Coastal Tech Receiver Hitch
Discussion in 'Gen 2 Prius Main Forum' started by gpb5200, Mar 3, 2007.
  1. gpb5200
    gpb5200 New Member
    I just ordered the Coastal Tech receiver hitch this past week. It has not yet arrived, but a question has just occurred to me, based on a thought that I just had.
    Is this a class 1, 2, or 3 hitch?
    The reason I ask is that not only would I like to mount a bike rack to it (no problem), I was thinking I could possibly mount a flat cargo carrier to it for those times my family goes on extended vacations, but am concenred about the toungue weight capacity of the hitch. The rack looks like it has its own receiver in the back, so if I really wanted to pack it all, I could attach the bike rack to the cargo rack and extend my car's length by about 4 feet. Not sure if this would be practical (or safe)...
    Having the option to run either one when needed, without having to rely on roof racks would be fantastic.
    Below should be a link to a folding, lightweight carrier I was looking at:
    http://www.sportomotoring.com/everthere-folding-carrier.html
  2. jimmyrose
    jimmyrose Member
    646
    Northern NJ
    I would contact Coastaletech directly to find out what class hitch you ordered, although someone here may reply with this (imo, it's always better to hear directly from the vendor).
    I have the 2" coastal receiver hitch (bought it from a local PC member). I bought it primarily to carry snowboards and skis. I have a Yakima Bighorn 4 bike rack and ski hitch attachemnt. With this set up and 2 snowboards and one set of skis, the hitch bounces quite a bit. I think trying to add a bike rack plus your cargo carrier may be asking too much of the hitch, especially if they're loaded up...someone on here beefed up their hitch by having an additional support member welded on and attaching to a point further towards the front of the car (his modification should strengthen the attachment points, imo).
    I've been wondering about a lightweight cargo carrier for when we take mini vacations (sans skis/snowboards/bikes), so thanks for the link.
    I would wait to get some responses from more knowledgeable members here before attempting/purchasing this combo. They will not steer you wrong.
  3. grasshopper
    grasshopper Member
    425
    Myrtle Beach SC
    I have a 2 in. costal hitch and I only use it to haul trailers. Tung weight is 300lbs, except for gas mileage it hasn't caused any problems. You need to keep it close to the carrying capacity of the Prius. I don't remember exactly what that is right now but it seems like 1300lbs comes to mind although I have hauled considerably more than that but not for long distances or up hills.
  4. jimmyrose
    jimmyrose Member
    646
    Northern NJ
    <div class='quotetop'>QUOTE(grasshopper @ Mar 3 2007, 11:29 AM) [snapback]399494[/snapback]</div>
    2006 Manual states vehicle capacity weight (occupants and luggage) as 810 lbs. I'm sure there is some built-in tolerance to that figure, but I'm not intrested in personally testing that theory. :)
  5. grasshopper
    grasshopper Member
    425
    Myrtle Beach SC
    <div class='quotetop'>QUOTE(ZenCruiser @ Mar 3 2007, 11:48 AM) [snapback]399501[/snapback]</div>
    Thanks, like I said I wasn't sure. But 810lbs WOW, My wallet weights more than that since I save so much on gas. :lol: :lol: :lol:
  6. Devil's Advocate
    922
    Las Vegas, Nevada
    The Coastal Tech hitch is a class I, 100lb tongue rating and 1000lb towing capacity. Eventhough Toyota specifically states that the Prius has zero towing capacity. (I may have violated this a couple of times!)
    I bought the Curt hitch which has a shorter reciever and creates less torque on the mounting points. With the CT hitch you should add the stabilizing bar to the rear center jack point or else your bikes will bounce.
    As far as racks, I have a Coleman I got for $129 at performance bike which holds the bikes great, by the wheels and with a clamp and not hanging style, Thule and Yak both make one for significantly more, though those do fold a second time so that when not in use it only sticks out about 8" from the back instead of the 24" on mine.
