It may be winter outside...
Discussion in 'Gen 2 Prius Main Forum' started by habel, Dec 8, 2005.
  1. habel
    habel New Member
    230
    Oslo, Norway
    I am looking to find the best way to heat the car during winter.
    As I see it, there are 2 options:
    1. Electric Heater
    This can be bought in different versions, and can be combined with an
    electric cabin heater
    2. Fuel operated heater
    On "normal" cars, this will heat both the engine and the cabin.
    I tend to find the last option the most compelling, as it will work anywhere.
    My question is how a fuel operated heater can work with the Prius A/C, as this unit is quite different from std. types.
    Anyone that has any experience and/or views on this?
  2. Oxo
    Oxo New Member
    533
    Oxfordshire, UK
    I don't fully understand the question. Are you referring to the heating of the interior (cabin) of the car when running and/or when stationary?
    If stationary will the car be standing in the open or in a building?
    What minimum ambient temperature would you expect?
    This is not to say that I will be able to answer your question but I will be interested in the replies.
    In my own case I do not expect the temperature to be lower than -10C and then only on rare occasions. I have every confidence that the car's a/c system will cope with this fairly well after I have started in the morning.
  3. jwe8f
    jwe8f New Member
    174
    Indiana
    If you're talking about the interior, I wouldn't mess with it -- the car heats up pretty good, and already has an optimized conditioning system...
    If you're talking about the engine, I would install an engine block heater that's on a timer and plugs into your wall.
    The engine block heater helps with both mileage and interior heating. Probably the best way to go overall.
  4. habel
    habel New Member
    230
    Oslo, Norway
    I am talking about stationary heaters to use outdoors - to warm (up) the car when it is cold outside. Both the ICE and the interior.
    In Norway -10C is not uncommon and sometimes down to -20C or more...
  5. habel
    habel New Member
    230
    Oslo, Norway
    Yes, the block heater is what I meant under option 1. It is a good solution - and can be complemented by an cabin heater as well.
    However - you need to be able to plug it in, and that is not always possible, that is why I am interested in a heater that uses fuel.
  6. tomdeimos
    tomdeimos New Member
    995
    Lexington, MA
    Hello there in Norway,
    I use an elsectic heater for my cabin and block heater for the engine. I have a bumper marine plug where I can plug both in. My house outlet has a time switch.
    You need to realize car heating is kind of rare over in the lower US. Some people use remote starters to just warm up the engine. My cabin heat is from a regular household electric ceramic heater. The kind you have in Norway like from Delfa are not easily available here.
    Likewise for fuel buring cabin heaters. I did see a propane engine warmer once I almost got for my diesel car that was hard to start in the cold, but rarely see anything available these days.
    I doubt even in Norway you need anything to get the car started up. But if you just want a warm car,
    either option should work. Electric requires a grid power plug nearby, so that should affect your choice.
    And here we find electric block heaters give us better mpg, but that may not be as true for European cars.
    Maybe someone up in Alaska has seen some fuel burning heater options?
  7. heatmaster
    heatmaster New Member
    If their is one thing that gets my goat---it's people that reply on a forum without doing any research! Let's do this nice and slow for those simple folk. Right click on "File" in your tool bar on your browser. Mouse over New. Mouse over Window, right click. Enter "Fuel Operated Heater" in your address bar.
    See, now wasn't that easy? :focus:
  8. heatmaster
    Actually, being as Prius is supposed to be an environmentally responsible vehicle, I'm surprised that the "non-idling" fuel operated heater doesn't come standard. In Norway you want to contact Webasto and in the U.S. you would want to contact Espar Heating Systems.
  9. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    So, for your first post here on Priuschat you chose to be critical of someone who started a thread 3 years ago? Chances are they don't even frequent Priuschat any more.
    Further, there are better search options available and built into the vbulletin software including the google tool at top right.
    But welcome to Priuschat.
  10. KAR IDEA
    KAR IDEA Member
    465
    Lake Peekskill, NY USA
    Three Touring
    Wow...that's embarassing.
    Welcome to Priuschat.
  11. qbee42
    3,079
    I would use Webasto even in the U.S.. Webasto makes a better hot water system, in my opinion. I did a lot of research with both Espar and Webasto when looking for a hot water system for our sailboat, and finally settled on a Webasto unit. It's been very good and very reliable.
  12. Presto
    Presto Has his homepage set to PC
    1,326
    24
    Vancouver, BC
    LOL. Great first impression. OP will probably create a new account now. :)
    Welcome!
  13. donee
    donee New Member
    2,956
    198
    Chicagoland
    Hi All,
    I think the lack of a direct fueled heater is a problem for winter driving. It results in allot of wasted fuel in a really cold climate. -10 C (14 F) is not really cold, in my opinion, BTW. As long as the sun is shining, and wind is not blowing, that is good walking weather. But -20C is a diferent matter, and it was -20C (-4 f) here this morning and in such conditions one would need to run the engine for a very long time to get the cabin warmed up. When that is going on, most of the heat is just being wasted out the tail pipe, rather than into the car to get the car warm. Maybe some sort of tail-pipe heat recovery system would be a reasonable compromise.
