2009 oil leak
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jvilter, Dec 1, 2008.
  1. jvilter
    jvilter New Member
    San Gabriel Valley, CA
    I am the very happy owner of a 2009 Prius. I've had the car for just over three weeks now and just noticed, late last week (just before Thanksgiving), an oil leak on the floor of the garage in the vicinity of the left rear wheel. More than a few drops for sure - if I had to guess, I'd say somewhere in the neighborhood of a couple of tablespoons. I plan to take it to the dealer today to have it checked out, but has anyone here experienced anything similar? I will update once I get a verdict.
  2. EZW1
    EZW1 Active Member
    722
    81
    Phoenix, AZ
    2016 Prius v wagon
    Four Touring
    No leak here but must comment that there is not much to leak back there - just wheel bearing grease, brake fluid, and (if the shocks are fluid instead of gas-filled) the shocks.
    Once you learn what is going on, let us know here on the forum.
  3. richard schumacher
    7,664
    1,046
    United States
    Just to get more data, and ignoring for the moment the apparent impossibility of the location: measure the oil level in the engine.
    What color is the stuff on the floor?
  4. tochatihu
    tochatihu Senior Member
    9,766
    3,766
    Kunming Yunnan China
    2001 Prius
    If you haven't driven to the shop already, please check the brake fluid reservoir level under the hood. If it seems low, please have the car towed instead of driving there.
    Looking forward to updates...
  5. jvilter
    jvilter New Member
    I took the car in this morning and got in right away (I was treated very nicely, I must say). They put it up on a lift and found no indication of any sort of leak. They took me into the service bay and let me look too, so I know there was nothing. It's still a mystery to me though, so when I came home I put some newsprint down in the area of the drip to see anything shows up by morning. Oh, and to answer the question, it was definitely oil on the ground.
    I'll report back here if I find more oil, otherwise, I guess that's all folks. Thanks for your input.
  6. toyotechwv
    toyotechwv Toyota Technician
    474
    251
    Princeton, WV
    When you say "left rear" I'm assuming you are talking about the driver's side rear?? That would be correct but I've seen a lot of people refer to left and right on a vehicle as they are facing the front of the car.
