Winblows strikes again
Discussion in 'Fred's House of Pancakes' started by Wolfman, Mar 23, 2005.
  1. Wolfman
    Wolfman New Member
    1,233
    Williston, ND.
    Once again, Bill Gates nightmare of an operating system has struck again.
    I woke up this morning to find the network partially down, rendering me unable to get online from any of the PC's around the house. Once I found the cause, and got everything back up and running, two of the three machines restored internet connectivity, and all PCs all show up on the network. As for the one that still will not connect to the net. I'm at a total loss as to what is malfunctioning. All settings are correct, no hardware or software has been added to this particular machine in months, virus and spyware checks all show a clean slate. Verifying the network I.D. and address all show what they are supposed to, and there are no user restrictions at all on this machine. Any ideas from the guru's out there? TIA.
  2. longshortofit
    longshortofit Junior Member
    28
    Isle, MN
    Can you ping the other PCs
    If not:
    Check Wiring
    Check NIC card
    Either one of these could have brought your network down in the first place.
  3. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    did you try the ipconfig /renew?
    if the machine in question is a client on a shared IP connect, its possible that when it tried to refresh its addy, the system was down. that would render it not able to connect
    if this is the case, there is nothing you will see in the settings that will reveal this.
  4. Devil's Advocate
    922
    Las Vegas, Nevada
    Hey just wait till all our cars come with windows OS. So when it crashes the car automatically stops, closes all the windows, and turns blue!
    but really, OS based car systems aren't that far off. i bet there is some techno computer geek out there that has already figured out how to incorporate an OS with the prius software. Imagine a super smart car. The car could go off of your cell phone and connect to the internet while your driving, Sweeeeeeeeeeeeeeeeet! Road Porn!.
    This would have an interesting effect on DVD nav systems, since they could be effectively negated by a properly set up web based system.
  5. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    <div class='quotetop'>QUOTE(DaveinOlyWA\";p=\"75128)</div>
    David:
    A Gold Star for you!
    If you have XP, you can also try the Repair Connection but that has rarely worked for me. If you renew/release it's forced to ask for a new number, depending on your particular network.
    I sometimes have this problem with my router - which also has a firewall - if Shaw Cable is doing work in the utility room of my building. The first time it took me hours to get it working again, now I just use IE to enter the router setup and click on Release/Renew.
  6. jayman
    13,439
    641
    Winnipeg Manitoba
    <div class='quotetop'>QUOTE(Devil's Advocate\";p=\"75160)</div>
    Actually, our Prius already are OS based. They use an RTOS that communicates om a CANBus (Controller Area Network) stack with LIN (Local Interface Network) extensions.
    The Toyota CANBus appears to faithfully follow the CANBus requirements for Timing Triggered events and is capable of multiple levels of "limp" mode.
  7. jayman
    13,439
    641
    Winnipeg Manitoba
    <div class='quotetop'>QUOTE(Wolfman\";p=\"75081)</div>
    Wolfy:
    Do you use a UPS on the network? It has been my experience that power bumps (Noise, sag, etc) are responsible for most unusual and inexplicable networking issues.
  8. Wolfman
    Wolfman New Member
    1,233
    Williston, ND.
    Yes, I've tried the ipconfig/renew command, and the machine has been power cycled. The problem still persists. I can try it again as it's only been done once. <<shrug>>
    Jayman, the system is a 100Base-T Ethernet with a wireless ethernet bridge connecting the two houses.
    The neighbours son has been gaming again, which is only confounding the problem as it has direcway throttling the connection - always a guranteed source of issues. I had to power cycle the modem a minute ago to get internet access back again. :cussing:
  9. jayman
    13,439
    641
    Winnipeg Manitoba
    Wolfy:
    Could you please go into more detail on that? Like, what *was* the cause?
    Is the dead portion on this wireless Ether bridge or before it?
    And why the h*** is a neighbor kid involved by gaming?? You have my explicit permission to give him a good whuppin'.
  10. Wolfman
    Wolfman New Member
    1,233
    Williston, ND.
    OK, I finally have the damn thing working.
    I ended up setting the machine to a fixed address, and then re-releasing it back to autoconfigure, and having it re-poll for a new address. Now it connects. I hate winblows.
