My battery gauge no longer fills up!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by dagnarus75, Oct 29, 2008.
  1. dagnarus75
    dagnarus75 New Member
    Broomfield, CO
    Hi guys... I'm a first time poster, long time lurker here at priuschat. I am posting now because I think I've run into my first prius problem...
    I bought this car new almost 5 years ago next month. Whenever I have driven downhill for large periods of time (which is often, since I live in the rocky mountains!) I have always noticed that the battery gauge on the "info" screen fills all the way up. That is, until last weekend. I was driving downhill for about 30 minutes, clearly enough time for the battery to fill, yet the final bar on the info screen never showed up. It was always one bar away from the top.
    Has anyone else had this happen? I took the car to the dealership and they say that the battery checked out fine - but that is definitely not consistent with this being the first time the car has exhibited the behaviour in 5 years. The extended warranty expires in 3 weeks, so I am hoping to get this resolved ASAP if it is a genuine problem. Thanks everyone!
  2. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    I think what you are seeing is normal. I never saw a "full" battery on my 04 and have not seen it on my 09. I do have to admit that I usually have the Consumption screen showing as the Energy screen is just eye candy and provides no real useful info.
    The ICE will spin up to bleed off excessive charge on the traction battery. Possibly you viewed the screen just after a bleed-off.
  3. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    I understand your worry, even with our "hills" my Prius reguarly fills up the screen with all green bars. I would inquire further at the dealer as how they tested the battery and make them give you a print out.
  4. narf
    narf Active Member
    611
    45
    Colorado
    Four Touring
    It could also be weather related. The cold weather could be effecting the charge rate. I know for me the only time I see full green bars is when I'm heading down MAJOR hills, like the Eisenhower tunnel westbound downhill.
  5. Turbogizzmo
    Turbogizzmo New Member
    75
    Colorado
    I live in colorado too, on our trip to steamboat the hybrid batteries were drained the whole way up and then on the way back down from steamboat we didnt get the green FULL battery but did get this:
    Then when driving back to Minnesota for my Grandfathers funeral I got a green battery around town multiple time, but never in Colorado.
    Its a fun game to play but I think the Prius does whatever it wants. :)
  6. john1701a
    john1701a Prius Guru
    12,802
    5,286
    57
    Lower temperatures bring on the green (7 or 8) bars more often.
    And as I've observed, vehicle aging does too.
    Now at 107,000 miles with the morning temp in the 40's, seeing more green is pretty obvious. The final 5 miles of my commute is a modest decent at 55 MPH to the river then a shallow hilly stretch of 50 MPH followed by 45 MPH. That seems to be the perfect formula for green appearing at mile 2 then retaining it all the way to my parking spot 3 miles later, now. It didn't use to be that way though. In fact, I didn't see the green last year until the final mile. Before then, almost never.
    So, I'm curious to hear reports from others... especially when the reverse happens with owners that routine drive over mountains. It's basically flat here in Minnesota by comparison.
  7. stephen2002
    stephen2002 Junior Member
    I don't live in Colorado but I've driven there a number of times. I noticed that in long downgrades if you put it in B mode before the battery fills it will really rev the engine and try to leave that top bar as buffer for when you need to use the brakes. If you listen carefully to the inverter whine you'll hear the pitch shift when you use the brakes going down a hill in B mode if there is battery capacity. If there isn't you don't hear the pitch shift. My assumption is that there is still a little bit of regen capacity left while it is spinning the engine full-out in B mode that it'll take advantage of until the battery is full.
    Try one of those long hills without using B mode and the battery indicator should fill all of the way. Just be sure to shift it to B once it does so you don't overheat your brakes!
  8. delgesu
    delgesu New Member
    Ontario
    FWIW, i've been driving my '09 for about a week now, and 1500miles, and i have yet to see the top bar light up...
  9. qbee42
    3,079
    On downhills, speed is a big factor in relation to battery charge. When you descend a big hill at low speed (but still high enough for regenerative braking), it's easy to charge to full green. On a high speed descent, it's not so likely.
    This is because of aerodynamic losses. At high speed, much of the recovered energy is used to push the car through the air. Looking at it another way, if you weren't descending a hill, you would be using a lot of gas just to move at that speed. The energy is used to push air, not charge the battery.
    I saw this a lot on our recent trip out west. In Maple Canyon, it was a 2,000 foot descent to the basin floor, most of which was on a narrow gravel road. I would do the descent at 15 mph, and easily got full green bars every time, finishing the route with heavy engine braking.
