2010 Prius picture - What could this be?
Discussion in 'Gen 3 Prius Main Forum' started by Paradox, Oct 19, 2008.
  1. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    I am not sure if this has been brought up before, I've been reading SO many posts recently, but in the pictures of the 2010 Prius from a few months back there is something of interst on the dash. In the picture below look at the square 'box' mounted on top of the dash highlighted in red and then the zoomed in box below it. I remember when looking at a Vette back in 01' it had a Heads Up Display (HUD) to show speed etc and the box with the projector to put it onto the windshield looked just like this. Also, a co-worker years ago had a Pontiac Grand Prix GTP and it had one of these too.
    My point is, or question rather, is could this be the housing for the projector for a HUD in the 2010? To me it looks so big just for an area to house a VIN number. I know it's all speculation but I don't have the virtue of patience when it comes to waiting Lol!
  2. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    Now wouldn't that be sweet!
    It would make sense with the MFD moved lower and most definitely not in the
    line of sight when driving.
    I guess it would be too much to ask that there be switchable -- with steering
    wheel buttons -- between maybe energy flow info from the Energy Monitor
    screen and customizable basic ICE and HV battery info a la ScanGauge.
    I suspect that HUD, if offered, would be an option only available on the higher
    numbered packages.
  3. nyty-nyt
    nyty-nyt Member
    139
    Ontario
    We already have a HUD for speed, fuel etc. It's just contained in the dash, not onto the windshield.
  4. Mormegil
    Mormegil Member
    255
    2014 Chevy Volt
    That's just a display. A Head Up Display, is defined as a transparent display overlaid where the viewer is typically looking while driving/flying.
    From wikipedia
    '[​IMG]
  5. Tideland Prius
    16,559
    Could be a HUD. The VIN would be in the black area of the windshield. It would be cool if it could show nav directions like the BMW ones can. You know, just the direction of the next instruction and how many metres/yards to that next turn
  6. fruzzetti
    fruzzetti Customization-Obsessed
    377
    California (Pulled over 6x, ticketed 2x for tint)
    I think you're probably very far off the mark with this supposition. It looks more to me like the projector system we already have in the Prius from 2004 on.
    The display containing your speed, odometer and fuel available is actually down toward the steering assembly in the dash board. It projects an image up to a pair of lens mirrors, and it is through those that we see the display -- thus it LOOKS like our display is there at eye level, however...
    Have you noticed the distance at which your eyes have to focus to see the display? And have you noticed the gentle magnification effect that seems to be applied through that lens? The reason it's done this way is so that you have to spend less time changing the focal length of the lenses of your eyes when you switch between looking out at the road ahead and looking in at the speed of your vehicle.
    If you go out to your car and lean over the front of the windshield from outside the driver's side of the car, you'll see the exact same rectangle shown here in the picture.
    I'll put $5000 it's just that same display we already have in the MkII Prius.
    Plus, engineers are still very much in disagreement on head-up displays. The advantage is that you can put the information in the same area (exactly) as the user is looking and at close to the same focal length. The disadvantage is that you're still modifying the driver's perspective of the actual environment, rather than assigning a safe 'neutral' area outside the driver's moving environment for them to look at to check the speed. There are coloration issues, colorblind-friendly issues, contrast issues, etc etc etc...
    ~ dan ~
  7. fruzzetti
    377
    Also the VIN plate is clearly visible to the right of the projector cutout.
    Sorry guys, my guarantee is 'no head-up display.'
  8. Tideland Prius
    16,559
    That's just a sticker lol. Probably a barcode or something for the windshield.
    Yeah the current one makes it look like the speedo is under the front wipers. If the HUD was temporary (e.g for nav instructions only), that'll be fine by me. I don't know if I want a HUD permanently in my view.
  9. fruzzetti
    377
    Please inspect this image for clarity:
  10. Picasso Moon
    Picasso Moon Member
    117
    Phoenix, AZ
    It sure looks like a HUD to me. I've owned 2 vehicles with HUD and each had a projector slot at the base of the windshield very similar to your picture. This would be a welcome addition to me as I very much liked this feature.