    As for the cause of this mornings networking troubles, one of the WAP's apparently went unstable, and then locked down. The one that I work with to keep this connection up, is in Missouri right now, visiting his folks. I ended up pulling his box off on his side, and putting mine in place, and setting up my spare WAP here to get the bridge back up and running. For some strange reason, I couldn't get his WAP to respond to being queried, so I thought it was the dead one. When I put mine up over there, the machine wouldn't query it either, so I'll have to test his box on my machine later.
    It's his son, about the same age as me, who is doing the gaming. Believe me, I'm not far from strangling him right now, but he is the neighbours son/pet. I think he's aware of my frustration at the moment. I "asked" him for some bandwith, and told him that his damn game has the entire works shut down. This was when I went down to reset the modem.
    Satellite internet is the absolute WORST form of broadband one can use for gaming. Due to b/w limitations, direcway will throttle connections where the useage is particularly heavy. Add to this, the fact that this is a shared connection, and I want to put a boot up a certain derriere.
  11. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    glad you got everything going again...
    WAP's are notorious for requiring frequent resets. and the problem is nearly always that there is no real problem or at least the problem is transiet in nature
    its like windows 95... if it breaks, uninstall, reinstall. same configuration, same settings... only difference is that before it didnt work and now it does.
  12. jayman
    13,439
    641
    Winnipeg Manitoba
    <div class='quotetop'>QUOTE(Wolfman\";p=\"75183)</div>
    I have found WiFi to be finicky too, so I don't use it. Never mind the security issues. Even CEP doesn't always play nicely with WiFi.
    The biggest problem to satellite Internet isn't the bandwidth throttling, but the latency/jitter. The Clarke Belt for the satellites is a *long* way from here, so anything that depends on isochronous or plesiochronous connections can latch up or act oddly.
    Remember when the Afghan war started and we were watching embedded reporters like Christianne Amanpour? Yeah, I think she's hot too.
    Anyway, the anchor here would be done with his question and she'd still be nodding in that annoying way she has for 5 seconds after the question was asked? That's latency.
    Happy to hear you finally resolved the problem. As far as your neighbor hogging all the bandwidth: Isn't a guy in his 30's a wee bit old to be living at home? Or is he caring for his folks??
  13. Devil's Advocate
    922
    Las Vegas, Nevada
    Toyota CANBus, hmmmmmmmmm
    Toyota CAN i Bus, hmmmmmmmmm
    Toyota CANNABIS, Hey, isn't that illegal???? :silly:
  14. jayman
    13,439
    641
    Winnipeg Manitoba
    Um .... ok ........
    :roll:
  15. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    <div class='quotetop'>QUOTE(Devil's Advocate\";p=\"75196)</div>
    you are starting to think like GM now
  16. Wolfman
    Wolfman New Member
    1,233
    Williston, ND.
    <div class='quotetop'>QUOTE(jayman\";p=\"75195)</div>
    Happy to hear you finally resolved the problem. As far as your neighbor hogging all the bandwidth: Isn't a guy in his 30's a wee bit old to be living at home? Or is he caring for his folks??[/b][/quote]
    Yeah, we use the Wi-Fi as it's the only practical means to cover the distance between the two houses, as it's too far to bury a wire, not to mention that we'd have to cut across two people's properties.
    You know how some people have dogs and cats as pets. Well, this guys kids are his pets. His son arrived a couple of months ago for a "two week visit." He works whenever he feels like it, and has done some rather "unique" things to his body - the kinds of things that cannot be concealed, and that render him unable to seek "normal" employment. The guy apparently has no drive for self support.
    His daughter lives in a mobile home behind the parent's house. She also has a kid, and pays zero, zip, nada, nothing for rent or even attempts to cover any part of the electric bill. She needed a car, bought one from one of those "sell it a dozen times" stealerships. The neighbours wife decided to be nice and cosign a regular loan so that it would be possible to actually pay off the car - a used Hyundai Accent. Not long after this was done, the daughter all of a sudden was "unable" to make the payment.
