Glue suggestions
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jfschultz, Mar 26, 2005.
  1. jfschultz
    jfschultz Active Member
    639
    115
    Germantown, TN
    2020 Prius Prime
    I am having a rattle problem in the upper glove compartment. It appears to be my wife's sunglasses case on the little shelf. A felt liner on the shelf should do the trick, but how to best glue it to the shelf with the heat and all?
  2. bshef
    bshef Active Member
    510
    76
    OC So. Calif.
    why not glue it to the $10 sunglass case?
  3. prius mdt
    prius mdt New Member
    25
    Richmond VA
    try a craft store - see if they have a sticky backed felt sheet you can buy. If not, use a spray on contact cemet. 3M makes one used in upholstry work. You spray it to the tray and to a sheet of felt - let both pieces dry (almost completely) and then stick the felt to the tray. Trim off the excess around the tray and wala...
