Went from 53 mpg to 46 mpg in 7 weeks
Discussion in 'Gen 2 Prius Fuel Economy' started by hypnogirl, Sep 11, 2008.
  1. hypnogirl
    hypnogirl New Member
    wisconsin
    My mileage has dropped dramatically.
    Got my prius the end of July and was at 53 mpg for the first 3 weeks.
    That was in exteme humidity with the a/c blasting and me driving
    the way I have always driven.
    We are now in September. I am at 46.0 and dropping every week.
    Weather is milder. No a/c. I am also learning to drive. Can go the last
    2 miles home from work with no arrows at all everyday.
    I have an appt to take it in tomorrow.
    I have always thought the brakes sounded horrible. Is it because the car is so quiet?? They sound like my old car when I went way too long before having them repaired. They don't grind, but certainly have a rubbing sound.
    Any suggestions before I take it in??
  2. Celtic Blue
    Celtic Blue New Member
    2,224
    139
    Midwest
    Have you put any air in the tires since you got it? I went to 42/40 in late July and found the pressure had dropped ~3-4 psig on all four corners by last night. About half of this is because of lower temperatures, the other half is normal air loss.
  3. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    Could be the brakes hanging on you.
    Could be your alignment has gone wonky.
    Could be the ethanol in the gas (changed stations? check the pump for stickers).
    Tire pressure, as Shawn says, is also something to check.
    You aren't driving in B mode, are you?
  4. hypnogirl
    wisconsin
    Not driving in B.
    Had tires checked today. 32/33 I know they say higher on this msg board, but I can't imagine that the dealer had them higher when I picked it up. I also notice a rubbing sound when the tires are turned...and I am not turning too far.:confused:
  5. Celtic Blue
    2,224
    139
    Midwest
    That's fairly low on the Integrities. It sounds like they had you set at the door placard pressures or thereabouts. Mine started out a few pounds over from the dealer (one of the rear pressures was higher than the front.) I reset the pressures myself.
    46 mpg is still very good with such a low tire pressure.
  6. morpheusx
    morpheusx Professor Chaos
    1,555
    81
    Akron, OH
    As the outside temperature lowers so does your tire pressure. At 32/33 you are below the recommended pressure on the sticker in the door. If I were you I would pump up to about 38 all around and see how that goes. Also remember that tire pressure is only accurate if you check it on cold tires that haven't been driven on in at least 3 hours or more.
  7. donee
    donee New Member
    2,956
    198
    Chicagoland
    Hi hypno...,
    Your response to the comment seems to imply tire pressure does not change once set. Which is incorrect. Besides the temperature effects - about 1 PSI per 10 degree F change, there is leakage. Its best to get one of these portable battery pack / air pumps. Go out the car on Saturday or Sunday morning before the sun hits the tires, and check the tire pressure. 42/40 psi as was commented on works quite well.
    This is at least 50 % the cause of your mileage reduction, if not more.
    Additionally, warm humid air is less dense and creates less aerodynamc drag. If your doing allot of your driving above 45 mph, the weather variations in the past few weeks will certainly have a big impact. Its been down in the 40s up there in WI I imagine? As its been in the low 50s here in the past two weeks. If your driving in the morning during this cool weather, and fast , that would account for the rest of the mileage reduction.
    Driving in rain is a big impact in mileage too. Besides the stop-and-go traffic rain causes, the rain will cool the radiator, and the engine thermostat will open up further to keep the block at proper running temperature, which uses more gas. Rain also has more mass than air, so pushing it out of the way requires more gas. Water on the road sticks to the tires for a small distance at the tire rotates, and then falls off. This lifting of the water requires more gas. Tire treads push water aside to avoid hydroplaning. This pumping action requires more gas. Driving home in the Hurricane Gustav remnant had big impact on my mileage.
  8. markderail
    markderail I do 45 mins @ 3200 PSI
    2,260
    163
    Pierrefonds (Montreal) Quebec Canada
    Was happening to me all the time ! Even after break-in.
    CULPRIT - gas additives, like Ethanol, but not necessarily advertised as such.
    In Canada, was almost always getting gas from Petro Canada, and was always stuck at 5.4l / 100km or 5.6l / 100km.
    Now I'm always using pure Regular, like from Shell, and EXACT same conditions, I'm getting 4.2 to 4.6l / 100km.
    If I get a sunny week, I get 4.2...a rainy week will be 4.6.
    I don't drive much above 100kph (60 MPH).
  9. effwitt
    effwitt Paparazzi Magnet
    225
    Eagan, MN
    Are you maybe making more short trips? That's a MPG killer.
    More stop-and-go driving or hitting more red lights?
    You could also reset the MPG on the display and then go for a 20 mile relaxed drive at a sustained 55 MPH and check what the MPG is then.
  10. unigeezer
    unigeezer Member
    228
    63
    torrance, ca
    Something is drastically wrong! You should easily be averaging 60-80 mpg, no matter what the conditions; uphill, 6 people in the car, AC blasting at high continuously, and even with low tire pressure. I'd take it back and complain. Maybe you got a lemon.
  11. hypnogirl
    wisconsin
    Thanks to all of you who tried to help.
    To the other....have a great day...it's gonna be a long one.
  12. hobba
    hobba New Member
    85
    Estero, FL
    Please see my thread entitled, "After Service Issue". I have experienced the same problem since June.
  13. richard schumacher
    7,664
    1,046
    United States
    Most likely there's not enough air in the tires. Tire pressures should be checked and adjusted at least monthly; do it when the tires are cold.
    Using 42/40 makes it easier to get better MPGs, but the ride is harder. Try it and see what you think. If you do this it will also be necessary to check the pressures after the car is serviced at a dealer, 'cause dealer techs love to re-set them to the factory value.
