"check engine" light 4 days after installation
Discussion in 'Prius PHEV Plug-In Modifications' started by SaucyRed, Oct 8, 2008.
  1. SaucyRed
    SaucyRed BEV jockey these days
    Redmond, WA
    We had a Hymotion battery put in our 2005 Prius with 35k miles on Friday. We've driven over 300 miles since then, about half of them with the pack charged.
    Tonight I went to start the car, and on the dash there's a big red triangle with an exclamation point, and the "Check Engine" light. They do not go away. On the MFD, it says "! Problem" for a minute, and then just shows an outline of a car with an exclamation point in it. The engine does come on after a minute, but I sure don't want to drive it with the "Check Engine" light on.
    I tried it a few times, with more than a 20 minute break. I had the pack turned off the last three tries. Same behavior every time.
    Any ideas? Obviously the car has never done this before. It's about 45 degrees here now. I'm charging with a 50' 12awg cable. I sent email to a Hymotion tech, but a lot of times people here respond faster and are more straightforward. Plus others thinking of getting a pack installed want to know what's going on. :) I will update this thread once it is resolved.
  2. SaucyRed
    Redmond, WA
    The "check engine" light was very persistent that evening, but was gone the next morning. It has not reappeared.
    123systems responded quickly and sounded surprised. They asked me to take it in to Green Car Co to get the OBD code checked. No code.
    So, nobody knows what happened, but it's gone...
  3. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    If it was a transient problem, four reboots tends to clear the
    triangle and check-engine light. That may be what you saw.
    A good scanner may still be able to pull what happened as a
    "history code", so worth trying anyways.
    My first guess would be a CAN glitch, which might give you
    a U code of some sort.
    _H*
  4. jerktaculus
    jerktaculus New Member
    Toronto
    I have experienced this a number of times on really cold mornings and only after charging for extended duration - I can start the car all day after getting pack going initially and the problem wont recur.
    Here's my cureall for the red triangle at wake up - start up,
    1) Start vehicle - if engine starts up IMMEDIATELY - then it is in limp mode. Turn off - Restart.
    2) The second start always starts up normally but still shows the fault.
    3) Wait 5 seconds, cycle the on-off switch - the triangle will likely flicker once or twice
    4) Repeat the process after another 5 seconds.
    5) Done.
    There is likely not a problem with the fundamental operation of your pack - perhaps there is some kind of software update that will come to fix the annoyance.
    I am guessing this is some kind of CAN sync'ing issue right at start up - why on cold mornings - not sure. 12V battery is perfect - no problems there.
  5. SVPriusFan
    SVPriusFan Hymotioned and loving it...
    115
    Denver Suburbs
    When I had my install done last week, the tech plugged in a special laptop and did a number of software-related checks, including checking the software revision (I have the latest). He said he could update the software if I didn't - perhaps this might have something to do with the intermittent red triangle? Just a thought...:rolleyes:
  6. Arthur
    Arthur Member
    94
    56
    Corning, NY
    I had my Hymotion system installed about a month ago. After the first few days, I started seeing the big red triangle and the check engine light. In my case, the problem usually occurred after my pack was completely discharged. It seemed to occur at random times.
    A123 Systems eventually replaced my unit with a new one.
    I wouldn't drive a Prius when the red triangle or engine light are displayed.
    The Hymotion manual explains how to clear this kind of error:
    "Resetting communications between the L5 PCM and Prius
    Some temporary and minor problems could be resolved ​
    by resetting and saving the Prius' communication and
    diagnostic codes. This is done
    by turning the vehicle off and on five times, pausing aminimum of thirty seconds
    between cycles."
    If the error recurs, you should probably disconnect it. In the back corner of the car, on the left side of the battery, there is a big white connector. Disconnect it and connect it to the identical connector (with jumper wires on it) that is hanging next to it. This completely disengages the Hymotion system from your Prius and allows your Prius to operate as it normally did before the battery was installed.
    I would suggest that you either call A123 at 508-497-7398 or call the dealer where your battery was installed.
    They will probably ask you how many times the red LED (on your dash) is flashing. It flashes a different number of times for different errors. Mine was doing 11 short flashes, followed by on long flash, and then repeating.
    I hope this helps.
    Arthur
  7. jerktaculus
    Toronto
    Fixed it - my 12V was dead dead dead. As soon as I put a battery tender on overnight the problems dissapeared. I checked current draw on the 12V when charging and couldn't see any difference - so I don't think the A123 Battery is killing it.
    I repeated some tests over the weekend to check at what voltage the system starts to register errors - red triangle. Looks like about 11.5 V - drops to 9.5 V when everything starts sucking juice - my 12V battery is definately toast.
    On the cold mornings - 29 - 32 F approx - we've been having lately - my 12V is dumping to 9.5 V before load applied and the car won't even start - so I had to bypass the PCM with the bridge plug and after the car has put some charge into the 12V - change back to PCM harness - everything boots up ok and runs normal.
    Soooo - I guess I need a new 12V battery - but I'd like a way to make sure it doesn't continue being a problem. That little bugger has been a source of pain - though it seems to affect the PCM before it affects the car .. need a high capacity replacement - or a battery tender - since I am plugging in anyway - should have a little 12V charger running to the battery to keep it topped off .. thoughts.
    I sent off some e-mails to the A123 systems gang - see what comes back.
  8. boxer93
    boxer93 Psyched for PHEV
    155
    22
    Southern NH
    Great observation. I have not had this worry since my Prius is brand new. I'm sure this could help others with older 12v batteries. With winter close I think a new 12v battery would be due. I'd be curious with a123's reply. Since hymotion started in Canada I would expect that they would have experience 12v battery issues by now.
    Chris
  9. SaucyRed
    Redmond, WA
    The L5 LED was not flashing the first time this happened to me. I took it in to my installer, but they didn't find an OBD code either.
    It happened again a few days ago; this time the LED was flashing. I'll put an update on that in my other thread about "flashing LED error codes"; there did appear to be a pack problem. But for this thread, I'll just say that the multiple-reboot (turn car on, then off, then wait 5 seconds; repeat a few times) worked fine to get rid of the check engine and other nasty lights. The multiple on-offs appear to have to be within a certain period of time, but I don't think you have to race to do it.
  10. hybrad2
    hybrad2 New Member
    Southern California
    Correct...restarting the car 5X clears the cann bus faults.
    Hybrad
