Why I use the term "stealership"
Discussion in 'Gen 2 Prius Main Forum' started by Wolfman, Mar 20, 2005.
  1. Wolfman
    Wolfman New Member
    1,233
    Williston, ND.
    I took my 03 Prius in for it's 45K service yesterday - consequently the first one that I had to pay for out of my own pocket in part due to them having to make good on an earlier mistake on the last service.
    I did my usual hand them 4 bottles of Mobil 1, one only half full, and reminded the tech doing the service writeup that I wanted the 45K service done according to the list in the Prius book, and also that my tires are to be kept at 44 front, 42 rear. I also asked for one empty bottle back.
    I was told it would be two and a half hours. No problem. They're feeding the customersas it's a Saturday, and I wanted to get my fill.
    I go eat, watch some TV, and then wander around the lot. I decide to get more water, and find that my car is back around front already, so I go to the desk. Coincidentally, the paperwork has just been printed.
    On the list - trans fluid change, EFI "system cleaning," and I'm being charged for engine oil that I supplied - and I've supplied my own oil from the first service. I end up pointing out to the cashier that the oil was supplied by me, and the trans fluid change and EFI "work" was not authorized by me as part of my car's service.
    The service writer comes out and tries to explain that this is their "standard" 45k service as listed on their big board outside. I told him that I don't care about their board, and that I specifically requested that they did the service as mentioned in the book. His supervisor comes out, looks at the work order, and then snatches it off of the table. He comes back a few minutes later, visibly put out at me, and then states that he knocked $100 off of the ticket. While the cashier and I were waiting for the new paperwork to print up, his "duties" had him pass me by two or three times more, and every time, he would get beet red in the face as he stormed by. Seems that he was rather put out at being caught and stuck with eating his "extra" work.
    When the service writer came back, I reminded him that I bring in my car for service not because I don't know how, but because I don't WANT to be crawling around under cars al the time, like I used to.
  2. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Wolfy:
    Geez but THAT sucks!
    Whenever I bring a vehicle in for service, I always go over *every* point and then make the service writer print out a hard copy. I make the service writer initial where it mentions "Customer must be contacted for any additional work" and I initial every line I wanted done.
    I'm not sure if your local jurisdiction has that legal out in the work order. It's required here, but naturally 99% of the time the customer *never* initials it. They trust their service writer, which can be a *big* mistake.
    My local Toyota dealer has no problem with that and knows I'm a "by the book" sort of person anyway. If it's not in black-and-white, don't even think about it.
    Sadly, another local Toyota dealer wasn't so honest. Despite the printed work order with their initials by the "Customer must be contacted ..." they did a *lot* of extra work when they did the warranty head gasket job on my 1990 Toyota 4Runner. I even bought the d*** thing off them new too.
    They did things like gear lube change all around: I had changed using synthetic lubes less than 3 months previous. Yep, the EFI "cleaning" which is usually a high-profit maker for the dealer. Even "cleaned" the HVAC.
    All in all, around $400 in extra charges. I flatly refused to pay, the service writer - a young smart-a** little s*** - got all snotty, and I demanded to see the dealer manager. Oh, that young little s*** also tried to snatch away my original hard copy work order where I quite clearly initialed by "Customer must be contacted ..."
    I growled at the little s*** that if he ever touched me again, I'd flatten him, then we glowered at each other as the dealer manger ran huffing over to us.
    I pointed out where I had initialed to be contacted for *any* work not expressly authorized by me. The manager also tried that "discount" bulls*** and I loudly remarked to the waiting folks in the service area "Everybody watch your wallets, these characters will rip you off!." I then threatened to contact my lawyer.
    The manager, then beet red, took the "updated" work order from that lying piece of s*** service writer, tore it up, and instructed the cashier to stamp "Paid In Full" on my original work order.
    You really have to stick up for your rights. I'm sure there are good dealerships out there, but there are also a lot of crooks too.
  3. TonyPSchaefer
    14,816
    2,499
    66
    Far-North Chicagoland
    almost sounds like it's neccesary to have a printed copy of the work you want done and a note indicating that you supplied the oil up front and having the service tech sign it before starting the work.
    I'm a bit put off, though, that their "standard" service would deviate from the printe Toyota service plan.
  4. Wolfman
    Wolfman New Member
    1,233
    Williston, ND.
    There's this HUGE board on the wall where you drop of the cars. labelled every 3k miles of course. I'd hazard a guess that there is alot of "extra" stuff on at least 80% of the scheduled items. They call this their "Toyotacare" program or some such BS name. IIRC, one of these services tallies in at over $1,000!!!
    The next service for my car will be at 52,500 miles. All this one entails is an oil change and tire rotation. They do these on the outside lift where I can babysit them. If it wasn't for the fact that they are the only Toyota stealership in my range of travel around the metromess, and that they are literally located 3 minutes from work, they'd be out a customer already.
