High Voltage Decay?
Discussion in 'Gen 2 Prius Main Forum' started by Santiago, Sep 17, 2008.
  1. Santiago
    Santiago New Member
    109
    New Mexico
    I've only had my 2009 Touring two days but I noticed that overnight the high voltage 5 bars drops to 2 bars overnight. Is this acceptable? Any thoughts on what could be causing this? Obviously the motor needs to run more than normal to bring the charge back up to where it was. BTW, I've never seen more than "blue" bars? Do you have to go on a long trip to get into the "green" bars?
  2. Patrick Wong
    18,210
    6,515
    Usually you will see green bars after a descent down a hill.
    I suggest that you keep an eye on the traction battery SOC gauge to see whether it continues to show a big drop overnight. The gauge should not behave in that manner.
  3. jelloslug
    jelloslug It buffed right out!
    813
    55
    Greenville, SC
    This may be a silly question but are you turning the car off when you park it?
  4. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    it almost sounds as if something is draining it... or you forgot to power down.
    if you're really curious, have toyota test it.
  5. Santiago
    Santiago New Member
    109
    New Mexico
    Absolutely turning the car off. And my wife hasn't driven it yet.;)
  6. qbee42
    3,081
    My thoughts too. More than one Prius owner has been fooled into leaving their Prius in Ready all night long.
    As for blue bars, the control system on the Prius tries to keep the battery at the blue setting, which is in the middle of the charge range. This allows room for additional charging when doing regenerative braking.
    All green is not a good thing. It's not bad either, but should only occur under special circumstances, such as regeneration from descending a long hill, or having the ICE run to keep the cabin warm.
  7. jelloslug
    813
    55
    Greenville, SC
    That is very odd than. My salvage car sat for over 2 months with the car off and it still had 6 bars when I powered it back up.
  8. Patrick Wong
    18,210
    6,515
    Since the OP has a brand-new car, maybe the traction battery ECU has to go through a learning process to calibrate its SOC readings.
    Or, maybe the 2009 behaves differently...
  9. qbee42
    3,081
    I think you are correct about the calibration.
  10. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    A couple of things to keep in mind.
    First, the gauge is not a "measurement instrument". It's an indicator. So take what you see with a grain or two of salt. ;)
    Second, the gauge does not "measure" battery voltage. It is operated by a computer, and it figures out what to display based on the charge it sees moving into and out of the battery. The battery is -fully- disconnected when the car is off. The other posters are not being suspicious of you or accusing you of incompetence. We have just seen lots of "newbies" leave the car on from time to time. Heck, I've done it once. Hey, only once! ;)
    Now, the computer uses lots of different things to calibrate itself, one of which is battery voltage. Battery voltage varies by temperature. Right there could be the explanation of the variance. The battery gets warm in use. It cools off overnight. The car will be doing the calibration routine often when new. As it learns, it "calms down". ;)
    Do be sure the battery vent is not blocked (right side of rear seat back). There is a fan in there, so don't panic if you hear it running from time to time. ;)
  11. miscrms
    miscrms Plug Envious Member
    2,079
    527
    Phoenix, AZ
    My guess is either a one time Battery ECU re-calibration or the car was accidentally left on (really easy to do). Its not unusual for it to change by one bar, if it happened to be right on the edge, but losing three is odd. Keep an eye on it, if it keeps happening it should be looked at.
    Rob
  12. kayak_hauler
    kayak_hauler New Member
    48
    San Diego
    When I 1st got my 08, it would drop 1-2 bars overnight. It has since stopped doing this....not sure how long it took. I expect this is a calibration issue as mentioned above....The compter has to 'learn' what a full battery is. Only having 2 bars in the morning seems a bit extreme though, if that keeps up > a week, you might want to have it checked.
  13. Neohybrid
    Neohybrid Not-so-junior member
    165
    34
    Central Virginia
    I have to go along with kayak_hauler -- my 08 behaved the same way for about a week. We had the car three days before we ever saw green bars even though we had what seemed to be a lot of regen.
  14. Santiago
    Santiago New Member
    109
    New Mexico
    Hey thanks... you guys have been quite helpful and reassuring.:p
