FYI Michelin Primacy MXV4 Tires
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by dorf, Sep 23, 2008.
  1. dorf
    dorf Member
    132
    Little Rock
    I just purchased 4 Primacy MXV4 tires (85/65R15)to replace the OEM's Integrity's.
    Yes, they do ride smoother and Yes they are definately more quiet and seem more stable.
    I wanted Harmony's but local dealers were unable to provide them although Michelin said that they are available.
    Hope this helps somone make a decision. Seems like a reasonable choice plus the $60.00 back from Michelin. Call them and they will send you a coupon. You have to buy before Oct 31, 2008.
  2. kn6vv
    kn6vv Junior Member
    75
    Loveland, CO
    Thanks for your report. I'm curious why you wanted the Harmony tire vs the MXV4? Is there much difference?
    I too am looking at replacements for my OEMs on my 2006 and have looked at the MXV4 at our local Sams Club. They show the sale only until Sept 30, not Oct 31. Are you sure on the sale dates? Thanks!
  3. ctbering
    ctbering Rambling Man
    1,650
    124
    Chicago Illinois
    If you don't mind sharing, what was the total cost of your tires?
  4. dorf
    dorf Member
    132
    Little Rock
    Don't know about the Sam's sale date but the Michelin coupon ends Oct 31, 2008 for sure. Call 'em.
    At the time Harmony prices were cheaper that the MXV4's, now about the same??? don't know why.
    Manufacture date on my tires is Aug 2008 or so ???(2908) last four numbers in tire code...29th week of '08
    $460.60 Out the door, Installed and balanced.
  5. priuslovers
    priuslovers Way Out Member
    65
    Hercules, California
    I could not stand the oem tires and did some research for replacements. According to Continental their new conti pro contact was supposed to have low rolling resistance and good traction. The MPG's went way down so I increased the air pressure, the ride was very rough - very disappointed (also lost a great deal of mpgs). I saw that costco had a sale on michelins and decided to check it out. I ended up purchasing costco's only michelins for sale (it appears that the name of the tire changes depending on where you purchase them). They gave me a sixy dollar coupon used in the store (which made the price of the tires $99 dollars each). After playing with tire pressure (now 42/40) the ride is excellent and the gas mileage is always 53 to 55 mpg (25 percent city and 75 highway - approx 70 miles per hour). I would Definitley recommend these michelins.
  6. voscott
    voscott Junior Member
    San Francisco
    Which michelin tire did you purchase at Costco for your prius? I have a 2007 prius so I wonder if it's the same tire for mine?
    The last time I checked with Costco they said they didn't carry the tire for my Prius so I had to go to an independent and it wasn't cheap, like $160 for one tire.
  7. vintagebob
    vintagebob Junior Member
    98
    San Jose CA
    The Primacy is very quiet and provides a great ride BUT they are also much heavier than the stock tire, something like 25 lbs vs OEM 17 lbs. Very noticable during initial acceleration with about a 5mpg hit on fuel economy. I have them and like them but I wanted folks to understand that they come with a MPG hit.
    I've tried: OEM, GY TripleTread, Falken and now Mich Primacy. (115K miles)
    YMMV
  8. malibucarl
    malibucarl Member
    237
    Malibu, Ca
    Did you like the triple tread from GY ?
    Thanx,
    Carl
  9. vintagebob
    98
    San Jose CA
    In the beginning I did. Great traction and handling when compared to the OEM tires. They were also very heavy though and provided a stiff ride quality that I didn't like. After they started to wear they also became very noisy. Too noisy in fact for me, especially with the MPG hit I was taking. The Primacy tire rides better and is very quiet with the weight really being the only downside (along with the cost).
    Be aware that the Primacy and the TT I used were a 195/60 size.
  10. cwy
    cwy Junior Member
    Tustin, CA
    It's been 2 weeks since Costco installed the Primacy tires to replace my worn out GY Integrities ($123/tire came out to total ~$450 due to $80 discount). Based on the positive reviews found here, I had them install 195/60/50. Being brand new, they instantly felt great in terms of noise & comfort compared to the shot OEM's w/36K miles.
    What I expected happened immediately (and still happening)... the dreaded MPG hit. Fortunately, it's been a very minor hit of only 2-3 mpg (~5%). So instead of 49-50mpg, I'm averaging 46-47 over the last 2 tanks. I'm hoping it'll climb up another tick or two as they wear down little by little.
