What is the "B" on the gear shift joy stick?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ecodeb, Dec 31, 2008.
  1. ecodeb
    ecodeb New Member
    midwest US
    I looked around the chat expecting that someone would have already asked this, but I couldn't find it. Forgive me if I'm asking what's already been covered.
    What the heck is the "B" on the gear shift joy stick? I know R is reverse, N is neutral, and D is drive, but what is B??? I read the manual thoroughly and there is NO MENTION of it.
    Nobody I know can answer this for me, including the dealership. I have a 2004 Prius, and I don't know what package. Base, maybe?
    Help?
    Thanks
  2. rrobin1057
    rrobin1057 New Member
    24
    Park Forest , IL
    I know what the B is I also try it out a few times it is just like a engine brake on a big rig / when you have a hard time of slowing down on ice or snowing roads or on a down hill just shift it into B and let up on the Gas Pedal and it will slow it down slowly but don't use it all the time it will decrease your MPG , any more ?'s about just let me know my name is Robert.
  3. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    B mode is engine braking; using the compression of the gas engine to slow the car down, much like a 'Jake brake' on large trucks. I hunch most people don't find it all that useful, but the intent is to slow the car on long descents.
  4. patsparks
    10,664
    567
    Adelaide South Australia
  5. ecodeb
    ecodeb New Member
    midwest US
    Wow, thank you! I don't understand why there is no mention of this in the 2004 manual. How would anyone know to use it, unless you have driven a big rig?
    Does it the "jake brake"-type feature work when the engine is running on electricity or only when the gas is powering the engine (i.e. as I excelerate)?
  6. KTPhil
    KTPhil Active Member
    1,379
    22
    It is in my '05 manual, which is probably identical to the '04.
  7. patsparks
    10,664
    567
    It's in my 04 manual but I'm an Aussie.
    It isn't a Jacobs brake but like downshifting in a conventional auto. You dump energy through the engine instead of the brakes. There is only an affect when your foot is off the accelerator.
  8. richard schumacher
    7,664
    1,047
    United States
    See p.137 of the 2004 US manual. It does not describe when or why one should use "B". The only time it should be used is to avoid riding the brakes on a long downhill. Riding the brakes can cause them to overheat.
    As a former resident of Wisconsin and Minnesota I can confidently state that there is no place in the midwest where one ever needs to use "B". The Black Hills, Appalachia, the Rocky Mountains, yes. I would not use it on snow or ice; the effect is like an immediate moderate application of brakes as soon as you take your foot off the gas, which is often a bad idea on a slippery surface.
  9. halpos4
    halpos4 "Taxi"!
    377
    25
    Ireland
    As a Taxi driver i find the use of "B" mode very useful for slowing down more so when i have 4 adult passengers onboard,i know it dumps energy through the engine and uses a bit more fuel but i'll take that,working at night in Dublin city,there's always some gobshite who'll walk out in front of you and a bit of extra stopping power doesn't go amiss!!
  10. qbee42
    3,079
    It is similar to a jake brake in that it uses pumping losses in the engine to burn off excess energy. It differs as explained above in that it uses the electric motors to do this. Yes, it works in both gas and electric modes (technically it's a bit more complicated, because the gas engine will be spinning without gasoline, which could be considered electric mode.)
  11. Carleff
    Carleff Junior Member
    Alameda, California
    Look at page 140.
  12. maseace
    maseace Prius enthusiast
    191
    Poulsbo, WA
    Also on page 15 of the pocket reference guide.
  13. Patrick Wong
    18,210
    6,512
    If you have experience driving a conventional automobile, then you may know that when you are descending a long hill it helps to shift into second gear or low gear so that your brakes do not work so hard to slow the car. B serves the same purpose as downshifting a conventional automobile's transmission.
  14. richard schumacher
    7,664
    1,047
    United States
    I'd use it if I needed the brakes for more than about 30 seconds continuously, or more than 50% of the time over one or more minutes. If the brakes start to fade or smell bad then it is overdue.
  15. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    I've yet to cook the brakes on the Prius, which is great. In our last car, I inevitably warped a disk nearly every camping trip, coming down the mountain passes. I'm definitely a convert to B mode and resistance braking.
  16. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    It should be noted that you're not merely dumping energy in all cases, just excess of what isn't going to the battery. B mode starts max regeneration, and whatever cannot be diverted to the battery ( > 60A) is used to spin the engine via the generator. Once the battery is "full", the engine will speed up (up to max RPM if at a higher speed) as all of the "generated energy" is being sent to the engine for resistance.
    There is a downside to B mode, it will keep your engine idling much longer at a stop, and you lose the fuel saving benefits of idle stop in stop/go traffic.
    In practice, I may use B mode from time to time to "force" max regen when decelerating on an offramp to a stop but use light brake pedal effort as well to keep the brake lights on for cars approaching behind me. I'll also use it coming down grades where I don't want to "ride the brakes" and want more "holdback" than standard off-pedal regeneration provides in "D mode".
  17. cagboulder
    cagboulder Junior Member
    Louisville, CO
    A service manager claimed that if I didn't use B mode on the downhill from 1 mountain pass, I wouldn't make it up the next one with any speed here in the Rocky Mountains of Colorado. Any truth to that???
  18. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
  19. richard schumacher
    7,664
    1,047
    United States
    Not really. He may have meant that you wouldn't make it because your brakes would overheat and fail, but that would be a very indirect way of saying it. Use "B" to avoid riding and overheating the brakes.
  20. visormate
    visormate New Member
    it is a Braking system using the generator.
    same as when you put on your brakes, but not as such a drastic slow down..
