Easy way to tighten/torque lug nuts - DigiWrench or similar?
Discussion in 'Gen 2 Prius Main Forum' started by AdamKPL, Sep 29, 2008.
  1. AdamKPL
    AdamKPL Member
    118
    East Hampton, Connecticut
    Apologies for my laziness, but I find it incredibly annoying trying to tighten the lug nuts appropriately. Not only are you tired after your project but I just don't feel like finding a torque wrench, adjusting it, then making sure I don't scratch the car doing it.
    So I found this thing online called the DigiWrench. Nocord Online :: DigiWrench
    Really couldn't find any reviews, but it seems like a nice solution...anyone heard of this or any other alternatives. Also doesn't it seem like it would be underpowered running only on 12v?
  2. Patrick Wong
    18,200
    6,497
    Yes, also $90 is a lot to pay for a one-trick pony.
    The advantage of a regular clicking torque wrench is that it can be used for a variety of auto repair jobs. If you use a 4" or 6" extension, you should not have to worry about scratching the finish of your car.
    If you need a socket other than one of the four provided with this DigiWrench, where will you be able to purchase one?
  3. David Beale
    David Beale Senior Member
    5,963
    1,987
    Edmonton Alberta
    It uses a standard 1/2" socket drive so any impact 1/2" drive socket will work. You may need to purchase 1/2" drive "deep" impact sockets as Toyota wheel nuts are buried in the wheel quite deep. They are easy to find.
    The only problem I see is the small handle. Remember, when you torque a nut there is a reaction force back through the wrench. I suspect this unit uses gearing, so the reaction force may be greatly diminished.
    Overall, it is much the same as an "air wrench" with adjustable torque setting. I wouldn't trust it until I tested it, but if it actually works as advertised it would be a good solution.
  4. Patrick Wong
    18,200
    6,497
    Hi David,
    Note that the cord is attached to a cigarette lighter plug. Hence the most power that the unit can draw is ~10A, before popping the Prius fuse.
    Assuming that the Prius is READY, the DC bus produces around 13.8V. Hence, 13.8V x 10A = 138W of available power, and the motor will have an efficiency factor since some of the power will be converted to heat.
    Meanwhile, the wrench is advertised as being to exert 250 ft.-lb of torque. It is hard to reconcile the advertised figure with the wrench's power consumption.
  5. jelloslug
    jelloslug It buffed right out!
    813
    55
    Greenville, SC
  6. AdamKPL
    AdamKPL Member
    118
    FYI, Buy.com has the unit for $54.00 + $12 shipping...jumped on it so I'll post a review once it's in
  7. AdamKPL
    AdamKPL Member
    118
    Never seen those, none the less if this thing actually works it's a much better buy than the torque sticks in terms of dollars and cents.
  8. jelloslug
    813
    55
    Greenville, SC
    There should be plenty of power for it to work with a 10 amp fuse. Most electric torque impact wrenches run about 1 RPM a full torque so that would work out about to .048 HP. That is 36 watts of power out and I would assume 75% efficiency on the motor and 50% on the gear reduction. This would put the watts in at 95 watts. All bets are off if the full torque is faster though.
  9. jelloslug
    813
    55
    Greenville, SC
    Torque Sticks are what most shops use for torquing lug nuts. They are a professional grade tool and have a lifetime warranty.
