PHEV mod under way, Bristol, UK.
Discussion in 'Gen 2 Prius Accessories & Modifications' started by aminorjourney, Jun 7, 2008.
  1. dmckinstry
    dmckinstry New Member
    1,034
    Cheney, WA (Near Spokane)
    Darn! You'll have a full charge before me now. I won't be back to my Prius before tomorrow some time.
    Have fun.
    Dave M.
  2. Flying White Dutchman
    4,374
    313
    did a partial first charge today!
    only its freezing outside so the ICE want to kick in all the time:mad:damm ICE:mad::mad::mad::mad:
    tomorrow i will try a full charger
    i also did a upper full grill block today and going to see if i can do a full tomorrow
    temp are not helping when working outside:smow:
    he nikki already a bit better?:)
  3. dmckinstry
    1,034
    Just a brief update. I haven't seen a report from you yet, but...
    I did a partial charge on Monday and pulled the plug on the charger, since I needed to run an errand. I quit, as the car started and pushed the voltage up. I'd had the car on so I could monitor the voltage, current and temperature using CAN-View. I couldn't drive very far without the engine starting, but in 13 miles I averaged 126 mpg (according to CAN-View). After I got back, I started to charge again, but it shut down within a few hours, with only about 232 V indicated. I let it sit overnight, and in the morning had a bunch of warning lights (even through the car did start). CAN-View indicated the battery temperature was 139F. The external batteries didn't get above 89F (according to and indoor/outdoor thermometer I was using.) The temperature seemed to stay at 139F for over an hour, but then started to drop. When it got down to 109 F I reset the DTCs and all errors went away. No problems on the internal battery since then. So, I don't know if there was a clitch in the temperature reading or something else. The internal resistance of the combination of parallel packs was still around 0.11 ohm, so the internal battery wasn't actually destroyed. Although, it may have been weakened. I won't know that until I test the OEM battery pack independently of the other packs.
    I did disconnect the external packs, and the internal resistance of the OEM battery was 0.25 ohms, which has been normal for it.
    I'm out of the country on a vacation (holiday for Europeans I guess) for a week. I'm not going to do anymore testing, until I get back and can have an external set of measurements of current, voltage and temperature when I do the charging.
    Dave M.
  4. aminorjourney
    aminorjourney Mum to two prius!
    335
    27
    Bristol, UK
    Dave,
    Please tell me you were using cooling on those additional packs?
    I suspect the guilty party here is not enough cooling on those packs. I would suggest constant forced ventilation while charging and as Norm has suggested, for several hours afterwards. What was the final voltage you are charging to?
    You'll also notice that pack temperature when you have been heavily using the pack to be higher than if you had not been using it. 139 degrees F is 59 degrees C! That's hot! Do you know what the temperature of the pack was when you returned from your trip? The highest I've seen my OEM pack get while driving (a long downhill with lots of high power regen) is 55 degrees C or 131 Degrees F. Above 45 degrees C (113 F) EV mode won't engage.
    Nikki.
  5. Flying White Dutchman
    4,374
    313
    HI
    what was your outside temp?
    you charged the pack and then went for a drive!
    and after that charged the pack again
    i think it got hot because you did not gave it any time to settle down.
    outside here is freezing the pack never reached 8celsius.
    i did a full charge
    also did a cell voltage measurement unloaded and loaded.
    nikki did you already connect the bms+?
  6. aminorjourney
    335
    27
    Bristol, UK
    I concur. I think your battery pack was probably fairly hot when you returned from your little trip and recharging it again pushed it over the top. What current are you charging at?
    Out of interest, are you recording via Can-View too? I've worked out how to power both CanView and MFD while the car is switched off - I'll document it when I've finished with my trials. The idea is that Can-View, MFD and BMS+ are all turned on when I charge and data-log to a PC I've got to put in the car.
    HAHAA! No. This is a week when I've had a plethora of students doing exams - not to mention the end-of-term concerts. No work on the Prius this week other than putting another 400 mlles on the clock. Tomorrow we're off to celebrate Thanksgiving (late) with some more American-British friends.
    Next week - I hope to get the board finished and then the BMS+ can get installed. I need to figure out how to get the power to the various components while charging. A 12v mains supply is my choice at the moment I think...
    Nikki.
  7. dmckinstry
    1,034
    I have been monitoring the temperature on the external packs, and they haven't been getting as warm as the internal packs. The only cooling is convective, but there is plenty of air space below them (the spare tire well has no tire in it). By touch the external packs in the a.m. when the interior pack read hot were cool. I'm still not sure the internal pack was at 139F when the sensor read that, which is why I want to attach a temperature sensor to the internal pack that I can read with the car off, while the charging is being done. I find it hard to believe the 139F for at least an hour (and at least 6 hours after completion of the charge with battery voltage of 232-233 V) wouldn't have completely destroyed the pack. Its internal impedance still only reads 0.25 ohms, which for this pack has been normal.
    The car appears to be operating normally with the other packs disconnected. However, there hasn't been extensive operation or testing. That will start sometime after Dec. 6th.
    Dave M.