  7. steved
    steved Junior Member
    Denver, CO
    <div class='quotetop'>QUOTE(gpb5200 @ Mar 3 2007, 05:21 AM) [snapback]399452[/snapback]</div>
    I have the Coastal 2" receiver and there is no way I would even consider a flat cargo carrier and then a bike rack attached to the cargo carrier. As others have said, the Coastal receiver bounces when loaded with bikes and the extended load and distance from the hitch would put stresses on the hitch and car frame that the receiver was never intended to handle.
    I am currently using a Thule T2 hitch rack (55 lbs) and then carry 2 mtb's that weigh about 55 lbs together. My total hitch weight is about 110 lbs and I know that the Coastal receiver deflects when you drive down the road and hit bumps, etc. Coastal told me that the 2" receiver is rated at 200 lbs so I'm under that, but I wouldn't want to put much more weight on it then I do. It makes me nervous to see expensive bikes bouncing behind the car.
    I am investigating reinforcing my hitch to minimize the deflection and I would be interested in any information from people that have done this.
  8. normonster
    normonster Junior Member
    Steved or others,
    I also have a 2006 Prius w/ coastal 2" receiver. When I first put it the bike hitch rack, I couldnt open the hatch, but now after months of carrying mtn bikes, the load has caused the hitch lower a bit, and I can open the hitch. This is great, but I also see A LOT of bouncing and its time to fix this. Does anyone have any detail or suggestion on where I can go get a support bar attached as mentioend in the previous post, or some other solution?
    Thanks,
    Norm
  9. tombellanca
    tombellanca New Member
    53
    Encinitas, CA
    search around.
    there were some really good pictures of someone's work. essentially it extended the back of the hitch about 12-18inches to a point where it could be screwed down and balance/off-set the dropping at the front point of the hitch.
    I found a welding shop that specialized in hitches for trailers and handicapped wheelchairs trailers. He installed the bar as I described about and also welded some support up above the hitch mount to the inside of the frame.
    The job cost about $125.
  10. icarus
    icarus Senior Member
    4,884
    976
    earth
  11. timm
    timm Medical Transport Driver
    121
    Spring Green, WI
    Four Touring
    You can take a close look at pics of my modified 2" inch Coastal hitch here: http://priuschat.com/forums/newbie-f...tml#post558310
    I've done a lot of towing in the last three years and have had no problems. I did remove, sandblast, and repaint the entire hitch this spring. (Wisconsin road salt in winter is a killer)
    Timm
  12. wpavalko
    wpavalko New Member
    I purchased both the Coastal 1 1/4" and Curt (1 1/4") hitches (long story involving a Hurricane). Just based on the mass, the Curt hitch is about 10 lbs heavier and looks much sturdier. The long Coastal neck didn't give me much confidence. I'm sure the Coastal Hitch works, but I decided to install the Curt hitch and it's really solid. I haul 2 Bikes on a Yakima Stick-Up carrier (which is pretty heavy) and it's very stable. Also, you can get the Curt hitch for $50 less.
    --WJP
  13. ScubaGypsy
    ScubaGypsy Live Free & Leave No Footprint
    95
    Aquidneck Island, RI
    Is the Coastal hitch the only 2" receiver?
  14. normonster
    Hi Timm!!!
    Thanks for the response. I just logged back into prius chat a whole month later, I was grumbling over the holiday break about my bikes bouncing around, and seeing your pics is really making the new year look better to me.:) I'm off to the trailer hitch shops to see if they can machine something for me. I live in the CA SF Bay Area, hopefully the cost for the fix will be reasonable.
    Thanks again!
    Norm
  15. timm
    121
    Spring Green, WI
    Four Touring
    You're very welcome. :rockon:
    Timm
  16. andrewsilver
    andrewsilver Enthusiast
    33
    Frisco, TX
    If anyone is interested, I have a CoastalEtech 2" Receiver hitch for sale. Cost me $167. Asking $100, open to offers.
  17. ilsinc
    ilsinc Junior Member
    Bellingham, WA
    Is it still available?
  18. ulandt
    ulandt New Member
    Boston, MA
    2002 Prius
    I
    Hi. I'm sure it's sold, but I am trying to get the receiver hitch for Gen I 2002, which seems to be discontinued.
    Thanks
