not related to the post. Many people have things of importance or significance to them in their signatures...feel free to ignore those. I believe you can also turn off signature viewing in your USER CP
  11. dogfriend
    7,512
    1,191
    Carmichael, CA
    Too bad that you can't selectively turn off some members signature(s) and allow others. ;)
  12. nerfer
    nerfer A young senior member
    2,507
    237
    28
    Chicagoland, IL, USA, Earth
    I thought it was tongue-in-cheek - comparing something one of the founding fathers and a great president said, against what many say will be considered one of the worst presidents.
    The way that signature was set up, it was hard to tell where the signature started and the post ended. I rather fondly remember the old days when your signature had to be four lines or less of ASCII text. Here's mine from the mid-90's, just as example memorabilia for the whippersnappers on the board today:
    Code:
                                                   _-+--_
    <my name here>             -                  /__|__|\___
      <e-mail here>            -                 /--\|  |/--4\
      Chicago, IL USA Earth    -  o     8  o   L+|/\||__||/\||U
      ...juggling, genealogy   -     O            \/      \/
       & barefoot bog walking  - cruising the information superhighway in a '65 bug
  13. Black2006
    Black2006 Member
    198
    +10 for good reading comprehension abilities :cheer2:
    I did try to separate the signature better, by including the flying pig prayer animation.
    P.S. At least no one thought the 2011 photo was real....:D
