Wheel bearing out?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by gene4655, Nov 5, 2008.
  1. gene4655
    gene4655 Junior Member
    51
    Scraping noise when I slow down and turn left. Shop says it is a wheel bearing out, and even though it's an '03 with 39,000 miles, it is under warranty. Anybody else have this problem? (And even before I found out it was under warranty, have to confess that the service technicians at McKinney Toyota in Ft Worth are the friendliest, most helpful I've found anywhere!)
  2. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    It has been known to happen early. Like most modern vehicles, the bearing is a sealed assembly and cannot be repacked. It must be replaced
  3. VTMRGRTVL
    VTMRGRTVL New Member
    24
    Grand Isle, Vt
    My '04 had the right front wheel bearing go at 45k miles. The dealer took care of it under warranty...
  4. Guilt Edge
    Guilt Edge New Member
    Welland, Ontario, Canada
    The left front wheel bearing also went on my 2005. 176 000 km (approx 110 000 miles). At first I thought it was an alignment problem, and so did the dealer.
  5. Devil's Advocate
    922
    Las Vegas, Nevada
    05 front left went out at 95,000. Helped along by a curb impact I think. The rest are still OK at 163,000. Replaced it myself for about $150 for the part from Hoy Toyota in TX about a year ago.
  6. tochatihu
    tochatihu Senior Member
    9,852
    3,814
    Kunming Yunnan China
    2001 Prius
    Prius fronts are cartridges that just need to be pressed in (slightly underestimating the work load there). For the rears, the whole wheel hanger assembly gets swapped.
    We usta imagine that some of them got hurt on the boat ride over. If such did not occur, them expect them to last a very long time.
  7. Priusaurus110
    Priusaurus110 Junior Member
    31
    Monument, CO
    I've had same symptoms (and so have others in this forum) with a small pebble that got lodged in the brake rotor. Is the shop absolutely sure about the bad bearing? Did they remove wheel and brake and confirm you have no rocks caught against the rotor?
    Just a thought...
