Can you resist "Reset"
Discussion in 'Gen 2 Prius Fuel Economy' started by Whiteyprius, Nov 3, 2008.
  1. Whiteyprius
    Whiteyprius Active Member
    389
    105
    North Carolina, USA
    Lately (for the past 3200 miles) I've enjoyed watching my mpg's be still for awhile. I know we all shoot for that "best tank," but I sort of got tired of seeing the mpg's jump up every time I'd coast and go down every time I punched it a bit - so I stopped poking "Reset." I've been very pleased that my honest to goodness overall (at least for 3K+) has been 50.4, and has remained that for about a week. My commute is 3 miles - most trips are 15 minutes or less - some weekend travel may include 100 - 200 mile trips. But it's kind of peaceful and gratifying to have that 50.4 sit there on the MFD for miles, and miles, and miles...:D
  2. NoMoShocks
    1,292
    83
    Camas, WA
    It depends on the terrain and how good of a Prius you got. If I could see the mileage settle in at over 50 MPG, I would not reset the computer, but I start going up hill from home and from work, so I like to reset the computer after I get to the top of the hill and see it read over 50 when I get to work. If I let it go for a few days, it will settle in around 48 MPG.
  3. mrblaise
    mrblaise Go Lakers!!
    2,248
    525
    Southern California
    I've reset it so many times now (by mistake) it almost doesn't even faze me anymore. lol
  4. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    We - the drivers of the 2004/05 Prii - don't have a choice. After refilling the tank, the MFD automatically resets after a few rotations of the tires.
  5. NC_Prius
    NC_Prius Member
    186
    Maybe your mpg gauge is broken now. :D
  6. rpg51
    rpg51 Member
    200
    Vermont
    Yea, I'm getting to the point too that I may just leave the MPG readout as is for the long haul.
  7. Mike F
    Mike F New Member
    I reset mine at the begining of January, had a maximum of 60.2 mpg but now the cold weather is here it down to 60.9 mpg.
  8. gdbelden
    gdbelden Gator Hator
    66
    70
    Virginia
    Must be new math....:D
    How can you go from 60.2 "down" to 60.9?
  9. Fibb222
    Fibb222 New Member
    1,499
    99
    My 2004 doesn't, but it's from Canada, eh.
  10. apcpa2000
    apcpa2000 Junior Member
    33
    South Florida
    I have never reset mine since we got ours - over 8,000 miles. Right now its a battle between 52 & 52.1
  11. john1701a
    john1701a Prius Guru
    12,820
    5,305
    58
    1.3 MPG is the margin-of-error, based on my 107,163 miles of data collected (details in my lifetime spreadsheet). That's the difference between what you see on the Multi-Display and what's calculated based on measure at the pump.
    Why resist knowing fluctuations are so small and the value is statistically misleading anyway?
  12. Kcissem
    Kcissem New Member
    Maryland
    No i cant resist to reset, I track my mpg by the tank on a spreadsheet so i have to reset after every fill up just to keep everything standard.
  13. taggart
    taggart Member
    249
    Are you sure about that? I have a 2008 and I swear it automatically resets at every fill-up. Could be wrong.
  14. Freedom
    Freedom Active Member
    540
    73
    Northeastern MA
    I've not used reset since picking up the car Aug 28th. Now closing in on 1800 miles. It bounces between 48.6 and 48.8. I'm happy! :cheer2:
  15. subarutoo
    subarutoo New Member
    1,213
    Chatsworth, CA
    I reset mine 5000 miles ago when I got new tires. It went from an easy 49-50 to 43-44. Oh well. :(
  16. Whiteyprius
    389
    105
    North Carolina, USA
    My miles for that tank resets after fillup, but the avg mpg's keep going.
  17. Whiteyprius
    389
    105
    North Carolina, USA
    Jeepers, what kind of tires did you put on?:eek:
  18. Whiteyprius
    389
    105
    North Carolina, USA
    Great early numbers - keep up the good work!:D
  19. Whiteyprius
    389
    105
    North Carolina, USA
    Not broken - I'm bouncing between 50.3 & 50.4 now:rolleyes:
  20. subarutoo
    1,213
    Chatsworth, CA
    BFG G-Force Sport 205-60 15 on stock rims. As the man says, "Your mileage may vary." Well, mine did. It drives and handles so much better, that I'm OK with it (have to justify it somehow).
