English/Metric
Discussion in 'Gen 2 Prius Main Forum' started by hdrygas, Mar 15, 2005.
  1. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    OK I am just fooling around in the car (again! so many buttons so many modes so little time) and I was wondering how fast I was going in KPH so I hit the switch and I was on the Energy Monitor Screen and it did not change to L/100Km. Is this normal what gives. Obviously this is a 'merikan car. Help understand the behavior. What happens in Europe, Canada, Australia, New Zealand when you do this. The spedo changes.
  2. exces6
    exces6 New Member
    97
    Houston, TX
    The button doesn't change the values on the computer, it only changes your speed. Also, your odometer stays in miles. I don't think the conversions are exact enough to convert like that.
  3. Canuck
    Canuck Member
    605
    Vancouver Island,BC,Canada
    The speedo is dual but the recording of distances and consumption is based on whether your vehicle is metric or US. Don't know if this can be adjusted otherwise or not.
    Darn ... beat me to it.
  4. exces6
    exces6 New Member
    97
    Houston, TX
    I bet it could be adjusted by a dealer or by loading a different version of the Prius software, but I don't think it's something you can just have changed for the fun of it.
  5. Frank Hudon
    Frank Hudon Senior Member
    4,147
    Henry does the temp readout change or just stays at F? on the CDN model nothing outher than the speed change Classic or new model.
  6. KMO
    KMO Senior Member
    1,966
    691
    Finland
    2023 Prius Prime
    The nav system units can be changed between miles/yards and kilometres/metres in its Setup screen. Doesn't affect the Trip Info screens though.
  7. Stocky
    Stocky New Member
    84
    Christchurch, New Zealand
    Our cars do NOT have the "km/miles" button that you guys have. We are 100% in the metric realm and everything is celsius, litres, kilometers, kilograms etc and couldn't easily change the car configuration even if we wanted to.
    It has been sooooo long since I used miles that I am afraid I have lost that intuitive feel. Even more so with temperatures - today was a cool to mild 21C (heading into winter now) which I understand perfectly, but if someone said it was 72F I would have great difficulty visualising it - just as the reverse would be true for you.
    Despite the fact that we changed to metric in the 1960s, many people here still measure people's height in feet eg 6 feet and babies are STILL 7lb 3oz when born - this is true of younger people who have only known the metric system - go figure.
  8. kenmac
    kenmac New Member
    149
    Perth, Western Australia
    The Oz model is strictly kilometres, L/100km.
    No switch - we can't actually drive to a "miles" country!
    kenmac
  9. Stocky
    Stocky New Member
    84
    Hi kenmac
    Interestingly - the Aus and NZ cars are actually identical models - I suppose they get loaded in Japan, toss a coin and head to whichever country comes up.
    So much so in fact that my i-Tech Prius came pre-loaded with the Australian navigation map, the NZ DVD has to be loaded. I come from Melbourne originally and could find my way to the old house I lived in - there was only the question of navigating the 2300km of Pacific Ocean - LOL.
  10. fjef
    fjef Junior Member
    94
    Ontario, Canada
    2001 Prius
    I
    Here in Japan it is strictly kilometers too - except the readout says I am currently averaging 22.1 kms/litre...
  11. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    I suppose with Canada being right next to the United States our cars require the km/mi button. It only changes the speed: the odometer, fuel economy, and outside temp stay metric.
    Canada also records newborn babies in "official" metric for records and traditional inches and lbs for everybody else. I think it just makes for more confusion.
  12. victor
    victor New Member
    414
    Gilching Bavaria Germany, & Drapanos, Crete, G
    Im in Germany with a German version. Metric only as well. Its a bit annoying as when I go home to the UK, I would like to be able to use MPH as well. I have an open question with Toyota about this.
  13. Canuck
    Canuck Member
    605
    I'm one of those more aged gents who still thinks in lbs,ft.in.,F* and mpg.
    I have to admit that the metric system is an intelligent step in the right direction.... calculating in metric is so much easier than the other. It was mentioned by fjef that in Japan the consumption readout is in km/l whereas in Canada it is in l/100km. I'm more comfortable with mpg.
    Being left handed I've managed to deal with such confusion. :lol:
  14. fjef
    fjef Junior Member
    94
    Ontario, Canada
    2001 Prius
    I
    Imperial or US? The confusion never ends...
  15. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    I tried the kmh/mph switch, too, hoping to get a quick readout of mpg. No such luck. Not that it couldn't be designed that way - I used to have a bicycle computer that would change from metric to imperial and back again, odometer and all, and it was way simpler than the Prius electronics. So, I had to pull out the calculator to make some comparisons, because most of the fuel consumption figures I read here are imperial. I recently pumped up the tires to 42/40, and went from an average of 5.6 litres per 100km to 4.1 km/100km, or about 50 mpg to 69 mpg if my fingers hit the right buttons. The 4.1 was only 60km driving like a granny, and the 5.6 was over a much longer time with different drivers and conditions, so I can't attribute that huge a change to tire pressures. But, I'm not about to put them back to 35 just yet.
  16. Frank Hudon
    4,147
  17. Canuck
    Canuck Member
    605
    Thanks for that link, Frank, I've filed it in my Favourites>Prius computer grab bag. . Now I won't need to haul out my Thomas J.Glover Pocket Ref. which I recently updated to version 2.
  18. Potential Buyer
    Potential Buyer New Member
    287
    <div class='quotetop'>QUOTE(Canuck\";p=\"73074)</div>
    I think L/100km is a bizarre measurement... km/L (analogous to mpg) makes much more sense. Plus it's more useful intuitively... I care about how far I go on a set amount of fuel; I don't care how my rate of fuel consumption.
  19. Stocky
    Stocky New Member
    84
    My previous car (of 7 years) was an Audi 100 and that measured in km/l (less is worse). The Prius measures in l/100km (less is better) so I have had to do a mind shift.
    It is somewhat difficult to adjust and I have resorted to an Excel spreadsheet with a table of values so I can quickly see how I am going while getting my mind back into l/100km mode.
  20. jayman
    13,439
    641
    Winnipeg Manitoba
    <div class='quotetop'>QUOTE(Potential Buyer\";p=\"73185)</div>
    Well, I had a hard time with the Metric system and still do. That said, I do believe L/100km enforces a very important point that "less is better," not "more is better."
    The More Is Better crowd is what gave us bigger cars, bigger homes, Super Sized meals, etc. It tends to enforce paradigms that you need More and Bigger.
    OTOH, Less Is Better tends to enforce paradigms that you should use less, eat less, consume less. I think L/100km fits will with conservation in general.
