Mileage significantly decreased
Discussion in 'Gen 2 Prius Technical Discussion' started by Phyllis06, Nov 20, 2008.
  1. Phyllis06
    Phyllis06 New Member
    Wisconsin
    I have a 2006 Prius with a little under 58,000 miles on it.
    I have the oil changed every 3000 miles.
    I put new tires on it last winter and have them rotated every 9,000 miles.
    In the last 4 months I've noticed my mileage has decreased some 4-6 miles per gallon.
    Does anyone have any idea why this would be the case?
    Could it be something as simple as needing to change the air filter?
    Not sure when I last had that done.
    Thanks for any help!
  2. JSH
    JSH Senior Member
    2,605
    140
    PDX
    Changing the air filter would be a good start, especially since your don't know when it was done and you aren't following the recommended service intervals from Toyota.
    My advice: Don't have this done, do it yourself and save $$$$. An air filter costs ~ $10 and is the easiest thing on the car to change.
    Open Hood
    Find air box (It will be a rectangle shaped box on the passenger side of the car)
    Undo 4 hooks
    Lift off airbox cover
    Take out old filter
    Put in new filter
    Put airbox cover back on
    Latch 4 hooks
    Close hood
    It literally takes 2 minutes at the most.
  3. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    Usually mileage drops are caused by the colder weather. Also, if your use has changed to include a lot of short trips in a cold car it will really drop the mileage. It goes back up when the weather gets warm again next spring.
  4. Rokeby
    Rokeby Member
    3,033
    710
    75
    Ballamer, Merlin
    Phyllis06,
    Welcome to PriusChat.
    Posters have reported that sometimes, especially in you drive in a dusty
    area, the inside of the throttle body gets dirty enough to negatively affect
    mileage.
    It's not all that difficult to clean it, but there is the chance that you can
    goober up one of the computer sensors in there -- air mass sensor?
    I'm no expert here and I'm hoping that one of the engine smart folks will
    come up and complete this idea; how to do it right, what to avoid, etc.
  5. justlurkin
    justlurkin Señor Member
    499
    63
    Long Island, NY
    Phyllis,
    Another tip to save you some money.. You don't need to change the oil every 3000 miles. Every 5000 miles is what the scheduled maintenance booklet specifies. :)
    It makes sense-- Unlike a regular car, the Prius engine isn't running all the time the car's in operation, so you don't need such frequent oil changes.
  6. Phyllis06
    Wisconsin
    Thanks to everyone who has responded.
    I understand that the mileage will drop during cold weather, but the drop was before that.
    I have had the car since Jan. of 06 so this is definitely something new.
    I was taking the car into the dealer for oil changes and service up until 20,000 miles or so. Since then I've been taking it in for oil changes to a local place for about half the price.
    I know I don't NEED to change the oil every 3,000 miles, but as my Father told me when I first began driving in '65 and he taught me to change my own oil. Oil is cheap so change the oil and filter every 3,000 miles so your engine doesn't ever have to over work due to dirty contaminated oil.
    I have occasionally gone closer to 5,000 miles between changes but I'll keep changing every 3,000 just for the heck of it.
    I figured I would change the filter myself, just wasn't sure if that could be the problem like it tends to be in regular engines. It's probably been close to 20,000 miles since it has been changed.
  7. Patrick Wong
    18,210
    6,526
    Hi Phyllis,
    Sounds like you will need a new engine air filter, but I doubt that would cause the specific mpg problem that you have noted. If nothing obvious is found, I suggest that you have wheel alignment checked and ensure the parking brake is not dragging the rear brakes. Good luck.
  8. Ogo
    Ogo Prius Owner since 2008
    220
    44
    Ilirska Bistrica, Slovenia
    Changing engine oil every 3000 miles is basically very stupid. You waste money and time, you increase pollution and basically do not do anything positive for your car. We are in 2008 and not in 1965 anymore. Both engines and oil formulations have evolved significantly over last 40 years. You will do much more by keeping your tires properly inflated than with premature oil changes.
  9. Phyllis06
    Wisconsin
    Ogo,
    Thank you so much for your kind words!
    When I purchased my Prius in Jan. 2006 I specifically asked the head of the service department how often I should change the oil.
    He said anywhere between 3 an 5,000 miles. The more often the better for the engine.
    Though I guess I should consider that he just wanted to sell me more service.
    As for keeping my tires inflated properly, I do so.
    My father was a truck driver, oil and gas delivery when I was a teen. He repaired all our vehicles. We were not allowed to leave the driveway until we could change a tire alone, change and check the oil, check the tire tread and tread wear pattern and pressure, remove the air filter, know where the choke was ( I know, can't do that anymore) know how to jump start a car, etc.
    I do however appreciate being called stupid by you.
    Blessings!
  10. richard schumacher
    7,686
    1,068
    United States
    How often do you check the tire pressures? Under-inflated tires are probably the single biggest waster of fuel. They should be checked at least monthly.
  11. mingoglia
    mingoglia Member
    846
    Gilbert, AZ
    First you have to keep everything in perspective. A Prius can get around 50mpg. What you're experiencing is about a 10% drop. In a "normal" vehicle you may barely notice the 10%... it's magnified on the Prius.
    With that being said, it's easy to "lose" 10% of your fuel economy.
