Sudden Braking Slow Down in Rain
Discussion in 'Gen 2 Prius Technical Discussion' started by ravenmaniac, Sep 30, 2008.
  1. ravenmaniac
    ravenmaniac Senior Executive VP of Nothing
    156
    DC Metro Area
    HELP! My 2005 Prius has begun to have a mind of its own when it rains. Here is what happens: As I am slowing, when the car gets to the point of the regenerative braking system turning off (7/8mph), the brakes make a squeak and slow the car down abruptly without pressing harder on the brake pedal, but only when it is raining and the roads are wet. It started doing this about 3 weeks ago. I took it to the dealer and the rain stopped on my way there. Of course, the roads dried and it wouldn't duplicate the problem. The tech was great though! He rode with me a few times to try to duplicate the problem, but to no avail. He removed the wheels, checked the braking system completely, but said everything was okay. He checked to see if there were any TSB's and there was not.
    Then, three weeks go by and it does it again in the rain last Friday. I try to get it to the dealer near my work, but of course, it stops raining and the problem goes away...Wth! :eek: It's not just me. My brother drove it in the rain too and noticed the same uneven brake modulation. I'm not talking just a minor slowdown either. This is gonna get me rear-ended, for sure! At one point, the traction control kicked on when it did this. I don't know what to do to get this fixed! Any suggestions would be great!!! Thanks fellow PC'ers.
  2. richard schumacher
    7,664
    1,046
    United States
    [clueless remark deleted]
  3. Patrick Wong
    18,204
    6,505
    I assume that you've owned the car for a few years and that the problem has only appeared recently. If true, then it sounds like your problem happens when the front brakes get wet. If the tech's inspection doesn't show any brake problems, and you are still motivated to take action, I suggest three possible courses of action, from least cost to highest cost:
    1. Using your garden hose, apply a strong spray of water to the front rotors and front brake pads to clean off any dirt and debris. Drive your car, get up to 40 - 50 mph, then shift to N and apply the brakes to dry them. Repeat a couple of times.
    2. Buy a can of brake parts cleaner. Raise up the front of your car and remove the front tires. Place some newspaper under each front wheel to absorb brake parts cleaner as it drips down. Liberally spray down the front rotors and front brake pads until all dirt is removed.
    3. If 1 or 2 do not help, then replace the front rotors and front brake pads.
    Also, I am wondering what is the tread depth on your front tires. Since your area usually faces a snowy winter, I suggest that you consider replacing those tires if your tread depth is less than 6/32".
  4. dogfriend
    7,512
    1,190
    Carmichael, CA
    I think this may be related to the type of friction material Toyota uses. I have noticed this phenomenon (brakes are much more sensitive in wet conditions) on 2 different Toyota pickups that I have owned and my father also mentioned this when he used to have a Toyota pickup.
    I have noticed it on the Prius too. I just try to compensate when it is raining.
  5. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
  6. EZW1
    EZW1 Active Member
    722
    81
    Phoenix, AZ
    2016 Prius v wagon
    Four Touring
    In order to effect a smooth stop in any vehicle, you've got to let off pressure a bit on the brake pedal the last few seconds before the car comes to a stop. The reason for this is because as the car slows, less force is necessary to slow it and just before it stops, very little force is required. If you don't let up on the pedal, the car will appear to 'jerk' to a stop. When it rains, the probelem is exascerbated because the water washes the dust off the pads and rotors, making braking more effective.
  7. jpadc
    jpadc Type before I think too often
    343
    34
    Indianapolis and Northern Wisconsin
    2017 Prius Alpha
    The severity that you describe here makes it sound to me very different than just build up on the break disks. Being this severe (and sudden onset) sound more like an electrical problem. Maybe when the control unit or wiring gets damp (heavy rains) it shorts a bit causing the signal to the breaks to act like you slammed down on the peddle. I'd have the wiring checked for cracks in the insulation or other wear.
  8. ravenmaniac
    156
    DC Metro Area
    Patrick:
    Thanks for your helpful insight!! I'll definitely take your advice and try the Neutral shift at 40-50mph to see if that helps. If not, then I guess I'll have to replace the rotors/pads.
    To my other fellow PC'er who suggested that I let off the brake pedal as I come to a stop. You can see that I've placed over 130k miles on this car. Wouldn't I have this problem in the first days/weeks of ownership if your diagnosis were the case? I have owned the car for almost 3.5 years now and just noticed the problem. Obviously, I know how to bring it to a smooth stop in the rain, but thanks for your input.
  9. ravenmaniac
    156
    DC Metro Area
    Oops! I forgot to mention that the tires are almost new and have excellent tread depth. Just an extra tid-bit that Patrick suggested....
  10. carlson.dl@sbcglobal.net
    [email protected] New Member
    My 2008 Prius seems to want to jump forward instead of slowing down if I am coasting with my foot lightly pressing the brake pedal and the current speed is about 20 MPH and it is about 40 to 60 degrees outside and the pavement is rough enough to bounce the tires. It only happens rarely, so I am not sure how to duplicate it, but humidity may also be a factor.
    Obviously, I have no clue what is going on, but when it happens and an idiot drives right in front of me my heart jumps into my throat as it seems that I have no brakes.
    The dealer has not been able to help me, as they cannot duplicate the problem. I presume that also means there were no problems recorded in the cars log.
    Can anyone offer any suggestions?
  11. jdenenberg
    jdenenberg EE Professor
    3,943
    1,940
    Trumbull, CT
    2020 Prius
    LE AWD-e
    NOOOO! Do it at low speed (15-20 MPH) and gently to clean your rotors. Repeat until braking is smooth and without scraping noise.
    JeffD
  12. qbee42
    3,079
    This is a traction control issue. It's not a problem, but just an artifact of the regenerative braking system.
    At speeds above 7 mph, the Prius uses regenerative braking to recapture some energy. To do this, the front wheels (drive wheels) are used to spin MG2 and use it as a generator. Electricity from MG2 is stored in the HV battery.
    When you hit a bump, the traction control system recognizes the loss of traction and forces braking to switch to the friction brakes. The short transition from regenerative braking to friction braking produces the sensation of jumping or lurching ahead. The car doesn't really jump or lurch, but it feels that way since the braking force is reduced for a very short period. Keep pressing on the brake and it won't cause any problem.
  13. dogfriend
    7,512
    1,190
    Carmichael, CA
    Isn't it actually an artifact of the ABS system? The way I understand it, when you hit a bump and momentarily lose traction, the ABS sensor(s) recognize the wheel rotation speed difference. ABS only works with the friction brake system, so the car must switch from regenerative braking to friction braking to activate the ABS. The surge you feel is the transition from regen to friction braking.
  14. qbee42
    3,079
    The "surge" (it's not really a surge) is the transition from regenerative braking to friction braking, but it's not ABS. It's the traction control system. The main purpose of traction control is to prevent the hybrid drive system from destroying drive train components, which is why it is touchier than most traction control systems. Regenerative braking is essentially electric drive in reverse. Losing traction while doing regenerative braking threatens to shock load the drive system, as well as causing a loss of braking action. The traction control system suspends regenerative braking and hands the braking to the friction braking system. At this point ABS can kick in if needed.
    I suppose we are splitting hairs by trying to decide which part of the ECU makes the call. Wheel slip is wheel slip, and somewhere in the code it gets picked up and suspends regenerative braking, and as stated above, the reasons are two fold.
