Help on Rims: size question
Discussion in 'Gen 2 Prius Accessories & Modifications' started by prius168, Nov 11, 2008.
  1. prius168
    prius168 New Member
    Southern California
    Would 17x7.5 rims fit on the prius? What tire size recommendation would I go with on this set up? Any help is greatly appreciated.
  2. PA Prius
    PA Prius Active Member
    762
    251
    SE Pennsylvania
    I don't know about 7.5", but a quick look on tirerack.com shows that 17"x7" will fit, and using 205/45 x 17" tire. Look further on tirerack and you may find 7.5"
    Your investments must be doing better than mine!
    PA P
  3. mrplease
    mrplease New Member
    51
    oklahoma city, ok
    yes 17" x 7.5" wide rims would work
  4. maido
    maido New Member
    Osaka, Japan
    My friend has 17x7.5 wheel on his PRIUS,
    with 215/45-17 tire.
    ^0^
  5. VipAutoSalon
    VipAutoSalon Pursuing Perfection
    Torrance
    Agreed 17x7.5 with a 215/45/17 tire will fit but please dont forget about the wheel's offset
  6. mrplease
    mrplease New Member
    51
    oklahoma city, ok
    agreed. offset is very important. it doesn't have to be precise on a 17" or 18" on the prius as to other applications though, but it needs to be in a general vicinity. like my cts, i have 22's and its such a precise fit that even a little off will cause problems. i run a +40 offset on my cts and even a +38 will not work w/o modifications. but on the prius if your running a 17" rim you could probably go within -10 to +10 without any problems. it just matters how flush you want them to sit.
    also 205/45/17 would be the closest overall height to the stock tires.
    stock tires are: 185/65/15. which gives the overall height of 24.47"
    205/45/17 would give you an overall height of 24.30"
    and the 205 width is ideal for a 7.5" rim
  7. prius168
    prius168 New Member
    Southern California
    Thanks for all the information everyone. The wheels I'm looking at has an offset of +48. Will that work?
  8. mrplease
    mrplease New Member
    51
    oklahoma city, ok
    yeah that will def work.
    mine are 18 x 7.5 with a +50 offset.
  9. prius168
    prius168 New Member
    Southern California
    Would I be able to use the existing TPMS? Thanks for all the help guys.
