NEW (old) Prius - help me get it home!
Discussion in 'Generation 1 Prius Discussion' started by kuwona, Nov 15, 2008.
  1. kuwona
    kuwona Junior Member
    24
    Near Philly 08033
    2002 Prius
    Hello Prius People -
    I just bought a 2002 Prius. It was listed a few times on eBay (examples: item 250317616362, and 250322314503) with no buyers at BIN $4500. I offered the guy $4000, and he accepted. It's still in NYC, 100 miles from where I live in NJ. When I took it for a test drive, it stopped running at a red light, would only start and run for a few seconds, and eventually would not start again at all. The seller brought another small battery (the little regular 12-volt job that lives in the trunk) and it startted up again.
    Can I drive it home?
    I now have both the small batteries charging at my house. If I take them up to New York tomorrow, will I be able to drive back home even though the main battery is "dead?" I know you guys will ultimately have advice for me about how to diagnose/repair/replace/etc the main battery, but for now, I just want to know if there is a chance I can drive - rather than tow - the car home.
    I'm looking forward to your thoughts and I hope to make this site a regular hang-out as I try to get this car back on the road as a daily driver.
    Thanks so much in advance,
    GW
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    100 miles...might as well try.
    I'd suggest having a back up plan (ie. a ride home). The closer you can get the less expensive it will be to tow.
    You should be able to find a salvage battery and have it installed for less than $1000. A brand new battery will be around $2300 + installation.
    Hope that's all that's really wrong with it...it seems odd though, one would think the original owner would have had the battery replaced and been able to get a lot more out of the car.
    Hope it works out well for you, but there are red flags flying up all over the place.
  3. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    Welcome, neighbor. Since this is a done deal I'll save the advice/lecture about the car. IMO the most harrowing part of the trip will be through NYC. Although I hate the tolls in this case I'd make an exception and take the Turnpike home. (I take US130 to US1&9 when going into NYC). Take the Car lanes and stay in the right lane. If the traction battery is shot I'm not sure how effective two 12V batteries will be. Sign up for AAA & take the plan that provides unlimited free towing.
    You have embarked on a noble quest. Good luck.
  4. Patrick Wong
    18,210
    6,511
    Hi GW,
    What is the greatest distance that you have driven the car so far, during your test drive?
    Do you have a digital multimeter available to you? If so, measure the voltage across the installed 12V battery when the Prius is READY. The voltage should be 13.8VDC, which shows that the DC to DC converter within the inverter is doing its job maintaining correct voltage on the 12V bus. If the voltage is much lower than that, then the inverter has failed (which by itself is a 4-digit repair unless you can find and install a salvage unit). This means that 12V power is being provided by the little battery, and the car will stop running once that battery is out of power.
    Carefully note the 12V battery polarity and make sure you do not reverse battery polarity when installing/reinstalling the batteries. That is an almost guaranteed way to destroy the inverter.
    Since you know that the traction battery (main battery) is "dead", you may notice significant driveability problems assuming that the car will even run. It is really questionable whether you will be able to cover a distance of 100 miles without using a tow service, so have your cellphone and credit card available for that eventuality.
    Good luck with your efforts to transport your car to your home.
  5. tochatihu
    tochatihu Senior Member
    9,850
    3,806
    Kunming Yunnan China
    2001 Prius
    it does appear that this one will need more than a little repair work. I'd begin by towing it home with a front axle dolly. I suppose that the one way rental fees will be less than you'd pay for a roadside tow. Plus, if the inverter/converter is not cooked yet, you don't want to push it closer to the edge by more time in 'limp home mode'
    Let's get this phase 1 behind us quickly and then focus on saving the patient. Good luck.
  6. thedutchtouch
    thedutchtouch prius is my SUV
    181
    Baltimore MD
    get a AAA plus membership. free tow.
  7. bwilson4web
    16,330
    Although a little pricey, check "U-Haul" as they have small trucks that can tow a full-size, flat trailer, that can carry a car. It is pretty expensive but possibly cheaper than a commerical tow.
