bump of shift knob can damage transmission
Discussion in 'Gen 2 Prius Technical Discussion' started by cycledrum, Sep 27, 2008.
  1. hschuck
    hschuck Member
    385
    bay city, ca
    I don't know if this helps, but, I believe Dozzer is talking about the unique case of hitting 'park' while at speed which forced the sys into N and then not being able to shift to D without hitting the brake. Others are talking about freely shifting without having hit the park button. The cases may not be the same.
  2. eagsc7
    eagsc7 Geocacher
    Prescott, AZ
    Here is what I've learned ALL BY DOING.
    You CAN shift from D to N at any point with no issues(I've done it at 83mph). You CAN Shift from N to D at any point with no issues(I've done it at 62 mph). The reasons for this is mountinous regions we shift out of D when crusing down mountain passes.
    ohh, and the cops DON"T pull you over.
    The Steaks
  3. richard schumacher
    7,666
    1,047
    United States
    That's a bit like saying it's OK to smoke two packs a day 'because you haven't got lung cancer yet.
    Why aren't you using "B" when coming down mountain passes? That's what it was designed for. It's silly to burn up the brakes and risk having one of the motor-generators fly apart.
  4. qbee42
    3,079
    No need to press the brake when switching back to D.
