Possible battery degredation?
Discussion in 'Gen 2 Prius Technical Discussion' started by whiten, Nov 22, 2008.
  1. whiten
    whiten Junior Member
    Littleton, CO
    I have a 2005 Prius with 91,000 miles. I keep reading online how Toyota says their batteries aren't degrading with cars up to 200,000 miles.
    But I believe that mine is wearing out. For example, my 33 mile drive one way to work has me drop in elevation about 1000ft in the last 10 miles. Most of that drop comes in a stretch between miles 22 and 28. The last 5 miles has only about 200 feet of elevation change. (See the attached pdf file.)
    In the early days of my drive, the battery would go fully green on the big hills down to work, and I could make it to work still with all bars green.
    But now, one new symptom is that the motor starts to run at the bottom of the big hills (there's a light at the bottom that many times I have to stop at). I'll have all bars green, and the motor starts while I'm stopped and sometimes winds up to fairly high RPM. I'm thinking the computer is trying to DEPLETE the state of charge because since capacity is down, it's overcharged.
    When I get to work now, it's almost NEVER still fully green. I'm still at the top of the blue, but rarely green.
    Finally more to the point, when I leave work, the first 1/2 mile is nearly flat, and yet I fall from the top of the blue to 2-bars purple and the engine is running already charging at a light there where I need to stop at most of the time (even in warm weather where it should could be off except for low state of charge). Yes, I know the car is running hard from start up to warm up the catalytic converter, but when the car was new, it would NEVER do this. This is with air conditioning OFF. It's of course gotten worse now as the weather is getting colder (my trip is between south-west Denver to Boulder in Colorado) and it takes longer for the engine to get to its operating temperature.
    There are other symptoms too like decreased gas mileage. Even though I drive better now (I drive now like a hypermiler), I'm down from an average winter tank of 50MPG to about 45MPG (my best tank over the summer a while ago was 58.6 on that hilly drive!!!).
    So all that is to say, is it worth the time and maybe money to take my Prius into Toyota and have them look at it? I've only had "official" service on it once (I do my own routine maintenance regularly), before 36,000 miles, and I asked them to do a battery capacity test. I wanted a baseline at that time. But the technicians told me there was no such thing. Hmm....
    Anyway, I'd appreciate any suggestions about what to do before I hit the 100,000 mile mark. Are there tests I can do? I read about Toyota doing cell voltage and resistance checks. And maybe there are aftermarket things I can purchase to find that out for myself? (BTW, I'm an electrical engineer so I'm tech savvy.)
    Thanks in advance! (From a very happy Prius owner overall).
  2. dmckinstry
    dmckinstry New Member
    1,034
    Cheney, WA (Near Spokane)
    I have no idea, but it "may" be possible with the kind of driving you do on a daily basis that you're stressing the battery more than most people.
    How did you collect your elevation data? Did you just take it off a map, or did you have a more sophisticated way of getting it?
    I'll try to PM you with contact information from at least one person that might be able to tell you.
    Dave M.
  3. john1701a
    john1701a Prius Guru
    12,826
    5,306
    58
    What is your expectation?
    The battery-pack will naturally not last as long for you as others. All that extra stress on a regular has consequences. In your case, that's reduced MPG. It probably doesn't mean a failure is near. Mine is now showing much more green than it ever use to. The impression I get is that it's just another vehicle behavior which we'd be oblivious to for years if it wasn't for the Multi-Display.
  4. whiten
    Littleton, CO
    Thanks for getting back with me. I'll be looking for the PM.
    I got the elevation through a brute force method that took a long time (boy I wish the Prius GPS had elevations too :(). I had wondered for a long time what sorts of elevations I went through every day.
    But in playing with Google Earth, I noticed you could click on a location and get its elevation. So I went to GE, and then plotted (using the ruler) every 1/4 mile on my route. I typed in the elevation GE gave me for each point into Excel and plotted it.
    However, there's an easier way for your routes that I know now.
    Go to Google Pedometer (okay, they won't let me link because I don't have enough posts - but do a Goggle search). Zoom in to the start of your route. Hit start recording, and then click your route. You might have to play with the "Draw Route" radio buttons, as GP tries to be smart about your route, and sometimes you have to do it manually to get what you want. Finally, on the left panel, click on the "small" or "large" Elevation link. It will compute your elevation (be patient if it's a long route).
    This is MUCH quicker than the GE method, but the elevation, if your drive is over 8 miles or so, won't all show up at once and you have to use the scroll bar. But if you have a graphics program, you can cut and paste them together. I got pretty close to the same results, but GP can be done in minutes vs. hours the other way.
    Hope that helps!
  5. Patrick Wong
    18,210
    6,513
    If your car doesn't show any warning lights, the traction battery will not be replaced although it may be degraded. So I'm not sure you will consider the outcome to be worth your time and money.
    I have a similar situation like yours, in that I live at 1,100 ft elevation and commute to sealevel ~25 miles one way. I suffered early traction battery failures on my 2001 and 2006 HiHy.