    On many of the mountain highway passes I could descend indefinitely without charging to full green, or would hit full green but need only light engine braking. In these cases we were doing 65 or 70 mph.
  10. dagnarus75
    Broomfield, CO
    Thanks everyone for your response!
    firepa63 - I see it fill up all the time when I'm going down big hills, and didn't this time. That is my concern. When I see something all the time, then suddenly it's gone, the change is what is grabbing my attention.
    paprius4030 - Hmm, good idea. I will ask for documentation if this continues. Since my warranty is up in 2 weeks, my main goal in getting it to the dealer was to get it on record that this problem occurred and was reported before the warranty expired. assuming of course that it is a problem!
    narf and john1701a - That's certainly possible. I was at a much higher elevation that I usually am at, hence colder. I will check next time I am at my "usual" downhill full-green (which is also west of eisenhower tunnel) :-D if lower temps bring the green bars faster though, I would think it would refill faster at higher altitude, not slower, right? hmm.
    qbee42 - hmm.. on this same note, I was probably driving slower than normal.. 25-30mph. This would go with that I should also have seen the green bars more quickly, assuming I was going fast enough for the regenerative effect.
    Thanks again to all of you, I knew I could count on good info here. I will be keeping an eye on it on my next mountain trip and will post again if I get any more info.
  11. RicCorless
    RicCorless Junior Member
    Augusta, GA
    Hi Dagnarus,
    On a downhill run, foot off the throttle, there is a fraction of regen braking applied to simulate "lower gear" engine braking in a non-Prius. If you touch the brake pedal, but don't press it to the point of actually applying the binders, then regen braking is maximized and remains so until speed is reduced to the point that adequate voltage is no longer being achieved by the motor-generator to provide recharge current. Under maximum regen braking, the recharge rate is maximized because the highest possible current can be directed to the battery pack. So, in addition to all the other details, keep note of whether you touch the brake pedal during descent or not. If you are on an incline steep enough to use "B", then the recharging rate will be very different than if you are in "D" and touching the brake pedal lightly (just enough to activate maximum regen braking).
    Just an FYI: there are two situations to avoid in order to maximize the lifetime of any rechargeable battery: one is full discharge of the battery, and the other - which is somewhat counter-intuitive - is fully charging the battery. The Prius charging algorithm appears to be designed to avoid either of those conditions in order to provide assurance that the battery pack will last the "lifetime" of the vehicle. I also own a 2000 Insight, and the electronics module on that original U.S. model actually incorporated a design flaw that allowed the battery pack to be routinely fully charged under very conservative driving conditions. Honda identified the flaw and, after more than six years they replaced both the appropriate electronics and the battery pack in my Insight due to early signs of failure of the battery pack. My point is to avoid the pessimism of some folks on this subject. The Japanese aren't ruled by bean counters like American auto manufacturers. You may have to get past that garbage attitude with some dealership employees, but you won't find it when you get high enough to speak with a person who cares about the company reputation.
  12. Norm611
    Norm611 Junior Member
    45
    Western New York
    My experience is that I almost never get a full (8 bars) battery in warmer weather, but get one fairly often in winter.
    My commute to work is 3 miles of suburban driving (about 10 traffic lights, usually get stopped by about 4), then 12 miles of expressway (57 to 62 MPH), then 0.6 miles of suburban streets with one light.
    During the summer, the ICE warms up within a mile or so, so it will shut off at a stop light. The battery usually stays at 4 to 6 bars, and very occasionally goes to 7 bars.
    In cold weather the engine will keep running to warm itself up. I frequently have 7 (green) bars several times during my first 3 miles, with 8 bars appearing once or twice a week. My guess is that MG1 may be used to load the engine (to warm it up faster) with the power going to the battery.
    I first noticed this with my 2005 Pri with the first cold weather Fall 2005 (I picked up the car in May). The pattern of no green in warm weather and frequent green in cold weather continued until I traded the car this August.
    On my new 2008 Prius, I never saw a green battery until we got our first cold weather this fall.
    Norm
  13. grand total
    grand total Member
    154
    ON, Canada
    I think the first sentence says it all. In cooler weather the engine continues running when you are stopped. MG1 is not used to load the engine per se, but is forced to spin (backwards) so that the car can remain still and will generate some power which has to go somewhere. If this explanation is incorrect I'm sure someone else will chime in.