    Do you have access to a vehicle that has a 2" ball? If you can keep the return drive at under 45 mph and buy a Harbor Freight tow bar:
    GOOD LUCK!
  8. kuwona
    24
    Near Philly 08033
    2002 Prius
    Hi Guys -
    Thanks for all the advice. I ended up towing it home yesterday. I had considered trying the drive and planning to call AAA if/when it broke down, but that would have meant a significant delay while I get it tagged, insured, registered, etc. And even then AAA says they won't tow it if it's not inspected - which it's not....
    Well it's in the driveway now.
    I have to catch up on some schoolwork this week, but I will be looking for "what next" tips for this coming weekend. I will take patrick's advice and test the inverter as he recommended above. I'll let you know what I find.
    But I guess the first step is getting it titled. While I'm almost positive Toyota won't help me, I should at least ask, right? Does the cars accident history void the warranty? Are there any bulletins or recalls I should know about?
    JimN - you live in SoJo! That's great. I'm in Haddonfield. If you are nearby, maybe you can help me not electrocute myself when I pull out the traction battery.
    Thanks again Prius friends,
    GW
  9. JimN
    7,028
    1,117
    South Jersey
    I'm an accountant not an electrical engineer (in Cinnaminson). Take your title, receipt & checkbook to the MVS office in Mt. Holly (next to Staples) during the day as the evening hours were cut. You'll have to pay the sales tax on the purchase price. Here's their website: State of New Jersey - Motor Vehicle Commission and it might be worth calling or visiting them regarding any questions about your particular case. No DMV jokes as you'll be on the road longer than you will be IN the MVC office.
    I would suggest contacting Oliver Perry, President of the local EV club. His address & phone number are listed in the 2008 newsletter available through the club's website:
    Eastern Electric Vehicle Club
    He's a retired HS Physics teacher and is part of the team that built the electric Escort. If you make contact you can mention that I sent you. Never hurts to ask for advice, shop time & help.
    Good luck.
  10. kuwona
    24
    Near Philly 08033
    2002 Prius
    Maybe I should change the title of this thread. Or I guess I could think of "Home" for this car as "on the road" in which case I still need help getting it home.
    I went to the DMV this morning and got a title, tags and registration. From there I went to the dealer to get the service history and ask about the warranty. There was a recall service done for the crankshaft position sensor and one for the HV battery modification - both from November 06.
    Also at that time the dealer "could not confirm" the customer's "shaking on turns" problem.
    And here's the part you have all been waiting for. This is from 08/04/08. (I'll print in all caps since that's what the service history does and it adds to the effect)...
    CUSTOMER STATES WHEN HE PUTS THE CAR IN DRIVE IT TURNS OFF (SPEAK WITH ADAM) ~|~ BATTERY TERMINALS WERE JUMPED BACKWARDS, BURNT COMPUTER, INVERTER ASSEMBLY, VOLTAGE COMPUTER. RESET ALL SYSTEMS ~|~ROAD TEST OK AT THIS TIME, STILL HAS LIGHT MAIN BATT LEAKING CODE, ADVISE THE CUSTOMER SAME
    Now I'll go out and use Patrick's technique to confirm the inverter is not doing what it should. But it sure sounds like I am in for an inverter and/or computer, a traction battery, and a steering rack plus labor - all on my own dime.
    It sounds like I can get a used battery for around $500, and do the labor on that myself.
    How about the inverter? How can I get one, and how hard is it to remove and replace?
    Thanks again guys,
    GW
    PS - JimN - Thanks for the contact. I'll plan to get in touch with Oliver.
  11. Patrick Wong
    18,210
    6,511
    Hi GW,
    What does "RESET ALL SYSTEMS | ROAD TEST OK AT THIS TIME" mean? Was it possible to drive the car?
    Please measure the voltage across the 12V battery, both when the car is IG-OFF, and then when it is READY. What voltages do you read?