  8. Flying White Dutchman
    4,374
    313
  9. dmckinstry
    1,034
    When I've turned the car on for CAN-View readings near the end of the charge, the current (total not just through the internal pack) was about 0.6 A, and temperatures less than 100F. When returning from the 13 mile trip, CAN-View indicated the temp. less than 95F, and the external packs even less. I might mention that when the temperature was indicated to be 139F, the case on the pack was warm but not hot to the touch. I don't know the temperature difference between case and battery, but the case couldn't have been much more than 100F, or I would have felt discomfort in touching it.
    I'll be interested in what you do to get CAN-View readings with the car off.
    In accessory mode even, the readings aren't necessarily correct.
    Dave M.
  10. aminorjourney
    335
    27
    Bristol, UK
    Great news everyone!
    My charger has shipped tonight and should be with me tomorrow. I'm so excited!
    Sadly my car isn't going to be back with me until the end of December at the very earliest so I'll be working without the Prius. At least I can charge the two packs up off the Prius to make sure that everything is okay with them as they've sat for some time.
    Dave, I'd be more than happy to share my final design once completed. There's still a few problems that need to be figured out before I actually do the PCB but I'm very close to having it sorted.
    Nikki.
  11. Flying White Dutchman
    4,374
    313
    hi nikki
    yes shame the thing with your car
    its not going good... but lets hope for better time's
    i am building a small 2 piece PCD with 1 relay on that will shutoff the charger when one of the packs gets to hot
    now i have 2 temp sensors because i only have the OEM pack and 1 addpack.
    the total cost for this in parts is about 40 euros or something like 50 dollars
    i am connecting the wire's at the moment and its more that i have this finisched before the summer gets here.
    i can tell you one thing
    there is no use of just 1 addpack to the oem pack with these low temparatures
    the current draw is limited to protect the packs and so the ice will run anyway.
    2 addpacks is minimum for a BMS+ situation or 1 if you life in a warm climat
  12. aminorjourney
    335
    27
    Bristol, UK
    Update!
    The Zivan NG3 has arrived!
    I'll post properly at some point when I've had a chance to look at it properly...
    As to the additional packs - I've got two additional packs plus the original, so I hope that will help me greatly. Since the British climate is decidedly warm in these parts most of the time compared to your northern lands I hope it will make some difference!
    Nikki.
  13. aminorjourney
    335
    27
    Bristol, UK
    Okay - here's an update.
    I went to the local Battery shop yesterday to get some cabling and came back with a couple of candidates. I've got to try them out and check they're not too thick to use with the 175A anderson connectors I'll be using.
    This morning I decided to take a photo of everything ready to go in - minus the car and the batteries (since the batteries are in my garage and I wasn't going to lift them out on my own!)
    My initial impressions of the Zivan is that it's HUGE! I didn't quite expect it to be as heavy as it is. I would love to plug it in and get it going, but there's no point yet...
    I also have a bit of a mac-based surprise too - but more on that when I get those bits and my car back! :)
    Nikki.
    (Happy new year!)
    P.S. Can we get this moved to the PHEV mods section? Danny?
  14. Flying White Dutchman
    4,374
    313
    funny
    when i got the zivan i expected it to be bigger haha
    do i see 3 hybird interfaces boxen?
  15. aminorjourney
    335
    27
    Bristol, UK
    I'm glad it's no bigger - otherwise it wouldn't fit where I want to put it!
    There's only 2 parts from Hybrid Interfaces - the CanView and BMS +. The third project box is one I'm using for my own adaptor interfaces.
    Nikki.
    P.S. There's some new code up now for CanView and BMS+ I think.
  16. aminorjourney
    335
    27
    Bristol, UK
    Folks,
    Another quick update!
    After a week off work (it's school break here!) I was able to catch up on all my chores plus spend a day or two progressing the conversion.
    This afternoon I spent some time trimming back the battery cases (after removing the OEM BMS) - and put on the new battery cables with Anderson connectors on them. This will make it easy for me to connect/disconnect the battery packs and charger.
    For fun I also boost charged both spare batteries and all is well. It was the first time I'd used the Zivan!
    There's a photo-set on Flickr. It's getting to the point where I can finally envisage driving around in my plug in Prius!
    Prius battery preparation - a set on Flickr
    I had better hurry up anyway - I have to exhibit it at the maker faire in three week's time! :shock:
    Nikki.
  17. Flying White Dutchman
    4,374
    313
    ok finally!!
    wow 3 weeks .... ai ai
  18. miscrms
    miscrms Plug Envious Member
    2,076
    523
    Phoenix, AZ
    Very cool! Can't wait to see it up and running. I'm sure you are already aware, but just make sure when trimming the cases down you don't compromise the parts that keep the battery modules in compression. Without that pressure, the modules will expand and pop like pop-corn during charging as internal pressure rises.
  19. Flying White Dutchman
    4,374
    313
    miscrms
    the 2 plates holding the battery's and used for the compression are connect with 4 (2 on top and 2 bottom ) steel pipe's
    the battery's are only connected to the base plate to hold them down
    you can cutt that compleet case away and still have the pressure hold.
  20. aminorjourney
    335
    27
    Bristol, UK
    Thanks! Yes, I have checked that it doesn't affect the battery compression blocks. I've actually just cut shy of them, so there should be enough metal left to stop the exploding!
    Nikki.
