Battery - Wondering if getting the Prius was a mistake
Discussion in 'Gen 2 Prius Technical Discussion' started by suvsBAH, Dec 31, 2008.
  1. suvsBAH
    suvsBAH New Member
    The reason for this post is I am constantly going back and forth if this purchase was a mistake. First I was driving some sort of SUV for 11 years, and then bought this 08 Prius for gas prices were getting way too high, and I was driving so much that 11 miles on the Prius I bought went to 30k plus in one year (that is how much I used to drive for my job). As a result I ended up with car payments and paying for gas because of the cost of this car. I could have just turned in my SUV for an affordable Honda Civic (non-hybrid) and had that already paid off. Now someone is telling me they read on consumer reports that after x-amount of years I will have to replace a battery on the Prius that will cost me 5k? Is this true???
    Man I hope I didn't make the biggest mistake of my life.
  2. alanh
    alanh Active Member
    1,175
    99
    Phoenix, AZ
    Everything on a car fails eventually, so yes, you'll have to replace the battery after "x" years. However, "x" may be 10 or more. There's no indication that the battery has a short life, and Toyota warrants it for 8 years/100k miles (or more in some states). There are cabs that have gone over 200k miles without a battery failure.
    The MSRP for the battery is $2000. Contrast that to a transmission rebuild a conventional car would probably require.
  3. EJFB1029
    EJFB1029 New Member
    4,726
    206
    Corpus Christi, Republic of Texas
    You didn't, the majority of batteries have been known to last well over 100,000 and more, there is a battery warranty that is way longer than the 3yrs/36,000, look it up in the manual, and a replacement battery is less then $3000, even if it were out of warranty.
    The Prius battery is designed to last the life of the car. According to Toyota, this is around 180,000 Miles.
    Hybrid-Related Component Coverage: Hybrid-related components, including the HV battery, battery control module, hybrid control module and inverter with converter, are covered for 8 years/100,000 miles. The HV battery may have longer coverage under emissions warranty. Refer to applicable Owner's Warranty Information booklet for details.
    California Emission Control Coverage: In California and any other state that adopts California emission warranty provisions, defect and performance
    warranty is 15 years/150,000 miles. The Hybrid Vehicle Battery is warranted for 10 years/150,000 miles.
    I don't really see where you went wrong, even if gas sold for 50 cents, you are still technically paying 25 cents for gas.
  4. JSH
    JSH Senior Member
    2,605
    140
    PDX
    As others have said, their is no reason to worry about the battery.
    As to the Civic vs. Prius question, there is no doubt that it would cost you less overall to drive the Civic.
    That is why I routinely kick myself for buying my Prius. It is a perfectly acceptable car but not what I should have bought. I went shopping for a $10K used Civic Coupe and ended up with a $20K used Prius. The Civic would have been paid off by now, while I'm still paying on the Prius. I got all excited about hybrids when I rented a Civic Hybrid in CA and got 49 mpg.
  5. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    I have a subscription to Consumer Reports Online. Where - exactly - did this person find the "information?" Nowhere that I could find
    Like any vehicle, it's rare for it to "pay" for itself. In that regard, the best vehicle is NONE AT ALL. If you're in my situation, and you can depreciate a vehicle while claiming mileage, the Prius is a very good bet. Mine certainly "paid" for itself in that way
    I could have purchased a giant SUV, and would have broke-even with it. For example, if I started driving my FJ all the time for work, I could write it off. In the end, it's entirely up to what you want
    BTW: a Civic is quite a bit smaller inside compared to a Prius, and there is no efficient hatchback design in the Civic. That Civic trunk is pretty small
  6. richard schumacher
    7,664
    1,046
    United States
    No, the battery will be fine for probably more than 10 years. Yes, a Prius is not the cheapest possible vehicle. But gas prices will go up again and then you'll feel better about it.
    Before any large purchase one should spend a lot of time thinking about real needs, wants, finances, and priorities, and investigating facts and alternatives. After the purchase is often too late :_>
  7. qbee42
    3,079
    I'm glad you guys answered this one. The wording on the OP was so confusing I had to read it three times to get the thrust of the question.
    As to my answer, if you are just trying to save money, buy a used Honda Civic. An old car is always more cost effective than buying a new car. Get one with a beat up body but good mechanics, drive it into the ground, and do the same thing again.
    If you want a new, reliable, and efficient car that is still economically sound for a new car, then the Prius was a good choice. The cost of a new automatic transmission for a conventional car will be worse than a new battery for the Prius, and it will happen much sooner.
  8. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    First of all, welcome to Priuschat. :welcome:
    We're a friendly lot. Honestly.
    Unfortunately, you've struck a nerve. The responses, so far, have been very polite. I'm sure this is based on your Prius ownership. You see, we get people coming by every once and a while proclaiming that the battery has to be replaced every 3 years, that Toyota is solely responsible for devastating the entire Canadian landscape to rubble, of requiring more natural resources than a Hummer, and a myriad other silliness. So we tend to get a little defensive anymore when someone starts regurgitating the false information that's still circulating.
    Now, wanna hear the funny part?
    It's been proven that some of the "think tanks" producing the original misinformation were funded by GM in 2004 when the current Prius model made its initial splash in the American market. All that stuff was put out there with the knowledge that by the time someone was able to disprove it, they would have published some other damning piece of misinformation. It's a truly brilliant slander tactic until they start producing hybrids. Now all of a sudden you stop reading articles about the evils of hybrids. Funny, huh? Not really.
