Best sounds for a 2007 Prius?
Discussion in 'Gen 2 Prius Audio and Electronics' started by PriusChick1, Oct 28, 2008.
  1. PriusChick1
    PriusChick1 New Member
    27
    California Beach
    Hi
    Just want to run this by any audiophiles or any one who has done
    a sound mod on their Prius.
    I just purchased a 2007 beautiful Black prius pkg 6.
    only 7000 miles, looks new. It has everything except a moonroof.
    The JBL 9 speaker system is rather mediocre, so i will replace a few parts.
    I received a qoute of 1000+ to install Polk Audio component speakers 300 watts, in 4 doors along with a Kicker amp 350 watt.
    then when i told them my budget was 600. they qouted me 694.
    installed.
    Any thoughts about the price? any better ideas about the same price range?
    I do want to add a subwoofer behind the back seat. would it be cheaper to include this at the same time?
    thanks in advance! :cheer2:
  2. zenMachine
    zenMachine Just another Onionhead
    3,355
    300
    Simply replacing all four speakers with Polk Audio components will not improve the sound. Your JBL "premium" [sic] amp is rigged for Bluetooth, Nav etc. Bypassing it without sacrificing those functions will require major work (and money). My suggestions:
    1. Unplug center speaker (free and absolutely a must)
    2. Replace front tweeters ($100 or less)
    3. Add a self-powered sub ($200 or so)
    4. Don't touch any other speakers
    5. Add sound-deadening to doors and floor if you like ($150 plus labor)
    Of course, everything also depends on what kind of music you listen to and how loud you like your sound.
  3. mycarhasadent
    mycarhasadent New Member
    I agree with zen, defiantly unplug that crappy center channel. And defiantly if you are going to add any speakers, do your self a favor and lay down some fat mat, or dynamat, this is actually something you can do at home, it is time consuming, but easy to do.
  4. EZW1
    EZW1 Active Member
    722
    81
    Phoenix, AZ
    2016 Prius v wagon
    Four Touring
    Can you provide make/model #s for the tweeters and sub?
  5. zenMachine
    3,355
    300
    There have been numerous folks who have replaced the tweeters. There was a thread or two about that somewhere.
    I have some Infinity tweeters in mine (can't remember the model #) as well as some full blown JL ZR components. My set up is quite a bit more complicated than the suggestions above though, so it's not a fair comparison.
    For self-powered sub, many people (including myself) have installed the Kenwood KSC under the driver's seat (or in the hatch box) and found it to be quite satisfactory. Of course, if your car has Nav then you obviously can't fit the sub under the seat. Another one to look into is the Boss BASS600. I have not heard very good reviews of the Bazooka, so I can't comment.
  6. PriusChick1
    27
    California Beach
    Just a quick update about mods to the JBL sound system.
    First I disconnected the center speaker, adjusted the EQ.
    Replaced the tweeters and 4 door speakers with Polk components.
    Added a powered dual subwoofer.
    I couln't stand the sounds before the mod, even after adjusting the oh so simple EQ.
    But thanks to you guys, after reading the threads about the JBL sound system and the integrated Nav, bluetooth, amp, I was able to adjust and actually like the sounds, especially the 6 CD changer . CD's sound better than the FM or XM radio.
    I have a MTX self powered dual subwoofer that's small but MIGHTY! It Rocks! amazed now at the sound quality without adding another amp to the door speakers. Lots of highs midrange and of course bass. I did my research about subwoofers and space . Difference with sealed subs and port subs,
    I was going for quality rather than loudness. But this system now is plenty loud.
    The only question is, does anyone know if there is a higher watt replacement amp for the current amp that powers the Nav, and bluetooth? I don't want to lose any functionality,would like a stronger amp to push the new speakers.
    Has anyone checked with the Toyotadealers? don' t really want to pay the priceydealer costs though. any suggestions? the dealership wanted 900 for a XM tuner labor/product. Everybody else under 400. So I don't want to check with them
    about replacing the current dedicated amp :(
    Any suggestions?
  7. Weirdo23
    Weirdo23 Junior Member
    28
    Washington
    PriusChick1,
    I don't think such a beast exists. These amplifiers are very specific to the vehicle/manufacturer line and you already have the top of the line or "premium" amp. It's not difficult, per say, to add an aftermarket amp to the system from an installer's standpoint, but if you want to do it right, it isn't cheap. As I'm sure you've seen in your research, many owners opt for the JL Audio Clean Sweep product. I went with the Rockford Fosgate 3Sixty.2 integration device. After a lot of research and some experimentation I cut all the speaker lines from the premium amp and rerouted the rear speaker outputs to the inputs of the 3Sixty. From those two inputs it gives me L/R Front, L/R Rear, Sub and Center outputs. The whole system is controllable via pc, pocket pc, or a palm device via bluetooth. The front left woofer output from the premium amp is now routed to the center speaker so I still have all original audio from the NAV system and bluetooth phone handsfree operation. By using the fader control in the audio menu on the MFD and sliding the output all the way to the rear I don't get any music from the audio system coming out the center speaker. Both bluetooth handsfree audio and NAV audio have thier own volume level selections on separate menus of the system. A good installer should have little problem making these alterations. You'd still need a 4 channel amplifier to add some power to those components though.
    The budget route, however is to put a LOC (line output converter) on the full range rear speaker outputs of the amp, and split that stereo signal to a four channel amp.
    Hope this helps. Let me know if you have any other questions, I've spent a ton of time researching this topic.
    Weirdo
  8. emtownsend
    emtownsend New Member
    111
    Post Falls, ID
    Sounds incredible! I'm afraid to ask.. but... I have to... How much did all this work & product set you back?
  9. patsparks
    10,664
    569
    Adelaide South Australia
  10. Weirdo23
    28
    Washington
    How much did it set me back or how much will it set me back :) I've just started so right now the costs are still low. The RF 3Sixty.2 was around $500. I bought it from al-eds.com. It lists for $599.99 but the code google20 will save you 20% which brings it down to $479.99. Al-Eds is one of a very few authorized internet dealers so you still get Rockfords warranty. It can be found at other online dealers for less ($399),(Rockford Fosgate 3SIXTY.2 ( WITH 2 IN MODEL ) (3sixty2-TWO) Equalizers Sound Processors Car Audio and Video - Sonic Electronix) but you are not getting the manufacturers warranty. Besides a few crimps and parts, that's all that I've spent so far. For now I'm using a pair of Orion components in the front doors, rear doors are disconnected and I have an Orion enclosure with 2 Orion 10" subs in it all driven by an Orion 4 channel amp. However, future plans include:
    JL Audio 300/4 V2 Amplifier
    JL Audio 500/1 V2 Amplifier
    JL Audio XR650 CSi Component Speakers
    JL Audio CVS110RG-W6v2 ProWedge Subwoofer.
    Not to mention the 4 and 8 gauge wiring and RAAMaudio sound deadening material I'll need to finish it all up. I'd say I have at least $1500 to go :) May take a while, but at least I'm not paying anything for installation!!
    Weirdo
  11. jorgeez
    jorgeez New Member
    121
    You can't go wrong with Polk Audio speakers. Sound clarity is good.