  6. whiten
    Littleton, CO
    There's no doubt that batteries wear down and don't hold as much charge as when they are new. But I'm, to be quite honest, suspicious that when "Toyota says its out-of-warranty battery replacement rate is 0.003 percent—or one out of 40,000 Priuses—for the second generation Prius" (First Numbers on Hybrid Battery Failure | Hybrid Cars) then they aren't doing a relevant test (hence my comment about the technician telling me that there was no battery capacity test). Of course they don't have to replace them if they don't have a metric by which to measure! The low statistic for "out of warranty" replacements says more about the out-of-pocket cost of replacement than having a metric by which to measure them against before the warranty expires.
    But, for example, NiMH batteries can have cell reversals and other behaviors where the batteries actually die. And in a stack of 168 cells per car, is it possible that one or more may actually have gone bad? Is it possible that with that many cells, the "good" ones mask the "bad?"
    My expectation, to answer your question, is that Toyota warranties the hybrid system for 100K miles. If all I have is normal wear and tear that's fine. But if I have a true, legitimate problem, I'd like to get it fixed before the warranty runs out.
    I just want to find out if there is a fair test that can be run to look at the batteries. Does the Prius computer itself monitor battery health and alert the user if it finds a problem? I have a co-worker who had his Honda Insight warn him of a battery problem at about 30K miles. Honda replaced the battery free of charge, and his mileage went up 10MPG pre/post the replacement. Would the Prius warn of a similar problem?
    My car, IMO, is showing symptoms that in my mind indicates at best, battery fatigue, and at worst, battery failure. But that's why I'm going out to the great collective of experience and knowledge on PriusChat for advice.
    I would appreciate hearing from anyone with answers to my questions or suggestions of where to go from here.
    Thanks!
  7. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    your SOC is not supposed to be green... blue is ok.
    also you dont give enough data to determine if you have an issue. its very conceivable that with proper stealth, or even purely by coincidence, your SOC could be in the mid to high 70's meaning that you would overcharge going down the same hill that you previously had no issues when starting with an SOC near or below 60%.
    also, charge states are determined by the batteries feedback. if you were getting to all green quicker (rather than slower as you suggest) that would imply that the capacity of your pack has lessen, meaning a shallower charge cycle and a quicker fill up?
    in any event, unless you are using another monitoring system for SOC current and have reproduced results more than a few times, i honestly dont think you could tell the batteries were going out.
  8. john1701a
    12,826
    5,306
    58
    The unknown is why I carefully track my MPG. With so many variables at play when it comes to efficiency, at least establishing an expectation through observed patterns is something to base upon.
    The hypothesis is MPG that slowly fades, due to reduced capacity over time.
  9. dmckinstry
    1,034
    Yep. Thanks.
    And if you find out your battery is degraded more than you want, you can get replacement battery packs from wrecked cars. I have two used battery packs added to my original for the purpose of creating a plug-in.
    Dave M.
  10. dmckinstry
    1,034
    Cell reversal should only occur if the SOC gets so low that the lowest cell actually does reverse direction. Normally, this shouldn't happen with even an EV mode modification. I don't know if this can be tested without removal of the battery pack from the car. However, CAN-View does give a lot of info including internal impedance. It apparently does this by using terminal voltage, internal voltage and current. I'm not sure, but I would expect that a reversed cell could cause an indication of high internal impedance. Usually normal internal impedance is around 0.25 ohm, but is temperature dependent. Maybe one of the other OBDII scanners gives this kind of info also.
    Dave M.
  11. Patrick Wong
    18,210
    6,513
    It's certainly possible for a battery module (containing 6 cells) to fail, and in that instance a DTC should be logged.
    The cells are wired in series. The battery ECU monitors voltage generated by the 14 pairs of modules. If one pair is much different compared to the other 13, an error will be logged.
  12. john1701a
    12,826
    5,306
    58
    I use to sing about the blues, but now it all about being green.
    Pun definitely intended! But I do now question your claim, wondering if Toyota engineers/programmers were so clever than they knew later life would introduce higher SOC levels. So, they had the Multi-Display adjusted to push the level down... preventing us from panic when the green started to become common.
    I'm 5 years and 108,000 miles into my journey with this Prius. In sub-freezing temperatures, I see 7 bars a few times per commute... quite unlike the past. Yet, nothing seems out of the oridinary. In fact, I saw hints of that behavior emerge late last winter. That give the impression of very slow aging... and no need for concern.
  13. brick
    brick Active Member
    1,083
    79
    Upstate NY
    One thing I have noticed over two years and 37k miles with the car is that the traction battery tends to maintain higher SoC in cold weather, particularly in highway driving. I ran I-95 from SC to RI yesterday and the pack spent the vast majority of the drive at 7 bars (green). That can happen in warmer weather, too, but typically not unless I'm traveling at 75mph+. (I was maintaining 65-70 on this trip.) Higher nominal state drove the SoC up to the max once or twice as I was negotiating NYC traffic and the steep hills of eastern CT and RI. So I don't doubt that there is some reduction in battery capacity at nearly 100,000mi, but it is likely that the onset of winter is exacerbating your symptoms.
  14. Chuck41
    Chuck41 New Member
    Midwest
    Brick
    I have noticed the SoC going into the green more often now the Temp. is in the 20 - 40 F.
