Rusted hose clams
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by FishHawk, Nov 10, 2008.
  1. FishHawk
    FishHawk New Member
    176
    Rusted hose clamps
    I have noticed that my hose clamps have rusted. Should they be replaced or will they be ok. My dealer has not mentioned this so I guess everything is fine. FishHawk
  2. qbee42
    3,079
    If you have hose clams, you must park your Prius under water. Maybe you'll find some pearls! :D
  3. EZW1
    EZW1 Active Member
    722
    81
    Phoenix, AZ
    2016 Prius v wagon
    Four Touring
    If they're rusted quite badly, I would be thinking about replacing them. Some day they may fail. What I would do if you do replace them, is buy the ones that tighten using s screwdriver, not the ones you squeeze with a pair of pliers. The screw-down ones can be completely opened up, passed around the hose, then re-threaded and tightened. This way you don't have to remove the hose to get the new clamp on.
  4. qbee42
    3,079
    To add to the screw clamp suggestion, I use clamps that are fully stainless. Most stainless steel hose clamps use less noble screws, which ultimately rust and fail, even though the clamp still looks good. In marine applications we always double clamp with fully stainless clamps. Popping a hose in a boat can make for a really bad day.
  5. Patrick Wong
    18,200
    6,501
    If you have more than 100K miles on the car, I suggest replacing the radiator hoses and clamps.
  6. jpadc
    jpadc Type before I think too often
    343
    34
    Indianapolis and Northern Wisconsin
    2017 Prius Alpha
    At 100K on any car its time to replace belts and hoses. Replace them all including the clamps (check the clams for pearls) and make sure to check all new parts for defects. Buy quality parts - but verify!
  7. Rest
    Rest Active Member
    1,210
    CA
    Many auto parts that get rusted don't have to be replaced, at least not right away. But don't rely on your "Stealership" service department to keep you informed about its condition. Keep any eye on it yourself.
  8. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    rusted clamps are ok.
  9. FishHawk
    FishHawk New Member
    176
    Re: Rusted hose clamps
    Thanks galaxee , they are not that rusted , the car has 45K miles on it and it's probably cosmetic. FishHawk
  10. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    I have not noticed any rust, are you in a high humidity or ocean area?