    Now, if they screw up the 60K service, they will be finding out what happens when I've reached the end of my rope.
    Oh yeah, they also reset the damned consumption computer also. :cussing:
  5. Cosworth
    Cosworth New Member
    ATL, GA
    I only take my cars to dealerships if I have friends who work at the dealerships. Otherwise, I work on my own cars.
    My mother owns an Audi and had it go through 60k service. Guess what the cost was... $600! :x And, this was for checking fluids, greasing hinges, etc. Then, they have nerve to tell us that the brake pads & rotors need to be replaced... at $710!!
    Hate stealerships!
  6. Wolfman
    Wolfman New Member
    1,233
    Williston, ND.
    <div class='quotetop'>QUOTE(Cosworth\";p=\"74044)</div>
    This is the first car I've ever decided to let somebody else do the maintenance on. It's more of a feeling of being too strapped for free time, and not wanting to crawl around trying to reach around under a vehicle wil low ground clearance.
    But, if they cannot do the job right, I guess I'll end up going back to doing it myself.
  7. jayman
    13,439
    641
    Winnipeg Manitoba
    <div class='quotetop'>QUOTE(Wolfman\";p=\"74042)</div>
    Wolfy:
    If *that* happens ... you had better start practicing on reducing your Circular Error Probability right now.
    Remember: you have to *slowly* exhale and then *gently* pull through the break-over point.
    :twisted:
  8. Frank Hudon
    Frank Hudon Senior Member
    4,147
    If it was my consumption screen that was re-set I'd be in jail now awaiting my court apperance on an assult charge. Or out on bail awaiting my court apperance on an assult charge. I'd be long past the end of my rope.
  9. TonyPSchaefer
    14,816
    2,499
    66
    Post-it Note on the MFD. "Resetting the Consumption Screen will cost you $<insert service price here>!"
    I'm only half kidding.
    I have changed the oil in all my cars. I married my wife because she once cancelled an afternoon date with me because she felt her car was running rough and she wanted to check the gapping on her spark plugs. But when it come to the Prius, I will give it a little more time before I'm comfortable performing work on it myself. I love my car but know my limitations. I will reclaim my manhood at some later date.
  10. Mary Lou
    Mary Lou Junior Member
    44
    Lynbrook, Long Island
    [font=Comic Sans MS:13d8f961be]When I brought my car in for my first oil change, I received a survey from Toyota in the mail for the service of my car. Fortunately, nothing went wrong and I gave them excellent ratings. I'm hoping when I bring it in for second service, I will get a survey from Toyota too. The dealership seems to be very concerned with the ratings they get. Before the survey came in the mail, someone from the dealership called to make sure everything went okay and that I was satisfied. They then mentioned that I will be getting a survey from Toyota about this trip to the Service Department and that if I wasn't going to rate them excellent, let them know, they will try to make it right. Does Toyota send these surveys out for all customers who get regular service?
    Mary Lou[/font:13d8f961be]
  11. jayman
    13,439
    641
    Winnipeg Manitoba
    <div class='quotetop'>QUOTE(TonyPSchaefer\";p=\"74062)</div>
    Tony:
    That's so bizarre it *has* to be true!
    But if she has any single sisters with the same "bad" habit, feel free to PM me.
  12. galaxee
    galaxee mostly benevolent
    9,810
    469
    MD
    In response to all of this:
    WOW.
    I bet half of all those extra charges you didn't authorize were because the service writer wanted to make more commission. As far as I know the techs just do what the service order says and aren't allowed to do any more unless the owner is contacted and gives authorization. Unfortunately trying to sort out who exactly is at fault there is probably difficult.
    My husband works half in the oil change and half in the regular service bays (he's the newest employee so he gets screwed until he moves up) and his bonus every month is based on his customer service surveys. They survey a certain percent of his jobs and base his bonus on their ratings.
    Then again, he must work for a dealership, not a stealership.
    I would avoid ever going to a place like that again.
  13. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    Boy I'm glad my dealer isn't like these guys.
  14. kidtwist
    kidtwist New Member
    183
    My one complaint about a Toyota service center is from a few years back and has nothing to do with money.
    The service writer called me a few days after I'd had some work done and told me I'd be getting a survey and he wanted me to mark the highest rating on each item. I wasn't inclined to do so because I'd had to wait several hours past the time promised before I got my Tacoma back. They had another screw up too but I don't recall what it was.
    He implied that he'd be in a lot of trouble if I didn't. I went ahead and did as he asked, but I never went back to that Toyota dealership again. It just annoyed me that he'd call to ask for something like that.