    If the voltage when READY is 13.8V, then the inverter might be OK. Is it possible that the inverter had already been replaced in August?
    If it is necessary to replace the inverter, this is not too hard to do. For salvage parts sources, try a Google search. The part number has evolved over time, so you will want a part number which is the same as your existing unit or higher.
    Regarding the traction battery and inverter replacement, you really need to obtain and read the Toyota repair documentation, at techinfo.toyota.com
    This will help you to correctly and safely perform those repairs. Good luck.
  12. kuwona
    24
    Near Philly 08033
    2002 Prius
    And here are the voltages from the little battery...
    After charging out of car over night = 13.06
    Installed with car "ready" and running = 12.02
    10 minutes later, still running = 11.86
    Need an inverter?
  13. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    it sounds like you need an inverter.. or... a fuse is blown to the one you have? either way, your battery voltage should never drop when the car is on.. dead battery or not (mine dies if i don't drive it for a 24hour period.. the 12v is that dead.. but i still get high voltage when in ready mode from my inverter... which.. i figured i should have damaged by now...)
  14. bwilson4web
    16,330
    You need to check "F10 FUSABLE LINK BLOCK NO. 1" that connects the inverter/converter output pin "AMD" on pin 1 of connector "B". This should be a "white" wire. This fusable link is located in the fuse assembly on the driver side.
    The connector is "I12" and the converter feeds "pin 1". I12 is described as 'gray' and has two rows of eight pins. Pin 1 is closest to the latch side and inline with the key slot that is found on the opposite side of the connector.
    Replacing the inverter would be an expensive way to test the fusable link. Past reports have suggested this is not a trivial part to replace.
    Let me suggest you first get access to the maintenance manuals. Then we can cite specific sections that apply.
    BTW, your battery looks 'weak' but understandable. But if the 12 V converter power is not available, it won't run long.
  15. kuwona
    24
    Near Philly 08033
    2002 Prius
    Thanks guys -
    I'm pretty sure I have found the fuse box I should be looking at (engine compartment - right side). But I don't know how to ID F10, Block #1, AMD, Pin 1, connector B or I12 without the manual.
    Which manual should I be looking for? Is it the 3 volume deal from Toyota? Does Amazon have it?
    Does anyone have a picture showing the location of the fusable link I am trying to find?
    PS - I bought a used battery for $450.
  16. Patrick Wong
    18,210
    6,511
    The used battery price is good if the battery is functional.
    techinfo.toyota.com will have the electrical wiring diagram for your vehicle. I suggest you start by downloading that; much faster and cheaper compared to buying the paper manuals.
    I do not know where the fusible links are located within the Classic relay/fuse box next to the inverter. The 2G relay/fuse box contains a 5" long white and clear plastic box where the fusible links are located.
    If you can locate the DC to DC converter output terminal that Bob listed (AMD) then you can measure voltage there to see if it is the same as the voltage measured at the 12V battery. You will need to refer to the repair manual to identify connector and pin designations.
    If yes then you can assume the fusible link is good. Then I would say the inverter definitely needs to be replaced.
  17. kuwona
    24
    Near Philly 08033
    2002 Prius
    Okay guys - Here's an update...
    I took it to my local dealer to see if there was anything they could do under warranty. Of course they couldn't/wouldn't.
    They got the following codes:
    P3000 (Battery Control System)
    P3125 (Inverter Malfunction)
    The mechanic said P3000 is a general code, and p3125 specifies the inverter. I'll add that the three miles to and three miles back from the dealer were the longest I have driven the car. It drove normally although the steering wheel does have the feature that fancy video games have where it vibrates like there is an earthquake in low speed turns.
    The mechanic said he did not get any codes for the battery. He also pointed out that the coolant had leaked out of the Inverter reservoir. Since the bodywork was done by Dodgy Brothers you can see damage to the driver's side frame rail in the neighborhood of the coolant pump. His hypothesis is that the crash damaged the cooling system for the inverter and that - not a reverse polarity jumping scenario - is probably what caused the failure.
