Brake replacement question
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by kkister1492, Mar 18, 2005.
  1. kkister1492
    kkister1492 New Member
    355
    Fremont, CA
    While discussing hybrids and other fuel efficient automobiles, one person reported that he had read in an auto advice column that you can not replace the Prius' brakes at home and replacing brake rotors would cost $15,000.
    Is any of this true?
  2. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    That *has* to be a joke. Right?
    For kicks I called my local dealer and they quoted: 2 front rotors, caliper rebuild kit, new pads, around $400.
    If somebody told me that my Prius would cost $15 g's for a brake job, I'd give them a comment that rhymes with "duck shoe."
  3. kkister1492
    355
    Fremont, CA
    I told him that couldn't be right but he swore by it - suppose to have something to do with the regenerative braking system being connected to the rotor and so it is a big deal to replace them.
    I was sure that I'd read somewhere on the forum that some of you have replace your own brake pads/shoes. He was pretty adamant about it all, though. Said it was someone like 'Click 'n Clack'.
    Said I'd check with the 'real' experts on the Prius.
  4. jayman
    13,439
    641
    Winnipeg Manitoba
    Well, I think it's just ironic that a person who in all probability has never looked under the hood of a Prius is telling you how incredibly much the front rotors cost.
    Maybe the rotors from a Boeing 777 or an Airbus A340?? That I could see, you're talking about what, a $100 million airplane?
    I would still use the classic comeback that rhymes with "duck shoe" and leave it at that. This guy is a boob.
    Look, if it means proving the point, and this guy isn't a homicidal stalker or something equally dangerous, drive him to your local Toyota dealer. Drag him to the parts/service counter and ask them how much parts/labor for the front rotors.
    If he still believes "Slick and Slack" or whatever the h*** their names are, then this guy is a boob. Maybe hook him up to the special HV battery charger the dealer has.
  5. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    The regenerative braking system is part of the hybrid system and thus under warranty for 8yr/100k miles. But, as mentioned, the brakes themselves are standard...disks and drums....
    I'd tell him that BECAUSE of the regen. braking the time b/w needing new brakes is dramatically extended b/c the friction brakes get very little use thanks to the kinetic energy being recaptured by the MGs.
    Your friend probably misunderstood something in the article. But, as seen in the 2 warped articles posted here earlier today, there is a lot of fear, ignorance, and prejudice printed by so-called 'journalists', so it may have said something like that.
  6. kidtwist
    kidtwist New Member
    183
    <div class='quotetop'>QUOTE(jayman\";p=\"73740)</div>
    Click and Clack (the car talk guys on NPR) are great. They've generally been hybrid supporters (the Prius gets their "awesome" rating). They've also been very critical of Detroit's tendency to build ever bigger and more powerful SUVs.
    Here's their web page for anyone interested: Car Talk Web Page
  7. rick57
    rick57 Member
    572
    Circleville, Ohio
    I'll do that $15,000 brake job! Pick me! Me,me! :lol:
    BTW, I have only done a brake job on 1 Prius, an 03 and it still had plenty of pad (was a front brake job) left. The reason for the work was that the pad material had come loose from the metal backing plate. It had about 77k on them.
  8. prius mdt
    prius mdt New Member
    25
    Richmond VA
    Dang Rick, I was scrolling down to get my bid in on the job - you beat me to it!
    I'll do it for $14,500.00 - that's my final offer. Oh yeah - and I can have it done by lunch time !!!
  9. tochatihu
    tochatihu Senior Member
    9,851
    3,813
    Kunming Yunnan China
    2001 Prius
    I remember reading on one of these boards that the NHW20 brakes required a THHT to bleed the hydraulic system. If this is accurate it might have started the story. Do our assembled experts agree that it's needed?
  10. jayman
    13,439
    641
    Winnipeg Manitoba
    <div class='quotetop'>QUOTE(kidtwist\";p=\"73748)</div>
    Mark:
    Then it sounds like this guy that kkister1492 knows is either making things up, is completely full of s***, or has forgotten to take his meds.
    His opinions are his own business - that's what the Bill of Rights is for - but when he goes around spreading bulls*** like that, he's a boob.
    We're all entitled to opinions, but my Dad warned me a long time ago about opinions and their similarity to sphincter's
  11. jayman
    13,439
    641
    Winnipeg Manitoba
    <div class='quotetop'>QUOTE(rick57\";p=\"73789)</div>
    Rick:
    Careful son, or I'll hide all your back pain meds! :cry:
    Seriously though, I bet this "horror story" becomes an Urban Legend and you'll have prospective owners wringing their hands asking how much the brake job *really* costs.
  12. jayman
    13,439
    641
    Winnipeg Manitoba
    <div class='quotetop'>QUOTE(tochatihu\";p=\"73829)</div>
    There is a thread on the Toyota Prius braking system with many nice jpg's of the system.
    I asked my Prius tech about that, as I've always changed my own brake fluid yearly: I siphon the fluid out of the reservoir, add fresh DOT3, then have a helper stomp the brake pedal while I crawl under and open the bleed screws. I like doing things like that.
    My Prius tech claims that as long as I don't introduce air into the system when I siphon out the reservoir and add fresh DOT3, there is no reason I can't do it myself. That said, the THHT is used to cycle the pumps and "properly" flush everything out.
