12 V switched source under hood?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Hman, Oct 14, 2008.
  1. Hman
    Hman Petrophobe
    We have 2 switched sources of 12 volts inside the car, but I couldn't find a neat source to tap into under the hood without tieing into the fuses.
  2. eagsc7
    eagsc7 Geocacher
    Prescott, AZ
    Personally, I would Always tie into the Engine Junction Block, But beings you asked...
    There is a Red wire that comes off the Engine Relay Block. From there, it goes into a Junction Connector, splits and becomes 2 Red wires. Assuming that you have the correct wire, you may tap into that wire for your accessory.
    A BETTER WAY:
    Goto Radio Shack , and have them explain how you would add a breaker into a vehicle breaker pannel. Follow their directions. I'd put the new breaker near the Dome Fuse in the Engine Relay Block.
    The Steaks
  3. Bobwho
    Bobwho New Member
    68
    Chicago area
    Under the hood is exposed to the elements. Read it will eventually become corroded. Given that salt is bad for electrical connections you must live in an area away from all snow, the oceans and dirt. If you are savvy enough to be under the hood with all of the high voltage just tap into the fuse box and have at it. Make your own connection point and add whatever you want to add in the way of accessories. Use underground rated wire nuts to make all of your splices weather proof to avoid the corrosion problems. Be certain that none of the stuff can vibrate into anything that can be damaged.
    Have fun voiding your warranty!
    Sarcasm keeps you from telling people what you are really thinking!
  4. dapastaguy
    dapastaguy Junior Member
    45
    Sumter, SC
    Why not just bolt it onto the jump start post? That is a mighty convenient 12V source under the hood?
  5. Hman
    Hman Petrophobe
    That would be great, but I need the power to shut off with the car. I was good at working on normal cars, but the Prius is a challenge even with a repair manual.
  6. fruzzetti
    fruzzetti Customization-Obsessed
    377
    California (Pulled over 6x, ticketed 2x for tint)
    Hold on a second....
    You want switched +12VDC and you want it WITHOUT tapping the fuse block (which is exactly the right place and right way of getting your switched +12)?
    Seriously, if you're going to draw your own power from a switched source aside from the fuse panels, you're going to want to install a fusible link in-line (or similar) because if I were you I wouldn't trust anything you were thinking about installing under that hood nearly as much as I trust the stock electrical components of the car -- I would assume the stuff I sought to install was the most likely to fail catastrophically and I would either:
    1) get a fuse tap and tap into a line already running below capacity
    2) get a jumper and a fuse and borrow from an empty fuse position
    3) if absolutely impossible to use the fuses, I'd tap into the power for the windshield squirter and install a fuse in-line to my work.
    ~ dan ~
    Better safe than stupidly standing on the side of the road watching your car burn to the ground.
  7. Hman
    Hman Petrophobe
    Thanks. I've never had a problem working on cars, but the Prius is a very sophisticated craft. Also being a neat-nut, I didn't want dangling wires or the cover ajar on the fuse panel. I didn't want to tap essential fuses (which all seem to be), but block B looks like a possible candidate for a tidy tap. Do you know what this is for?
