MPG going down...HELP!!!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Jonnett, Oct 17, 2008.
  1. Jonnett
    Jonnett New Member
    West Virginia
    I have an '08 with 24,000 miles and in the last month the MPG has gone from 54-56 to anywhere from 44-48...been doing the same routine as usual. Oil and filter (as needed) every 5,000 miles along with tire rotation, gas at the same station, etc...even put new tires on it thinking maybe that would fix the problem as the originals were getting worn but the gauge hasn't moved. I have noticed that the battery hasn't been staying charged as it previously did - staying 1 bar above half way mark...normally almost full or in the green - would this have anything to do with it? (I can never get it back into the green no matter what I do...and I live in the mountains of WV!!) Don't want to make a trip to the service dept if someone can tell me an easy fix...new to the hybrid scene and appreciate anyone's insight into my problem! Extremely frustrated since I was doing so well in the mid 50's!!! :confused: Thanks!!!
  2. Prius_SGP
    Prius_SGP New Member
    58
    Saint Genis Pouilly, France
    Hmmm, sounds a little strange.
    I'm sure that one of the poseters here will be able to make some better suggestions, but: Are you using the A/C or other battery dependant devises more then before? Drop in external temperatures?
  3. Jonnett
    Jonnett New Member
    West Virginia
    Actually haven't been using them as much...was using the A/C but the temp has dropped and now I am only occasionally using the defroster in the mornings and that is only briefly!
  4. richard schumacher
    7,664
    1,046
    United States
    Is this your first winter in the Prius? The MPGs of all cars drop with the temperature; it's just more obvious in a Prius. Check tire pressures at least monthly.
  5. john1701a
    john1701a Prius Guru
    12,820
    5,305
    58
    That sounds normal... for any vehicle. It's the seasonal cycle, caused by factors totally out of your control. Temperature & Fuel changes are the major influences which many people simply aren't aware of until having a Multi-Display. Having a Prius brings a whole new meaning to the coming of Spring.
    Here's a summary of the 5 years of driving data with my Prius:
    Details and more graphs are available on my website.
  6. Ian MacDonald
    Ian MacDonald Junior Member
    51
    Benica, CA
    How long ago did you replace the tires? I noticed about a 15-20% drop in mileage for about 1000 miles when I replaced my tires recently. Thankfully everything for me returned to normal though afterwords. :)
    Temps can also have significant effect. With temps in the 70-80F here in the hilly SF Bay Area I average around 55 MPG in mixed freeway driving but that drops into the mid to upper 40 MPG range when temps are much below 60F.
    Cheers,
    -- Ian
  7. Celtic Blue
    Celtic Blue New Member
    2,224
    139
    Midwest
    My guess is John has hit on the key difference--the coming of cooler weather. But if you've been through the seasons with this car before (and with 24,000 miles it seems likely) then perhaps not.
    With regards to the battery--you don't have anything covering the battery ventilation duct on the rear passenger side do you? You don't have dogs or lots of dust, etc. in the car that could clog the battery's ventilation blower, right? If the battery gets too warm then it won't charge or discharge normally.
    It does seem odd that the battery is not taking more charge, but the SOC indicator has some ability to reset itself if I understand correctly. My '08 likes to stay in the bar just below green. And on steep or long downhills it frequently goes up a bar into the green. (Elevation changes here are usually only 100 to 200 feet although steep and frequent.) I occasionally draw it down two below and once or twice three below green in some ICE-off flat stretches of over a mile. I'm a little puzzled as to why it would not hit green during regen in WV mountains. I would expect it to max out with two green bars on the steep, long stretches. Green isn't really good though so don't aim for it. It represents some excess charge. High blue is the actual target zone of the control system as I understand it.
    New tires are probably costing you mileage as the originals are very low rolling resistance. They aren't the best for handling, but they are fuel efficient. Typical observation is that tires take several thousand miles to break in and that mileage will improve as they wear.
    You might want to check oil level unless you did the changes yourself and have already verified level. Unfortunately, Toyota's own specs will result is a slight overfill. Excessive overfill can reduce mileage or cause other more serious problems.
    Does the ICE shut off normally or do you find that it is stubbornly running at times it used to be off? (If it is always trying to charge the battery that might be the case.) Also, alignment problems could result in more steering input and more drag/rolling resistance, and therefore the engine running more often while moving.
    Any chance of seasonal fuel blend changes for the region?
    Check tire pressure. Lower temp = lower pressure. Time = lower pressure too. (Defroster definitely indicates low temp.)
    I doubt any one of these would fully explain the difference you are seeing, but several might.
  8. john1701a
    12,820
    5,305
    58
    Forgot to ask about the tires... Once you pass the break-in penalty, they won't ever be quite the same anyway. The impression is that those from Japan aren't quite the same as the ones available locally, even if you do get the same name & size. And if you did get a different type, change is inevitable. I upgraded to ones with greater traction, despite awareness of a permanent MPG drop.
  9. Jonnett
    Jonnett New Member
    West Virginia
    Hello everyone and thanks for the suggestions! I purchased the car in February and have been thru the winter months here in WV - as for the tire swap, I did this about 500 miles ago but only after the mileage had started to decrease and haven't seen any change with the new tires either way!!! The only thing that I can think of that I have done differently in the last couple of months was with the oil change, had been putting synthetic in it and with the last change just put regular in...would this effect the mileage??? Should the battery not fully charging concern me? With the WV mountains it used to stay fully charged all the time (almost always in the green - not that I was aiming for this achievement but it was easy to achieve with the long, down hill stretches!) Now it stay one blue bar above the half way mark...should I have this checked with my service dept and if so what should I ask them to look for?
  10. richard schumacher
    7,664
    1,046
    United States
    Don't panic. If they put in too much oil that can reduce MPGs.
    Tomorrow morning before you drive the car check the tire pressures and the oil level.
  11. Gymshortz
    Gymshortz Junior Member
    Olympia, WA
    In Washington they begin adding 10% ethanol to the gas in the fall. I noticed a drop in mileage the last couple of tanks. It is exaggerated in the Prius vs standard cars.
