Fueled up for the first time tonight
Discussion in 'Gen 2 Prius Fuel Economy' started by cycledrum, Sep 18, 2008.
  1. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    Fueled up with Shell 87 at 363 miles on the ODO. At the first pump, had trouble with it shutting off several times after a smidgeon going into tank. I cursed the pump and moved to another. This time I tilted down on the nozzle (handle part towards ground) and gas went in. Lo and behold their is a diagram on pump showing tilt of handle toward ground and tip up in the filler pipe.
    The MFD showed 53+ mpg average at fillup, 38fr/36r PSI in tires. Been driving normally, sometimes in lots of traffic, up hills, twisty roads, freeway, city, bit of everything. No really short trips, always 20 min to an hour of driving. Amount of gas pumped in div. into miles, over 58 mpg, but not likely accurate.
    So far, I'm pretty blown away by the fuel economy. I keep comparing it to what my motorcycles, from 600cc to 1000cc got which is anywhere from 35 mpg to 45 at very best.
    So, I really like the, no, my Prius ;)
  2. Kcissem
    Kcissem New Member
    Maryland
    it will go up from your first tank especially if you start taking advantage of the different driving techniques, my first tank was 48mpg and now 5 tanks later that last two have been in the 60's with my lifetime average now up to near 56mpg.
  3. Freedom
    Freedom Active Member
    535
    69
    Northeastern MA
    I've almost finished my 2d tank of gas. Oh how I remember that first fill up! It was over 2 weeks ago, but I remember the feeling as if it were yesterday. (with my old car, it WOULD have been yesterday!)
    Enjoy! I sure am.
  4. Kcissem
    Kcissem New Member
    Maryland
    I've had the car for 2 months and am now on my 6th tanks, but i have yet to spend the ammount of money or filled up the ammount of times i had fill up in my last car in just one money, in two months i've spend 192dollars on gas, still have a hundred to go before i match what i spent in a month before. (Had a sports car that only got 18mpg)
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,804
    Clearwater, Florida
    Its not the pump.
    Your moving to another pump allowed the tank to vent a little.
    After a year of ownership I have found the best thing to do is to let the fuel tank vent a little before fueling. I have had only one gas belching episode and have since let it vent a little and its been fine. When you arrive at the gas station open the gas fill...do not insert pump. Go inside and get a drink or whatever. By the the time you come back it will be ready to fuel. Works every time now. Fill on slowest fuel setting and hang up the pump on the first click off. Do not attempt top off. Always fill up when your down to 2 pips.Good Luck!
  6. morpheusx
    morpheusx Professor Chaos
    1,555
    81
    Akron, OH
    He's right, there have been a few times where mine has been in the sun all day, and I needed to fuel up in a hurry and from empty only been able to get 6 gallons or less in. On my previous cars those would have been the days that when you unscrew the gas cap that you would hear the gushing of vapors escaping.
  7. Celtic Blue
    Celtic Blue New Member
    2,224
    139
    Midwest
    What you are doing is evaporative cooling of the tank, so that the undersized vent system can better handle the incoming fuel and resultant flashing. Makes sense on a hot day, and is completely counter to what the design is supposed to accomplish (reducing fugitive emissions.)
    EDIT: An interesting aspect of this problem is that in some hot conditions it could start out almost independent of fuelling rate. If the tank and fill line are hot and trying to off gas, then adding a small amount of fuel is still a problem because it will still have about the same vaporization rate to start out. This is likely to produce enough back pressure and perhaps enough splashing toward the nozzle to seal the venturi inlet, shutting off the nozzle. So if one waited to fuel, allowing the system to vent/off gas and thereby cool, the resultant flashing vapor velocity might not exceed the system limit.
    Hmm...this brings me to another consideration...some of the vapor return nozzle designs for Stage II vapor recovery areas might work better as they have built in ability to handle vapor counterflow. I've seen pics of some that have more holes and could perform better if my hunch is correct. The devil could be in the details of the nozzle design. That might help explain why some are so insistent that this is all "operator error"--if they are in areas that have a different nozzle design.
    The number of possible scenarios for this system to fail is staggering.
  8. edthefox5
    10,096
    4,804
    Clearwater, Florida
    Thank you yes sir your right too with your observation of the air gushing
    on older cars. You'll never see that on the Prius as the fumes are trapped
    and re-cycled I would imagine and that other poster is correct too in my venting of the tank I am doing what Toy's Engineers exactly do not want me to do and thats venting fumes in the atmosphere. But I beleive if I don't I won't be able to successfully fill the tank without fuel pouring out which is probably worse atmosphere wise. I think Toy's Fume recovery system in the tank is to tight. Probably to meet there 0 Emissions mission.
    Or maybe with the fairly recent installation of E10 everywhere maybe thats creating a fume problem the car was not designed to handle. Just reaching here.
  9. N3FOL
    N3FOL Member
    891
    Stewartstown, PA.
    +1. My Prius does better than my 900. Even with the cold air in our area now, I am still getting a little over 51 mpg.
  10. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    Thanks for the info! Can fill on the slowest setting and still get out of the gas station before some other behemoths around.
  11. gungadin
    gungadin New Member
    Dayton, OH
    Just got back from a trip to Chicago from Dayton, OH, 310 miles each way. Waited until we were on the last pip and refueled at 480 miles on the trip odo. Amazing fuel economy! The mileage across the entire trip was 49.5 mpg. Speeds were highway up to 72mph, tires were the OEM Bridgestone Turanza's set at 45f/43r psi (cold inflation pressure listed as 51psi on sidewall). Today we leave for Fayetteville, NC, about 540 miles each way. We now have about 1100 miles on the ODO. Love this car!
  12. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    Filled up for 2nd time tonight, Shell 87. Waited a minute with fuel cap off, put nozzle in a bit, pumped on slowest setting, clicked off, thought about trying to pump more in, but decided no way, do not top off.
    So, 6.582 gallons after 364 miles mixed driving, few short trips, for -
    55.3 mpg
    ~ 38psi fr/ 36psi rear
