I Have Seen The Next Generation Prius
Discussion in 'Gen 2 Prius Main Forum' started by enerjazz, Mar 30, 2005.
  1. enerjazz
    enerjazz Energy+Jazz=EnerJazz
    256
    144
    Fairview, TX
    OK, so I haven't actually seen it, but I did get to spend the last couple of days with Amory Lovins of RMI as he talked about his book "Winning the Oil Endgame." Based on Toyota history of innovation and long term thinking I'll just say two words of prediction "carbon fiber."
    For those who don't want to read the book just go straight to the slideshow and check out the section on cars. I predict that Toyota will again be a leader and be one of the first to mass produce the carbon fiber body. This will significantly boost the Prius mileage (and, as a side benefit, safety - see slide 9 to see how steel can't match carbon). The current Prius actually looks like Amory's hypercar (slide 14) which was first shown in the mid 90's.
    Amory points out that cars exist to move people. Yet a person is only a tiny fraction of the weight of the system. The car spends most of the energy moving itself and taking you along for the ride. Make them lighter (but still strong and safe) and we spend much less energy still doing the same job - moving you safely. I call #1 on the list for the carbon fiber Prius.
    Presentation - http://www.oilendgame.org/pdfs/WtOEg_Presentation.pdf
    Download the book for free - http://www.oilendgame.org
  2. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    thanks for the link. some very interesting stats here. some pretty radical ideas here too. but can we manufacture that much fiber?
  3. Tadashi
    Tadashi Member
    796
    Fort Hood, TX
    I am not so sure about cabon fiber replacing steel. It would depend on the appliation. Composites are stronger but not as flexible. Under stress a composite will hit a point and have a catastrophic failure, where as metal will fatigue slowly and in some cases get stronger as it is bent. Hence for the reason composite have not been allowed in certain aircraft parts. You would be able to detect the defect and replace it before a failure. It has been 15 years since I took my composites class so they may have come up with suitable work arounds for safety. I will have to read his book and see how much composites have advanced I guess.
  4. TotusPorcus
    TotusPorcus New Member
    Ah.. out of curiousity, what is carbon fiber made out of? Does the process start with a petroleum based raw material??
  5. Tadashi
    Tadashi Member
    796
    Fort Hood, TX
    I am not sure now, but in a nut shell it was a carbonfiber cloth or kevlar or whatever type of composite you want to make. Then you would use multiple layers of cloth with various types of resins and epoxies that would harden/cure to make a really hard composite. I think the resins and epoxies are petrolum based. I am not sure about the composite clothes that are used.
  6. Tideland Prius
    16,602
    Well the SLR has a full carbon fibre body and the first car with a carbon fibre crash structure. Carbon fibre is made of (woven?) cloth that's baked at high heat (and somewhat high pressure) then moulded (sometimes parts are in multiple layers) and glued together
  7. Jerry P
    Jerry P Member
    322
    Waterford, PA
    2021 Prius
    XLE AWD-e
    Really makes you think. I don't know how the energy use for manufacturing steel vs. carbon fiber goes, but I would think that carbon fiber is a bit less since steel is VERY energy intensive.
    Just the use of aluminum in vehicles is making a big difference. The hood on my Prius probably weighs 1/3 of the hood on my wife's Corolla. If the whole body was made to weigh 1/3 of what it currently weighs, the savings would be fantastic. Aluminum, though good, is not the answer, since aluminum production consumes very high amounts of energy. Recycled aluminum, however, does not.
    The one problem I see with ultra-light vehicles is wind stability. This is already a problem for some people with the Prius, and some way would have to be found to minimize this.
  8. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    if it were made of petroleum products that would seem to be a half solution at best. i saw a special on this type of technology before but i was under the impression that it just couldnt be manufactured in huge bulk like steel could. (a huge steel roll can make several cars and be hauled on a single truck. carbon fiber cant be and also as someone may have mentioned here, it has a problem of not bending like steel does in an accident.
    with no crumple zone, accidents would create severe injuries for occupants. as i understand it, a lot of strides have been made with flexible restraint systems (the seatbelt does the stretching instead of the car crumpling, both in effect moderating the deceleration of the vehicle in event of an accident. this is the largest cause of injury.) however, this system last i heard was only effective in front or rear collisions only.
    i did see a special on Modern Marvels with some sort of fibre that had all the characteristics of carbon, and was as flexible as steel. they showed a demostration where a fender was crunched. then a guy came along with a suction thing and pulled it back out. not a scratch or mark on it. unfortunately, that vehicle would cost about 300,000 i believe.
    also you if want an example of a car with carbon fibre, look at the MacLaren F-1. it has a carbon body, 12 cylinder motor and will go 0-100 in 4.3 seconds.
    the car is so light that it has flow through air dams that when the brakes are pressed, the dams direct force up to effectively make the car heavier so it can stop since the rear spoiler isnt enough to do it.