    In terms of handling/stability compared to the Integrities based on seat of my pants data filtering/analysis, Yes, it's an improvement. I don't hear squealing/skidding on turns and it "wanders" a little less on SoCal freeways. The real test will not be known until many thousands of miles later to see how well the Primacy's hold up as they enter their middle age & golden years. So long as they last close to (perhaps beyond?) their 60K warranty and they provide better/safer feel than the OEM's, I'll be more than satisfied.
  11. jdenenberg
    jdenenberg EE Professor
    3,953
    1,950
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Your 5% MPG hit is not completely real. I can account for half of it with the change in revolutions per mile. First, the Primacy is rated at 851 revs/mile compared to the Integrity at 855. This changes your speedo/odo calibration by 0.5% which lowers your Apparent MPG by a like amount. Second, when a tire wears the revs/mile goes up due to a reduction in the tread thickness (this also slightly reduces rolling resistance) by about 0.25 inches at end of life. This reduction in circumference of 2% causes another false change in MPG by the same factor.
    Another factor is that the temperature is now dropping which also reduces MPG so wait till you have a full year of data before trying to compare your new tires to the ones you took off.
    When I replaced my Integrity tires with Michelin MXV4+, a detailed analysis showed a 0.5 MPG improvement (mostly due to better MPG in the winter). When I replaced them with my Nokian WR tires another MPG improvement occurred (about 1 MPG, but I have to wait one more month for a full year of data).
    See the attached spreadsheet for details.
    JeffD
  12. priuslovers
    65
    This response is to answer VOSCOTT's question about the michelin tires.
    The costco close to my house only offered the michelin x radial. It comes with an 80,000 mile warranty and a 60 dollar coupon to costco - it made the tires cost $99 each. Inflating the tires to 42/40 increased my mileage over the goodyears and had an enormous improvement in ride and handling(current mpg 53 -55 , includes some fairly large hills to climb to and from work).
  13. HOV
    HOV New Member
    CA
    I just replaced my Prius original tires with Michelin X's from Costco and my mileage has dropped by 4 MPG! My PSI is 42. Any thoughts?
  14. sandman
    sandman Member
    277
    32
    kentucky
    What tire did you replace with the Michelin X's and how many miles where on them? Any new tire will have more rolling resistance than a used tire thus lower MPG's, it will take at least 500 miles to break a new tire in.. I would look on the sidewall of the tire and see what max PSI is for that particular tire and bump it up to that..Other than that give them some time and please keep us posted on the MPG's..
  15. ualdriver
    ualdriver Member
    358
    65
    Midwest US
    When you guys are replacing your tires, are you going into the menu on the MFD that has a button you select when you put new tires on your car? I thought (or perhaps I'm confusing this with another car) that in the instruction manual it said that if you put new tires on your car, you're supposed to make a section in your MFD. I wonder if that has an effect on the accuracy of the MFD mileage displayed?
  16. ualdriver
    ualdriver Member
    358
    65
    Midwest US
    duplicate deleted
  17. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    not aware of any adjustments on MFD that can be made when changing tires
  18. HOV
    HOV New Member
    CA
    Thanks for your response. I'm really at a loss here. The originals I replaced were Goodyear Integrety's. I had over 37000 on them and they were very bare. I was getting 47-48.5 MPG with them. The MPH has decreased even more with the Michelin X's to around 40 MPG. The sidewall is 44. I've had them at 42. I haven't changed my driving at all. Is there something else that could be wrong? This happened immediately after I replaced the tires. I have run 3 tanks of gas and the performance is decreasing. Costco nitrogen and I had them reconfirm the PSI.
    Thanks
  19. Bob64
    Bob64 Sapphire of the Blue Sky
    1,540
    93
    Virginia
    Colder temps...
    alignment + balancing?
    tire breakin period not passed.
  20. dorf
    dorf Member
    132
    Little Rock
    From my experience on a '07, the fill up gallons sometimes do not equate to the MPG reading.
    I have been advised to hit Reset on the Consumption screen for the system to start all over computing MPG...it takes awhile for the numbers to increase.
    But cold weather effects all.........
    I've got Primacy MXV4 and have not really seen a MPG hit.
    My best was 49.9 MPG
    I don't think the MFD is an exact thing.