    I have not changed anything but noticed the colder it is the more the Soc goes into the green. Thanks for the post because some indicate that it could be a problem with the traction battery.
  15. whiten
    Littleton, CO
    So many thoughts, so little time... ;)
    First, I was not trying to imply that my Prius is showing more time in the green, but less. And more to the point, when it is in the positive region (5 bars or more), it seems to drop into the negative region much more rapidly.
    Just to reiterate, on my drive to work with the big downhill portion about 2/3rds of the way there, my Prius has almost always charged to 8 bars down the hill (from day one). The following 5 miles of gradual downhill, when new, I could finish off to work running nearly 100% on battery (and still arrive with 8 bars).
    Now, I rarely get to work with 6 bars, and never 7 or 8. And I'm driving more conservatively than when new.
    But on leaving work, in only 1/2 mile, less than 2 minutes of drive time, and only 50 feet of climb (accellerating slowly to 35MPH), I'm down to two bars almost every day. So I've used from 25% to 56% (depending upon uncertainty in the calculation) of the useable battery capacity in that short time & distance.
    Second, I've been noticing this trend for a year and a half or so; i.e., through multiple seasons, temperatures, loads, road conditions, etc. I can see temperature effects for sure. Yet the overall trend is still towards muchlower battery capacity (IMO).
    Third, (just as a response to recent post on this thread), last February I drove from Denver to Nashville, interstate (75MPH) most of the way. On the way there, I did experience 7-bar green SoC throughout eastern Colorado, Kansas (it averaged below 20F), and into Missouri. But then as temperatures warmed up as I drove to lower elevations and eventually south, the SoC went back to more normal. Gas mileage on that leg of the trip was a little less than I'm used to on the highway, about 40MPG. On the way home, through, through Kansas (again 20F), I only averaged 33MPG. Typically 3 to 4 bars. WAY DOWN on MPG! I did not notice a head wind either driving or when I got out to fill up and for stops. I drove this stretch before in the summer, and both directions got between 42 to 47 MPG. So these out-of-character indications I chalked up to colder temperatures, and probabably some part due to an older battery.
    Anyway, thanks for the feedback. As I stated in my 1st post to this thread. I'm not in any way complaining. This car is amazing, and I would buy another in a heartbeat if I had the money and need. I'm just trying to get information about whether my battery is behaving as expected after 90K miles, or is it having a problem that I should take it in for.
    So far, the jury is still out in my mind.
  16. Flying White Dutchman
    4,376
    313
    did anyone measure the battery cells?
    i did look at the pictures
      File size:
      41.3 KB
      673
      File size:
      48.4 KB
      699
  17. donee
    donee New Member
    2,956
    198
    Chicagoland
    Hi Whiten,
    Not sure if this has been mentioned yet or not, but the Prius has a warm-up cycle that during the first minute (somebody said something about 105 seconds in another thread ?). During which the computers will not use the gasoline engine for much thrust.
    So, using mid level accellerator pedal postions during that time the computers will use the battery to push the car. The engine is effectively just idling.
    To avoid this, as it seems your driving situation is stressing your battery, just sit in the car after turning it on for 2 minutes. The engine will run. It will wast gas. But, it will be used to climb the hill, and not the battery, when you leave. And this should help prevent the battery from getting into a reversed cell situation in its old-age.
    On level terrain and in typical residential areas this is no problem. But up hill at significant accelleration, in a commercial area, the battery is going to discharge a bunch before the 105 second (?) is up. In my drive, I have a stop sign at the top of the hill. I really baby the car up that hill, and its only 1/4 mile out from the start. Once I get through the stop sign, I accellerate very slowly (about 1/16 th accellerator pedal depression) trying only to use only the engine. And as its down hill after the stop sign, this is practical. Near the bottom of the hill is where the warm-up cycle completes, and off I go.
    The only bad part of this, is that if Type A wacko SUV driver pulls in behind me when I am doing that down hill slow accelleration, they end up plastered to the rear of the car for the next few miles, even if I am going 5 mph faster than the limit. Because they are too close to me to safely glance down at their spedomenter, and have preconcieved notions about Prius owners. On more than one occasion, I have had such drivers pass me on curving 25 mph, no passing zone and zip up to 50 mph.
    From my driving experience in Colorado, I make the suggestion that you just sit in the car for two minutes.
  18. john1701a
    12,826
    5,306
    58
    And we've taken your observations and run with them. My guess is that we'll see something similar later. Our green will slowly fade to less and less blue bars and lower MPG as the miles/years pile up.
    The impression I get is that's normal, but sooner than those of us in flat-country will experience.
  19. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    John; i only have 30,000 miles but i also notice green more when its cold and i think its because the ICE has to run more to stay warm so it tends to run the SOC a bit higher in winter.
  20. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    I think the general theory was that a little more charge is
    deliberately pushed into the battery in cold temps to try and
    warm up the cells a little more. They aren't really happy below
    freezing; regen current is limited to 40 or 50 amps, you can't
    get into EV mode, etc etc. Charging and taking in cabin air
    through the vent system helps get the cells happy sooner.
    _H*