  15. DanMan32
    DanMan32 Senior Member
    3,799
    27
    Tampa Bay, FL
    Whenever I go for service, I get a call from the dealership, of which I can never return because they never leave a number. They say I should get a survey, but I never do.
    For that one time they spent supposedly 2 hours to supposedly set the alarm to passive mode, I would have given them bad marks. They obviously did set it to passive, but it doesn't take 2 hours to do that so I don't know what they did.
  16. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    Great to see people sticking up for thier rights. I don't think it would be out of line naming these "Stealerships" for the benefit of other Prius owners in your area.
  17. rick57
    rick57 Member
    572
    Circleville, Ohio
    <div class='quotetop'>QUOTE(Mary Lou\";p=\"74064)</div>
    Mary Lou, I think they do send out surveys to all their customers, be it an oil change, 60k or warranty work. My dealership ( I can call it that can't I?) phones all the customers about a week later (each writer in charge of his/her own) to check if the work was done ok and if they had any problems. If there are, they try to reschedule the customer to correct their problem. Toyota is big on survey scores and tries to get dealers to improve their scores. Ours was down a little last year(not bad but could've been better for us), so I went to the service manager to suggest that we try to make sure everyone is trained/doing things the right way/looking after the customers car/etc. So guess what, he made me Shop Foreman!. Oh boy! Now I am the guy every body goes to when having problems and I try to keep everybody doing things the right way. We have even had a few training classes( yes I'm the teacher).Our scores are much improved. They were never really low, but the service manager never likes to see us get bad reports,just bad for business. Without the customers, we would be out of work. Word of mouth you know. Even so, I know there are even a few techs in my dealer, as in all dealers, that you wouldn't want to let work on your new car, whatever it is. You just need to find the right dealer/tech that you are comfortable with and go with them. There are good ones out there. And need we forget, the techs service writer also. Mine doesn't know a lot about cars( less about Prius') and is always asking for our help in some things( always asking me questions on the Prius,haha). But she is a good service writer, best we have. Even won some city wide contests. So I guess you need to know the service writer and tech well enough to trust them.
    Sorry to hear about Wolfmans and everybody's hard luck. Maybe if everybody just kept on Toyota about your specific dealer things would change. If you need to, maybe contact your region. The Regional Manager I think would love to hear about any problem dealers he has. Toyota really wants happy customers. :)
    Now go ahead and bash me :cry:
  18. galaxee
    9,810
    469
    MD
    no bashing here rick. sounds like the way my husband works too. tries to do all he can for each customer. in fact he has a few people who refuse to let anyone but him work on their cars! all the techs get bonuses for keeping their customer survey ratings high which is an added incentive.
    i believe it is a dealer-specific thing as well, some places are more concerned with money than customer service.
    i got survey call 3 days after buying my new prius and they took down every little comment i made. they really seemed to care. i had no complaints but it was nice to know i was being heard.
  19. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    Rick et al. I suspect milage varies. Junior people do a lot of simple work and if they are not supervised to do quality work, quality work suffers. I suspect they are encouraged to be fast. My last encounter with the "dealer man" was plus minus. I came in with my 4 quarts of Mobile 1 and my copy of "New Car Features" that I was reading at the time. I had to put both down on the counter so the service guy could do the paper work. He had to have seen the book. It was not special it was the book I was reading, I am always reading a book. He should have know I was a Prius geek (yes I am and I have no interest in changing so shove your 12 step). I told him to leave the extra oil in one of the bottles in a plastic bag in the back and went to the waiting room for the 10k and the Nav upgrade. They got it half right. Oil cool 1/8 below the mark and about 350 cc in the bottle. They rotated the tires alright, 42 psi in the back, 40 in the front. They did not check the tires. I expected them to be set to factory, but they never checked. :roll: I my business I get a malpractice suite when that sort of thing happens. Makes me grumpy. I think the technicians probably do a good job, or would like to think that, but the folks in the oil change bay are not supervised as they should be.
  20. galaxee
    9,810
    469
    MD
    <div class='quotetop'>QUOTE(hdrygas\";p=\"74874)</div>
    To be stuck in oil change is a very unfortunate situation for anyone, as far as I have heard... they simply get screamed at all day for not being able to do the job of two people. They get no respect for any qualifications they may have and the service writers seem to have a general disgust for them.
    That's what my poor hubby deals with every day as an ASE certified tech who is half working in the oil change bays and half working in the tech line.
    I could see being screamed at as a distraction from checking your tire pressure.... these poor guys are worked to the bone for practically no paycheck. They are just trying to get the work out faster so the service writers get off their backs,as you mentioned. At least it was just a small mistake and easily corrected without having to return to the dealer.
    Not to trivialize your situation, but that's what I hear about every night after my husband comes home from his 14 hour day....
