2004 Prius - Was VSC Offered? Problem on Ice?
Discussion in 'Gen 2 Prius Main Forum' started by pekoe1111, Sep 23, 2008.
  1. pekoe1111
    pekoe1111 New Member
    I live in VT and recently bought a 2004 Prius, with what looks like all options (side airbags, Bluetooth, Nav., etc.)
    I have heard that either traction control or vehicle stability control causes the power to be cut when you are on ice or slippery snow - making drivers extremely unhappy.
    Do 2004s have TC and VSC?
    Thanks,
    BB
  2. Presto
    Presto Has his homepage set to PC
    1,326
    24
    Vancouver, BC
    TC is what people complain about, but it is most often confused with VSC. Proper winter tires are the way to go. TC is a standard 'feature' in all 2nd Gen Prius.
  3. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    The sensitivity of the TC was changed apparently in the '06 or '07 MY and it isn't as aggressive as it is on my '04.
  4. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    The 2004 in Canada came with TC as standard, and VSC as an option. This may not be helpful to someone in Vermont, but at least you know it's possible to have one without the other.
  5. pekoe1111
    So the goal is to not spin the tires, which activates the TC?
    Efusco - Your sig. has all-time miles. How do I find that in my trip computer?
    BB
  6. efusco
    19,891
    1,196
    Nixa, MO
    Yes,
    You don't, you have to track manually.
  7. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    Well actually, all-time miles is on the odometer. Just press the "Odo/trip" button until you see the odometer readout. All-time MPG is not kept by the cars' electronics. ;)
    You can minimize your TC problems with good winter tires. I put on Nokian WR tires so I wouldn't have to change wheels twice a year. They work very well.
    I understood the TC was "desensitized" in mid 2005. It apparently can't be "reprogrammed". If you want it changed they have to change the module.
  8. kenmce
    kenmce High Voltage Member
    1,544
    515
    NY
    Mine does. It beeps at me when it thinks I'm skidding.
  9. Tideland Prius
    16,555
    Do check the KB for the list of Prius options if you want to find out what you have.