    So anyway, a long time ago when the Prius was just being released in the US, the car was put through several tests. One was to discharge and recharge the battery several times. This was done up to the point where they felt they had simulated 100,000 miles of driving under various conditions. When they tested the charging capacity of the batty pack, they found that it was still able to hold more than 95% of its original charge. This is why Toyota is so confident in their 100,000 mile warranty.
    I'll have to search for those test results. I read it online back in 2004 when I got mine and hopefully burned it to PDF.
    So don't worry. You did not make a mistake. With gas prices as low as they are, you are saving money. When prices go up again, you will be saving even more. Enjoy.
  9. Clar
    Clar Member
    151
    DC/MD/VA
    I got a prius in Jan 2006 and I have 70k on the car now. not as many miles per year as you but still plenty. My buddy got his in 2004 and he has 240k miles on the car and still on its original battery.
    I'm not saying that your battery will last that long. If I get even 150k out of my prius' battery, I'll be very happy.
  10. bwilson4web
    16,318
    Good choice. You are one of the folks who like me, drive a lot of miles each year.
    A new battery from Toyota goes for about $2,200 plus labor to install. The price continues to decline and we're finding the best way to drive to minimizes battery stress, if you are interested.
    It is false!!!
  11. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    The only mistake you made was listening to people who don't know what they are talking about. You should also be enjoying low maintenance costs.
    The only maintenance/repairs I'm expecting to pay for is fluids & filters for many years to come. Enjoy the low gas prices. Right now I'd have a tough time pumping $12 worth of gas into the car.
    The only downside I experienced was that I can't qualify for the promo item when a 10 gallon fill-up is required.
  12. spitinuri
    spitinuri Member
    317
    I'm not quite sure what you are asking. My question is: "Do you feel like you overspent on your car purchase?" If you did sell it and buy something cheaper. There's nothing wrong with an older Civic or Accord. Do what makes you happy or at least reduces your worries. Peace!
  13. donalmilligan089
    239
    22
    virginia usa
    I rebuilt a 2005 and the hv battery had been discharged to the point of ruin. Autobeyours put me in a used hv with only 17,595 miles for $1050 installed. Not to worry there are more and more wrecked prius with good hv batteries, There is a big rebate for used up batteries due to reclaming valuable materials. Seems that I read that toyota pays up to $600
  14. Conservatively Fiscal
    Conservatively Fiscal Intellectual
    Providence RI, Portsmouth NH
    Responses are amazing. Ty brothers, Amen.
  15. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    302
    Northwest VT
    2018 Prius Prime
    I would say 'no'. Like others said, the info you got is bad, repeated from a source that heard it from a source that heard it from ..... Only two batteries have failed in Australia, both in cabs. One at 350K kilometers and one at 550K. I believe this is out of 10,000 Prii sold in Australia.
    Toyota Prius taxi tops 340,000mi, dispels battery myth - MotorAuthority - Car news, reviews, spy shots
    Granted a used Civic would get maybe 50% better mileage than my old '95 Odyssey, but here is what I have saved based on the Prius mileage and the Odyssey mileage. Other vehicles I was looking at to replace the Odyssey would have gotten mileage similar to the Odyssey.
    Over 4 years and 82,065.7 miles I have saved:
    2427.34 gallons of gas
    $6,492.53
    What that means is that my 'loaded' car cost the equivalent of $20K just based on the money I have saved on gas. If I had purchased the base model, the cost would have been $15K.
    Granted gas is way cheaper now than it was 2 months ago, but not much cheaper than it was when I bought the car. It WILL go back up. It is down now because there is less demand... NOW. First due to the skyrocketing prices, and now due to the horrid economy. The only way gas will stay cheap is if we, and everyone else in the world, stop using it. That is highly unlikely and both China and India (totaling about 40% of the world's population) are starting to use a lot more.
    I have also saved money due to fewer oil changes and fewer other maintenance items. One way to save money is to wash and reuse the cabin air filters and NEVER let the dealer charge you 15 minutes of time to replace it. You can do it yourself in 3 minutes, no tools required.
    I presume you have also noticed how much usable space there is in your Prius, space you would NOT have had in the Civic. Shy of 4x8 sheet goods and a greenhouse window, there is nothing I have purchased in the last 4 years that would not fit inside my Prius, most of the time with the hatch closed.
  16. eanjay
    eanjay Junior Member
    Nova Scotia, Canada
    This I'm not sure about?
    Me, I have a new 2009 Prius sitting in 4ft of snow at the top of my steep snow filled driveway. In the 600 miles of driving so far, I'm getting 43.5mpg(US) at 5deg(F) on Blizzaks. The wife likes the car, my kids like the green concept - what's not to like about that.
    EanJay
  17. donee
    donee New Member
    2,956
    198
    Chicagoland
  18. TJandGENESIS
    TJandGENESIS Are We Having Fun Yet?
    5,299
    47
    ★Lewisville, part of the Metroplex, Dallas, in the
    I would hope some day this kind of thread won't be needed.
  19. bwilson4web
    16,318
    suvsBAH Junior Member
    My Car:
    Package:
    Nominated 0 Times in 0 Posts
    TOTM Awards: 0
    Friends: 0
    Missing from this post is any description of vehicle MPG. If driven at high speeds, '30,000 miles in one year', then a Honda Civic might have been a fine choice.
    No.
    I spent four years in the Marine Corps after an unfortunate relationship fell through. Your 'problem' is trivial and easier to solve.
  20. miscrms
    miscrms Plug Envious Member
    2,079
    526
    Phoenix, AZ
    +1 to that. Everything I have read from CR states the Prius is one of the most reliable cars out there, is the cheapest mid-sized/family car to own and operate, and has one of the highest customer satisfaction rates of any car ever.
    Rob
