Winter gas mileage
Discussion in 'Gen 2 Prius Main Forum' started by Palmetto, Dec 10, 2008.
  1. Palmetto
    Palmetto Junior Member
    88
    West Michigan
    I drive a 2008 model since May. Summer months I average about 48 mi/gallon of gas.
    I live in snowy Michigan and my mileage has dropped to about 38 mi/gallon. I have an engine block heater for my commute to work, but the engine is cold on the start home.
    The roads are snowy. Rolling resistance is up, for sure. I notice that the engine turns itself on at a stop, after moments, if my heat is on. Is the significant drop in fuel efficiency that I have experienced expected given all of the aforementioned info? Has anyone else in the snowbelt noticed the degree of change in fuel efficiency that I have experienced?
    Regards,
    Jeff
  2. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    Yes, it's normal. It happens to non-hybrids as well, just not to the same degree. They have more "waste heat" to keep them warm.
    If you turn off the heat when stopped the engine won't run. I use the "A/C auto" switch on the steering wheel to turn it off and on. On when the light turns green, off when I'll be stopped waiting. Once the car is fully warm I don't bother to switch it. The engine won't start as long as the coolant is above 63C (I use a Scangauge II to monitor the coolant temp).
    Double check your tire pressure as well. It drops a lot with cold weather. You don't want to run lower tire pressure in snow or on ice. Tire manufacturers will tell you their tires work best with proper pressure in snow and on ice. I use 40 PSI front and 38 PSI rear (15" wheels, Nokian WR tires in stock size). I check monthly.
  3. qbee42
    3,079
    Yes, the mileage drop is normal. We live a couple of hundred miles north of you, and our summer mileage of around 54 drops to the mid to low forties in the winter. If I make any short trips, the winter mileage can easily drop into the high thirties.
    The same thing happens with normal cars, only you don't notice it as much since the mileage is poor all of the time.
  4. Celtic Blue
    Celtic Blue New Member
    2,224
    139
    Midwest
    Palmetto,
    With regards to the heat, have you experimented with lower blower settings? If I use lower blower settings I can generally keep the ICE from starting at traffic lights. So far this has been true in both summer and winter. I've been using the second blower position. Obviously there are times that more heat or AC are needed for comfort or safety, but at times where low settings are permissable it does really seem to help mileage.
    Defog/defrost is probably the worst since both the heater and AC compressor are working simultaneously.
    With both the Prius and other vehicles I try to get rolling ASAP (as long as visibility isn't compromised) without starting the heat. The quickest way to warm the engine is to put some load on it and I would prefer to do that by driving. In other vehicles as soon as the temp gauge starts moving I switch on low heat.
  5. Palmetto
    88
    West Michigan
    David, Tom and Shawn-
    I appreciate your replies. David, I use the same tire pressure as you do. I last checked about 1 month ago, before snow, so I'll do that again.
    Tom, I'm impressed with all the snow you drive through up there that you can still hold your mileage above 40/gal. Great job!
    Shawn, I'm beyond embarrassment when I want to know something. I've read about ICE on many, many posts but don't know what the heck is being referred to. It seems I can substitute "engine" in place of ICE in your post. Can you explain?
    Jeff
  6. beckerman
    beckerman Junior Member
    56
    Short Hills, NJ
    Join the club. I went from 47-48 in August/September to 35-39 in December, but I have a daily 10-minute city commute, so my mpg is usually down.
  7. qbee42
    3,079
    ICE = Internal Combustion Engine, or gas engine in other words.
    The reason my mileage stays up is that my driving mostly consists of a 45 minute trip to Traverse City on occasion. Short trips are mileage killers. We live in a little village, and I walk everywhere. Only the trips into the "big city" are driven.
  8. nerfer
    nerfer A young senior member
    2,507
    237
    28
    Chicagoland, IL, USA, Earth
    To repeat Tom, but in other words, short trips magnify the effect of cold weather because the engine spends less time in the warm efficient zone. I'm in the same situation as Palmetto, so I'm guessing Palmetto's daily commute is between 5 and 15 minutes each direction.
  9. David Beale
    5,963
    1,989
    Edmonton Alberta
    Observations from the Scangauge II in cool weather (close to 0F).
    Yes, it takes some time to -fully- warm up a Prius. Three blocks at 60-70 km/hr (40-45 MPH) will get you nice hot air blasting out of the vents.