  9. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    another thing the guy mentioned that i think is a great idea is the low income leasing program.
    it doesnt go into much details but what i think it does is lets low income people trade in their old ineffcient ( and probably untuned) junkers in for high efficiency vehicles. now if the Prius was selected for that program, it would drive the price waay down. it would also take a huge chunk out of the gasoline appetite. we have all been stuck behind the old ford van that belched out as much smoke as your backyard bar b Q.
  10. pepa
    pepa New Member
    102
    Rockford, Illinois
    I think there already was a vehicle with body made of carbon fibre once: It was East German vehicle called Trabant.
    It was three cylinder, two-cycle stinky bastard. Quite popular back then because it was so darn cheap.
    The fact that it never rusts is today considered a curse in countries of former Soviet bloc, because these smelly monsters are still running there.
  11. enerjazz
    256
    144
    Fairview, TX
    Honda and Toyota are both working on carbon fiber.
    Quote from an interview:
    LOVINS: So I think that policy will now be reexamined. But I don't actually think the marketing will be a big problem. As soon as the automakers have cars made of this stuff--BMW may have it as early as next year; Honda and Toyota are in the carbon airplane business, not for amusement but to migrate the technology to cars--they will be marketing the safety of that stuff just as Honda successfully does now. And we have light cars, mainly imports, that are very safe, sell very well, no problem.
    http://www.cfr.org/pub7553/amory_b_lovins_..._innovation.php
    RMI spun off a for profit company - initially called Hypercar, but later changed to FiberForge (http://www.fiberforge.com/PAGES/home.html) after they realized that developing affordable carbon fiber technology was where the action is.
    This site covers quite a bit about carbon fibers:
    http://www.geocities.com/CapeCanaveral/1320/
    Amory is meeting with the developers of the Prius soon. I told him to give them a big hug from me.
  12. Tideland Prius
    16,602
    it's 0-60 in 3.2 secs Dave :p. It has fans underneath (not sure if they're active or free-spinning) to help with aerodynamics. I just got all this info from a Top Gear clip from the early 90s
  13. D'Tan
    D'Tan New Member
    North Dakota
    Well, I'm involved in a project here at school where we're building a fuel-cell powered vehicle (we used to do solar cars, but we're going on to other power sources). The chassis is made mostly out of carbon fiber. There are metal reinforcements in some areas like where the suspension connects and the roll cage is metal. Don't recall what's steel and what's aluminum (and I don't care that much; I'm on the electrical side of things).
    If you want to see how the panels were laid out, go here: http://www.und.edu/org/sea/
  14. Tadashi
    Tadashi Member
    796
    Fort Hood, TX
    The book is very interesting and worth the read. They discuss the economic trade offs and show a vehicle that was in an accident (weight is extremely important in aircraft). The composite vehicle only suffered scratches and the normal car had to be towed. At low speeds I can understand this but the author failed to address what would happen at high speeds (as mentioned before no crumple zones). Unless the industry uses a layered mix of metal and composite.
    He talked about a a high production automated method at 80% quality of hand methods at 20% of the cost. I remember doing graphite composite for a plane. We layered several layers of graphite cloth in different directions to account for different stresses. I do not remember baking it. We used epoxy and resins and left at room temp to cure. It was exteremly messy and time consuming.
    Making the car lighter would be a problem. In El Paso we have 30-60 mph gusts from Nov - Apr. I get thrown around a bit already in my Prius. I guess they can semi-enclose certain areas of roads to accomidate this problem.
  15. richard schumacher
    7,664
    1,046
    United States
    I'd bet on titanium instead. A new reduction method should soon make it about as cheap as aluminum.
  16. Ray Moore
    Ray Moore Active Member
    857
    52
    Aluminum isn't cheap.
  17. 200Volts
    200Volts Member
    439
    46
    Northern CA
    I interface to the aerospace industry and there is a big carbon fiber material shortage right now. Carbon fibers come woven or in strands. The woven material is used like cloth is in fiberglass and the strand material is wound around mandrels to create complex shapes.
    Titanium will never happen in high volume. Racers nicknamed Titanium "unobtainium" because of the expenses for raw material and machining. It's relatively brittle compared to Aluminum or Steel. Some small parts are made of Titanium now (like A arms on the corvette, I think).
    The big Audi has an all Aluminum body and the commerical shows 2 men holding up the body by themselves.
  18. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    Tideland Prius;
    you must have specs on the slow one. the one i read about does 0-60 in 2.1 sec
  19. Anonymous
    Anonymous Guest
  20. kidtwist
    kidtwist New Member
    183
    That looks like a cross between a Prius and an Insight. I'm all for a next-generation Prius, but I hope it doesn't look like that.