    1) Low air pressure. Tire pressure "leaks out" continually. It's slow, but it happens. This is why you have to check your pressure somewhat regularly. This problem is made worse by the lower temps. The lower temps also lower pressure. Combine the two, and you could be down 10lbs very quickly. This is the number one reason for bad economy.
    2) Cold temps in general. All modern car's computers priority is to bring the engine up to temperature. This is for emissions reasons primarily. The catalytic converter has to stay hot in order to work. In all cars (the Prius included), the engine will run richer to facilitate this. The Prius has one more thing against it. In order to generate this heat, the engine will be running in situations where it might not run in warmer weather...reducing fuel economy.
    3) Over-filled oil. This seems to be observed more in a Prius than other vehicles. Again, it's probably because it's relative to the overall MPG a Prius sees. A few percent difference is not only measureable on the Prius, it's right in your face.
    If I were to speculate about your latest oil change for a moment... I've found in the past (do all my own service now) that the oil change places typically check the dipstick and call it "good enough" when doing oil changes. This good enough could be a bit too high. These service centers also check the tires. I can picture them adjusting them down to 30psi. Many places don't check/know what pressure the tires should be at so they automatically adjust them to either 30 or 35psi (although some fill up to the max rating). If your tires were warm heading in and they adjusted them, this too could bring them down to below optimal for the Prius.
    There's a very good chance your tire pressure is low, your oil level is too high... and the ambient temperature outside is causing this 10% drop that you're experiencing.
  12. hobba
    hobba New Member
    85
    Estero, FL
    All the suggestions listed above are good ones. With the age and mileage on you car, you might was to get the fuel injection system cleaned. Dirty or clogged injectors can diminish gas mileage. It takes about an hour at your Toyota dealer.
  13. morpheusx
    morpheusx Professor Chaos
    1,555
    81
    Akron, OH
    Nobody has mentioned that perhaps they put a thicker viscosity of oil in last time you had your oil changed, or even overfilled.
  14. bat4255
    bat4255 2017 Prius v #2 and 2008 Gen II #2
    670
    269
    Dodge Co. Wisconsin
    2017 Prius v wagon
    I would not be surprised to hear of a large % drop.
    The cold weather, 10%-20%
    10% winter blend fuel
    10% low tire pressure
    Short trips 10%-20%
    As others mentioned, ck tire pressure, and filters.
  15. Phyllis06
    Wisconsin
    mingoglia, hobba, morpheusx and bat,
    Thanks for all your comments.
    Probably the decrease in gas mileage this year is not as drastic as I thought it was from last year at this time. Probably closer to 3-4 miles per gallon decrease over previous years during colder temps.
    I became the most concerned because generally I get 47-49 mpg on my frequent long trips to AR. But this time the mileage was 42 mpg's.
    I checked the air filter and it is somewhat dirty so I will definitely replace it, and even though I had the tires rotated prior to my trip with them checking the pressure, I'll check it myself to make sure it is OK.
    I ride a Harley and must check my tire pressure frequently so I tend to do the same with my car. Though I did not do so before or after this last trip.
    On the way down there was quite the headwind so I attributed the terrible mileage to that. Started out at 49, finished the 693 miles at 41.
    I reset it when we started back, and still only got 42.
    Generally around the area, we live outside of town on a hill, I get 47-48 mpg's. Getting 43 now.
    I'll change the air filter and check the tires today. Hopefully one of those will help.
    Thanks again!
    Blessings to you all.
  16. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Some have noted issues with the mass air flow sensor, which is a "hot wire" meter. You require a special cleaner to clean this, otherwise you risk ruining it
    My FJ Cruiser needed the mass air cleaned. I noticed the fuel economy slowly declining over summer. Picked up a can of CRC Sensor Kleen for under $6, the FJ mass air meter was dirty.
    CRC Canada > Product Catalogue > Automotive > Cleaners/Degreasers > SensorKleen?
    There appeared to be a light ash residue on the two hot wires. The popular theory is that routine operation of the PCV introduces oil vapor into the intake manifold, which when it lands on the mass air wires turns to ash. I've posted photos of the before/after
    There was a big difference in my FJ. I cleaned my Prius and there wasn't any difference. The dealer cleaned the MAF last year, so maybe it wasn't that clogged
  17. abishai100
    abishai100 New Member
    Vermont
    This sounds like a problem. I know when I shop for an Earth-friendly car, I look for mileage, warranty (if it's used), and engineering.
    I think some of these other posts are accurate. I would consider writing in to the manufacturer and ask them how common this problem is and then post here what their response was.
    God bless!
  18. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    I like your Father, he taught you well.
  19. joanjenn@embarqmail.com
    [email protected] New Member
    Virginia
    I have a 07 Prius and it has lost mpg too- this is WInter but it did the same in Fla when I was there. Have recently had new tires on at dealer and oil change and then is when the lower avg milage is showing up- goes like 43 avg instead os 50 and 60's. I have been back to ask and they checked tirepressure and said it was not that and it was probably WInter. I am not sure who to believe- does anyone know also about the 30,00 mi very expensive general checkup Toyota recommends? General things like tires, oil, brakes , fluids and so on for over $200. Is this necessary? I really like my Prius but am not sure if anything is wrong or not with this big drop in milage. Thanks, Joan
  20. danl
    danl New Member
    231
    Boston, MA
    What do you guys recommend for tire pressure?