    After 5 min or so of -driving- (waiting at lights etc. doesn't count), the heater will not prevent the engine from shutting down at lights, though if the wait is long enough, it could restart.
    After 20 min of -driving- the engine etc. is fully warm, and it's unlikely the engine will start while waiting at lights.
    Note that the engine will cool off if you are coasting downhill a lot.
    The heater set temp being higher or the fans running at higher speed -can- cause the engine to start sooner. This is simply because when the engine stops there is only so much energy in the heater core. If you remove it more quickly, you will reach the engine start trip point (about 63C coolant temp) sooner. Don't confuse this effect to directly -causing- poorer mileage. You can operate the Prius so the heater uses -waste heat- only, and when you do so the heater has no effect on mileage. e.g. make sure the engine doesn't start when you are waiting at lights etc. I run my heater at a set point of 22C (about 73F) with no effect on mileage, because I don't allow the engine to start when I'm stopped.
    Yes, ICE is Internal Combustion Engine.
    MG is Motor Generator (there are two in a Prius). MG1 is the smaller of the two.
    An engine produces power from conversion of one form of energy to another. e.g. burn gasoline to turn a shaft.
    A motor uses power to turn the shaft. e.g. electrical energy from a battery or air pressure from a tank.
  10. Palmetto
    88
    West Michigan
    My commute is 10-15 minutes.
    The information posted on this thread is consistant. I appreciate the factual information I got here (it all fits). Thanks guys-
    Jeff
  11. qbee42
    3,079
    Hey Palmetto, what part of Western Michigan is your home turf? I spent a lot of years in the Kalamazoo area.
  12. Palmetto
    88
    West Michigan
    We moved to Grand Rapids about 6 years ago. I've been through Kalamazoo, it's not far as you know. Seems like a nice community.
    How about you? Where in N. Mi are you?
  13. Prius Prime
    Prius Prime Junior Member
    68
    Macomb, MI
    2016 Prius v wagon
    I'm in the metro Detroit area and I'm crying about my lower than normal MPG too. It's the weather. I don't think we had temps this low until February last season. We didn't seem to have much of a fall or Indian summer.
    I do have the EBH this year which really helps in the morning--but I wish I had some place to plug in while I'm at work. I also have the grill blocked.
    Driving habits make a bigger difference now than ever--watch the fast starts, coast lots, combine trips, check the tires and all.
    I was happy this morning commute--about 14-18 degrees and I still arrived at work with 51.3 mpg on the mfd.
    Has anyone ever had problems with their grill blocking foam falling out at the car wash?
    Prius Prime
  14. jdel
    jdel New Member
    49
    Be sure to install something to block you grill in the winter (pipe insulation). It will improve your winter efficiency at least 2 MPG
    John
  15. john1701a
    john1701a Prius Guru
    12,820
    5,305
    58
    For those experiencing mid-grade winters, yes.
    For those that endure the extremes (routinely seeing below 10°F) the benefit translates mostly to lots of heat for keeping you warm.
  16. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    302
    Northwest VT
    2018 Prius Prime
    Car wash? What is a car wash? :) Yeah, i would imagine if you have foam pipe insulation stuffed in the upper grill, it could be knocked out by the high water pressure. For the lower, you need to hold it in with plastic wire ties. I found 3 works well.
  17. john1701a
    12,820
    5,305
    58
    If you use the 1/2" type for each slot, you actually have to tear it out in the spring. The stuff doesn't move that way, regardless of what you hit it with.
  18. Celtic Blue
    2,224
    139
    Midwest
    Don't know about the car wash as I always hand wash, but I've had to use plastic ties on the upper grill. The compression fit works for a few weeks, then the foam works its way out enough to catch the slip stream.
  19. fthorn
    fthorn From gas hog to greenie to gas hog
    197
    I had major surgery 7 weeks ago. So, I've been laid up till about now. And I just now got in my Prius. The wife had been driving it. I asked her how she managed to take my 52 mpg down to 39!!!!!!!!!!!
    Well, I drove it for hours today. I did BARELY better than her.
    This winter mileage sucketh! :)
  20. Prius 07
    Prius 07 Member
    715
    Toronto, Canada
    You're taking a big hit not only for the colder temps but it is amlified by your short commute of 10-15 minutes. 2/3 of your trip is likely spent just warming up the coolant. I recommend you concentrate on this part of your trip and pulse the pedal in addition of taking a favorable terrain for your route (if possible). A history of my seasonal stats going into my second winter:
    I try as much as possible to limit my short trips in cold temps.