    So my current mission is to replace the inverter and diagnose and repair the inverter cooling system. Any tips?
    I also have an extra traction battery. Whoops.
    Also, is it good or bad form to post new questions in the same thread as I get further into this car? Should I post a new Thread called "How do I replace the inverter?" Or is it better to keep everything about Operation Priustein's Monster in one place?
    Okay guys thanks for all your help.
    Patrick - When I sign up for techinfo.toyota.com, will I be able to download pdf files or is it set up to limit your access to information to the period of your subscription? Would I be able to just pay 10 bucks and have an all-you-can download buffet? (In case it's not obvious, I'm a full-time student... no income). I have been downloading all of the unofficial manuals and info I can find, but of course most of it is for the current generation prius.
  18. patsparks
    10,664
    567
    Adelaide South Australia
    What I can't work out is, if the main traction battery is knackered, what is starting the ICE?
  19. Patrick Wong
    18,210
    6,511
    Regarding techinfo.toyota.com, your access is limited to whatever subscription period you choose. It is not easy to download a repair manual for a particular model year since there are indeed hundreds of .pdf files to contend with. If you pay $10 on a Friday you may have access until Monday as I think the timer is based upon business days. Or if you pay $50 then you will have access for a one-month period, which perhaps may work better for you.
    I suggest you download the electrical wiring diagram and the repair manuals for your model year, plus the New Car Features Manual for 2001 plus 2002. The latter will give you theory of operations not found in the repair manuals.
    DTC P3000 "Battery Control System Malfunction" - either the traction battery, or the traction battery ECU is bad. However this DTC can also be produced if you were out of fuel.
    The steering wheel vibration implies a problem with the electric steering gear, which is another ~$1,000 repair or so if you buy a new part and install yourself. The problem is noisy torque sensors which provide bad signals to the steering gear ECU.
    The inverter cooling system is pretty simple: coolant flows through the inverter and transaxle, and is pushed along by an electric pump. Hopefully you will be able to see where the leak is coming from. It is not easy to purge air out of the system, refer to the repair manual for details.
    Perhaps you are starting to see how this car may become a very big project with respect to both time and money, hope that you have the funds and time set aside.
    I suggest you continue to post your questions within this string for now. Good luck.
  20. kuwona
    24
    Near Philly 08033
    2002 Prius
    Hi Guys -
    It's been a slow process so far. I've been busy with mostly schoolwork. Here's what I've done since the last post...
    I took Patrick's advice and went to techinfo.toyota.com. WOW! Great site. They do make it so you can't just click "download everything" or anything like that, but you can download PDF files individually, and I went through and downloaded a lot during my brief membership.
    Using that info, I uninstalled the inverter/converter and replaced it with one from eBay. I tried to bleed the cooling system and I think the air is all out but the coolant will not pump through the system. I'm trying to figure out why not.
    I took the pump out and tested it in the sink. It pumps okay with its inlet submerged in the sink.
    I did notice that the old coolant was thick, which seemed odd. I drained it out, but not completely. I flushed the HV radiator (only - not the coolant passages in the inverter), and put everything back together. The hoses going to the pump and coming from it are now full of clean looking coolant.
    When I run the pump (key in "on" position), I hear it/feel it running, but no coolant flows into the reservoir. The system is filled to the correct level.
    My next guess is that I need a pump. Maybe the sink test is not adequate for actual performance?
    I'll also add that after I got frustrated with the pump not pumping, I wanted to see if the eBay inverter worked. I turned the car on. The ICE ran for about 15 minutes. I revved the engine a bit at the end to see if anything was leaking (not that that would help me determine that). It's about 25F here today. I verified with the car "ready" both during ICE operation and after that the voltage at the aux battery was 13.84. Car off voltage is 13.04. I think that's good news.
    But what about the pump?
    GW
