Prius airplane sounds "road noise"
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by acarter001, Sep 27, 2008.
  1. acarter001
    acarter001 New Member
    new orleans
    I have a 07 Prius that has been very good until recently. I noticed road noises coming from the front passenger side that are increasingly getting louder. It sounds almost like a plane taking off as I accelerate. I thought it may be the tires, but when I had them changed out the noise continued. Has anyone had this problem or know what the issue may be?
    Thank you in advance for your help
  2. dogfriend
    7,512
    1,191
    Carmichael, CA
    Assuming you are still under warranty, I would let the dealer look for the problem. I haven't had any issue like this on my 07 w/ 23k miles.
  3. morpheusx
    morpheusx Professor Chaos
    1,555
    81
    Akron, OH
    perhaps some debris is caught in in between the rotor and the brake pads.
  4. statultra
    statultra uber-Senior Member
    798
    31
    Edison,NJ
    2001 Prius
    I have this exact problem! it sounds like a drone from a jet engine as the car gains speed, I could never pinpoint the problem.
  5. Patrick Wong
    18,210
    6,515
    Since your car had been in an accident, is it possible that an axleshaft is slightly bent or otherwise damaged?
  6. acarter001
    new orleans
    Debris around the brake pad and rotor was my first thought. The only accident I was in with the car was that a truck backed into me and just dented the bumper, but I will have to look at the axle shaft as well. I will be bringing it to the dealer tomorrow to check it out but any other suggestions will still help. Thank you all for your help so far.
  7. morpheusx
    1,555
    81
    Akron, OH
    please keep us posted after you get back from the dealership
  8. acarter001
    new orleans
    The dealership says it is the wheel bearing, as I am luckily still under warranty it should be taken care of. I get the car back tomorrow and will keep you posted.
  9. 97ss150
    97ss150 New Member
    ft worth
    2003 Prius
    mine does the same thing around 50ish and then again about 70ish. i do not know what it is. its loud like the tranny needs to upshift, but obvsly. that isnt the problem. so now i think ill look into making sure the transaxle oil is up to specs