    All I can say is, that if these two were my kids, I would have had them packing their bags long ago. I would personally never dream of putting my folks through this kind of crap. My folks wouldn't have anything to do with it either, as one of my brothers is finding out. Him and his wife want to be pets, and have been solidly and flatly refused by both my foks, and his wifes' folks - the way it should be.
  17. jayman
    13,439
    641
    Winnipeg Manitoba
    <div class='quotetop'>QUOTE(Wolfman\";p=\"75350)</div>
    Wolfy:
    Well, as far as your 2-doors-down neighbor and his kids, that's his business. An odd arrangement to be sure.
    Anyhoo, I'm still a bit puzzled about this DirecWay Satellite Internet and the WiFi thing. Do you own the DirecWay and the neighbor "borrows" bandwidth, or vice-versa?? I know it's very expensive compared to cable and DSL with inferior bandwidth.
    Sharing bandwidth over a terrestrial link is troublesome enough, but over a satellite link it becomes highly unreliable. Again due to the latency/jitter issue. I'm assuming where you live now has zero access to cable modem or DSL.
    Let's hope you can sell and that the new development has cable modem, DSL, and maybe even fiber to the home. Hey, you can always dream, right?
  18. Wolfman
    Wolfman New Member
    1,233
    Williston, ND.
    <div class='quotetop'>QUOTE(jayman\";p=\"75369)</div>
    Wolfy:
    Let's hope you can sell and that the new development has cable modem, DSL, and maybe even fiber to the home. Hey, you can always dream, right?[/b][/quote]
    Yeah, I just grit my teeth and keep my composure when his pets act up. :D It's not really any of my business, and they already know that I feel that they are being severely taken advantage of. Everybody has flaws, and this is theirs. It's what makes the world go 'round, and gives us fodder to complain about our friends. :mrgreen: We are all on very close terms, and I often refer to them as adopted family. We even just "knock and walk in" when we go over to each others houses. They are one of the things that are making this decision to move very difficult.
    They have the equipment, and I couldn't afford to pay for the equipment myself at the time. They were initially trying to have a wireless USB setup to get the internet to all of the PCs at their house, and having massive issues with it. I then helped them wire and set up their house for ethernet. When we did this, we got the bright idea to link the houses. At the time, I was also having all kinds of problems with sprint and their phone service. Once this was done, it opened up the opportunity to dump sprint altogether, and I offered to pay for a portion of the monthly bill if I could tap off of their system.
    Initially it was a mess as we had to have a dedicated server to process the Direcway system. Network issues and outages were almost weekly. Direcway has since come out with a modem that connects directly to ethernet networks. It's a plug and play operation now, as it does host duty for supplying network addresses. The system works well, untill they start throttling the connection to restrict b/w. When they do this, the modem seems to get flaky, and will then lock down. The only option then is to power cycle it, and let it resynch. Beyond this, it's no harder than setting up any other home network, as the modem only sees network addresses polling for internet useage.
    DSL is available, but would entail letting sprint back into my house - which will never happen. The new development is also serviced by sprint, so no phone lines will be hooked up there either. When I move out there, I'll purchase a direcway system off of evilbay to offset some of the startup costs, and go with satellite again, since there is no cable service at the new place either. I'm not an online gamer, so the system works fine for me.
    As for the WiFi part, it is just two WAP 11's set up to act as a wireless bridge. You have to put the far end's mac address into the respective units, and they simply act as a long cable. Even the sniffer equipment will not latch onto this system for hacking - I've tried. :mrgreen:
  19. Danny
    Danny Admin/Founder
    7,093
    2,120
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    Whoa.... God Bless Texas
  20. jayman
    13,439
    641
    Winnipeg Manitoba
    Wolfy:
    Ok as far as your Internet connection it sounds like you've done the best you could under the circumstances. Your rant on Sprint is cute, like my foaming-at-the-mouth whenever somebody mentions Bell Canada (I used to have property in Ontario and had them for "service" as they are the legal monopoly in Ontario).
    I think DSL is at the end of the ropes. The only way to "compete" with cable modems and especially PON equipment for FTTP is if they install their little boxes every 500-1,000 ft. Like *that* makes any sense, unless you're in a high-rise apartment or condo.
    Too bad you can't get cable modem service at the new place. I suppose the DirecWay is way better than dial-up though. Good luck!