  11. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    My thoughts exactly... I know how the current one works Fruzzetti but it would be MUCH lower in the dash not some big piece/block of plastic as seen in the spy photo. Also, even if it were the projector system we have now just not covered and worked into the dash yet I don't believe that theory. Why? Because if you look at the first interior spy photo which was one of 3 in the set you can see that the normal cutout is already there, the cutout which we see the graphics for in the pcitures provided by bossdowner. Anyways, just something else to look forward to and ponder. Maybe team prius will tease us with a photo of this... Oh wait that would actually tell us something, so if they did it'd just be a picture of a 1" x 1" piece of the plastic not really revealing pertinent
  12. EZW1
    EZW1 Active Member
    722
    81
    Phoenix, AZ
    2016 Prius v wagon
    Four Touring
    When you compare the photos above with those leaked here earlier, especially the one looking thorugh the RH passenger window, you'll notice there is no display like our current 2nd models - so, what is shown above may very well indded be a HUD.
  13. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    I wonder if Toyota sensed some of the complaints people would have(Heck, we sure have heard them voices here) about the nav screen being moved lowed down on the dash, making one take their eyes off the road more often... So maybe they planned for that and added an HUD that has more info available on it than just speed and such like other past cas to have an HUD. Maybe they put in other stuff like when using the navi it will put distance markers or straight, right left turn arrows etc letting one know ery crudely what move will be coming up next from the navi. I mean heck, depending on how fancy and colorful these things can be now (not just that greenish blue color) maybe they'll send the hybrid info to it showing all the inf on whether the car is runing on batt's, motor, regenerating etc...
  14. Tideland Prius
    16,559
    :blush: Yeah I see it now.
  15. Rybold
    Rybold globally warmed member
    2,760
    322
    Southern California
    That's Frickin' Sweet !!!!!! :D:D:D:D:D
    How does it perform in different lighting conditions?
    ("surprisingly, fairly well" or "not that great" or ... ?)
    Question: isn't the Prius display too large for this? In other words, wouldn't it block too much of your field of vision ? )
  16. 9G-man
    9G-man Senior Member
    1,273
    194
    Atlanta, GA
  17. SW03ES
    SW03ES Senior Member
    2,480
    176
    Gaithersburg, MD
    I would be very surprised if it were a HUD.
    Ever wonder why there aren't a lot of HUDs on cars? Studies have shown HUDs actually distract drivers more than they help and legnthen reaction times. The reason for that is when you're looking out the windshield your eyes are actually focused on the HUD, not whats going on down the road so when something happens that requires your attention you have to refocus before you can react.
    HUDs are used on planes because not as much happens in your sightlines you have to react quickly to. Good for planes...not for cars.
    It could be a lot of things, could be a HUD, could be a lane departure warning system, could be a sensor for automatic wipers, could be a head position sensor like on the LS460...
  18. Tideland Prius
    16,559
    LKA and Rain-sensing wipers are incorporated into the rear-view mirror base. Headlight position sensor.... do you mean like the new Venza and its automatic high beam thingamajig?? Not even sure why Toyota is introducing it... didn't GM or Ford use it before?
  19. spwolf
    spwolf Senior Member
    3,156
    440
    Eastern Europe
    head/eye sensor is on the steering wheel in LS... i cant see what this could be but HUD, and I have been in all current toyota vehicles and have never seen such device before.
    As to the automatic high beam, i sure hope it will be on Prius as well - it is awesome feature much needed here in europe, however it sensors would not be positioned there, but they would be same sensors that are in the back of the mirror...
  20. mxvet
    mxvet humble
    26
    davenport, ia
    I've had HUD in my last crossover and it's plain sweet.
    that's exactly the same type of projection area the Buick had.
    i'm happy to see Toyota embrace the idea.