    My local Prius tech also claims they will happily do my yearly brake fluid change, flush, and bleed for $80. As my back has recently started acting up again, I think I'll take them up on the offer. At least they stand behind their work if anything should happen to FUBAR.
    Oh, FWIW, my 2000 GMC Sierra needed the OTC Tech2 to cycle the ABS pumps if air was ever introduced into the system. I would think every new car and truck with ABS needs the handheld tester to cycle the ABS pumps if air is suspected.
    I used to have a 1992 Honda Prelude SR with ABS. You needed a special tool from Honda just to reach the bleed screw on the ABS accumulator, and you needed their special dedicated ABS tester to cycle all the pumps. Not a job for the corner service station, that's for sure.
    I suspect the Prius with all its technology may be very intimidating to the masses. It's not like this technology ever gets in your face, it all works behind the scenes.
  13. rick57
    rick57 Member
    572
    Circleville, Ohio
    <div class='quotetop'>QUOTE(jayman\";p=\"73839)</div>
    Rick:
    Seriously though, I bet this "horror story" becomes an Urban Legend and you'll have prospective owners wringing their hands asking how much the brake job *really* costs.[/b][/quote]
    No No not the meds! :cry: Actually I am doing better, :wink:
    As for the bleeding,I have not had opportunity to do that yet on a Prius. So,I looked it up. On the 1st gen, a combination of pedal activation and Scan tool accomplishes it. On the 2nd gen, you also must use the Scan tool. So as usual,if you attempt any maintenance/repair of the Prius,always consult the repair manual before starting. These high tech hybrids are not like the cars of yesterday. :)
  14. kkister1492
    355
    Fremont, CA
    So, according to my friend - the Xerox repairman - The letter had stated that this guy had gone into his dealership to have the brakes and rotors replaced and he was quoted a price of $15,000. So he left and went to his neighborhood shop to get a quote from them and they refused to touch it. (My first thought was that there waws a misprint in the newspaper and the price was $1500. But even at that it's pretty high.) That was when the 'experts' started their explaination as to why it was so expensive.
    Whatever!! I'm not going to lose sleep over it but I will make extra darn sure that my brakes don't ever get to that point. We just replace the brakes and rotors on my Grand Voyager for $500 +. Apparently, my teenage son drove a few too many miles with the stereo turned up very loudly and didn't hear the screaming of the brakes. Hoefully, he's learned a lesson. And the kids wonder why I won't let them drive my car!
  15. DanMan32
    DanMan32 Senior Member
    3,799
    27
    Tampa Bay, FL
    The brakes on the Prius is no more complex than newer ABS systems on other cars, as Jayman said. And I was the one that posted the brake diagram for discussion: http://priuschat.com/forums/viewtopic.php?t=6778. Regen has nothing to do with the hydraulics, other than the skid (brake) ECU asking the HV ECU to use regen so it can use less or no hydraulic brakes. Regen is done from the PSD (Power Split Device) using MG2.
    The pads/rotors/drums/shoes are otherwise standard stuff.
    As for bleeding, that would be tough to do, as you have 2 lines going to the wheel cylinders: one to create pressure in the cylinder, the other to release it. But I suppose constantly cycling the brakes and bleeding would get some air out either through the bleeder or back out to the reservoir.
  16. jayman
    13,439
    641
    Winnipeg Manitoba
    <div class='quotetop'>QUOTE(kkister1492\";p=\"73928)</div>
    I think you can stop right about there. Geez, that explains everything.
    I recommend a severe beating. For a small additional charge - or one fluffy homebaked Cherry and Rhubarb pie - I'll do it for you.
  17. jayman
    13,439
    641
    Winnipeg Manitoba
    <div class='quotetop'>QUOTE(rick57\";p=\"73914)</div>
    Rick:
    Happy to hear that. Don't forget what I said before about your back exercises. At least several times a week, preferably once a day, and your back will rarely go out.
    Jay
  18. rick57
    rick57 Member
    572
    Circleville, Ohio
    <div class='quotetop'>QUOTE(DanMan32\";p=\"73936)</div>
    Hey Danman I got off track with all the posts and forgot to dig into the brakes like we had started in the other thread. But I guess I am curious now so I will reread that thread. And for the lines,there are only 1 line to each wheel,not 2 as you thought.
    And jayman,I remember about the excersises,don't worry. Also I don't like rubarb but I will take cherry, :lol:
  19. jayman
    13,439
    641
    Winnipeg Manitoba
    <div class='quotetop'>QUOTE(rick57\";p=\"73942)</div>
    Rick:
    Glad to hear that. It's easy to forget about the exercises until it feels like there is an ice pick buried in your Lumbar.
    I think rhubarb is an acquired taste. My Mom always plugged plenty of rhubarb down my pie hole, so I'm addicted for life. It truly is Nectar of the Gods.
    I keep dropping hints for Frank Hudon to ship me some of his excess rhubarb when his garden is ready, but noooooooo he never does. :cry:
  20. DanMan32
    3,799
    27
    Tampa Bay, FL
    [/b][/quote]
    Hmm. Not what the diagram is showing.
