To EV or Not to EV. That is the question
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Blue-Adept, Apr 1, 2005.
  1. ScubaX
    ScubaX Member
    484
    Redding, CA
    In the United States you can not void a warranty! You can only deny a repair of a particular item if you can prove that what the owner did to a warranted vehicle damaged that particular item.
    So, if they claim the EV damaged the battery and they deny the warranty you could sue them. In California I can sue them in small claims for up to $5,000 damages for around $22. No lawyers are allowed in court. They would have to send a CFO at minimum to court and show a judge that you had EV, used EV and that EV damaged the battery. Federal law requires a burden of proof on the denier of the warranty repair. Then of course if you’re using Toyota's own switch, and show they use it in other countries, the judge is not likely to believe that it caused damage. If it would, why use it in other countries? Are they even going to show up in a small claims court? Not likely. They then will lose and have a judgment against them which you can collect on. Now talk about bad publicity.
  2. KMO
    KMO Senior Member
    1,883
    643
    Finland
    2023 Prius Prime
    Indeed, they will probably try to do so where possible. See the quote above in Brent's post, which suggests such things as "vehicle abuse", "off-road driving", "overloading" and "improper maintenance" as other reasons warranty coverage might be denied.
  3. Blue-Adept
    Blue-Adept Active Member
    293
    179
    Grand Rapids, Michigan
    2018 Prius Prime
    What is the Mac Mini?
    Blue
  4. Blue-Adept
    293
    179
    2018 Prius Prime
    Where can I find a Mac Mini? How much?
  5. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    www.apple.com mac minis runn for about 800 for the good one fully loaded. that included bluetooth.. wireless keyboard and mouse.. er.i think 800. have to find a way to interface it though. Dave might be working on that. I know it was mentioned to him. My friend Emailed him a while back.
  6. Tideland Prius
    16,501
    ok then, that warranty issue is off my mind. Now where's Coastal Dave :p
  7. mikepaul
    mikepaul Senior Member
    1,763
    Columbia, SC
    I dusted my iPod mini the other day, wondering the same thing...
  8. DanMan32
    DanMan32 Senior Member
    3,799
    27
    Tampa Bay, FL
    I hope the mac mini interface could work with a PC simply by having the appropriate driver SW.
  9. ScubaX
    ScubaX Member
    484
    Redding, CA
    How come you need the Mac Mini to work with a PC? It may need to work with PC software though, as I don't believe my mapping software comes in a Mac version.
  10. DanMan32
    3,799
    27
    Tampa Bay, FL
    Not the Mac Mini, the interface FOR the Mac Mini. Often all HW needs to work in a different platform is appropriate driver.
  11. ScubaX
    ScubaX Member
    484
    Redding, CA
    <div class='quotetop'>QUOTE(DanMan32\";p=\"79774)</div>
    I'm not overly familiar with Mac technology, but Mac and PC's have different architectures that make internal hardware either Mac or PC. External hardware may work either way if using either USB or FireWire and even SCSI with the appropriate drivers.
    Now as for software, it is written for either Mac or PC but will not run on both without a complete rewrite of the code. The exception to this are emulators. The Mac lovers really love to point out that they have software that can emulate a PC and run PC programs - as long as they are not too graphic oriented. PC lovers don't care that they can emulate and don't need to emulate because 98% of the software written is made for PC's and those that are made for MAC's eventually get made for PC's.
    For a car computer, you would have to look at the purpose of the computer and most importantly, the software you want to run. The primary software I want to run are Delorme SA mapping software which is very graphic intense. If the MAC could emulate it, it would not be very good. The other software is for the cars diagnostic software. Does that come in a Mac version? Probably not.
  12. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    <div class='quotetop'>QUOTE(ScubaX\";p=\"79822)</div>
    most hardware will work with either Mac or PC, its the software you have to match
  13. ScubaX
    ScubaX Member
    484
    Redding, CA
    "most hardware will work with either Mac or PC, its the software you have to match"
    So when I take the AGP display card out of my PC and put it in a Mac's AGP slot it only needs drivers? So its not affected by the CPU, MB/Chip sets, Bios, RAM settings of the Mac? Then ATI should save some money and package just one product with multiple drivers.
    I know HD's will. But I know my video capture will not.
    Do Mac's have PCI slots?
    Next thing you know :guns: Microsoft will slap Windows on there and it will be a PC :pukeright: :pukeleft:
  14. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    yes the card will work as long as the Mac has an AGP slot. the only thing that cant be swapped easily is RAM and CPU's. but being a Mac or PC doesnt matter as both nowadays have to be matched up with a compatible Motherboard.
  15. Tideland Prius
    16,501
    Question. Does anyone know the exact shipping cost to ship the EV mod to Canada?
  16. ScubaX
    ScubaX Member
    484
    Redding, CA
    I ordered the stock EV button and wire harness (no wires just the connector) JapanParts on April 6th and I received it on April 11th. Only 5 days from Japan. Cant beat that. I didn't even have time to get the rest of the stuff I need first.
    Mike
  17. Blue-Adept
    293
    179
    2018 Prius Prime
    I ordered my ev mod from costal tech 3 weeks ago. Still have not heard back from them. I ordered like 6 things. No reply at all. How fast did any of you get the parts.
    Blue
  18. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    Just to clarify for those that are not Mac literate. The Mini has no slots. It is just 6 1/2" square and 2" high. It has most of the interfaces that you will need. The Mac OS X (ten) is a UNIX based OS. You can run the Mac OS on a emulator, don't know the name, I have no need. Virtual PC will run many Windoz programs on a Mac via emulation but not all, at least not well. The 800 dollar price is for a fully loaded system. Bluetooth, Airport (WiFi), DVD-R drive etc. Does not include monitor, keyboard and mouse. I am going to get one to add to my home entertainment system to be used as a audio jukebox and TIVO. I will add one to my car when the interface is worked out. DVD player, iTunes for a audio jukebox as good as an iPod, who knows with a cell phone serf the net? The form factor is "insanely great". And yes I am totally under Steve's reality distortion field at all times.
  19. hschuck
    hschuck Member
    385
    bay city, ca
    I also ordered the ev mod from costal tech (on 3/26). No response from costal so I followed-up with email asking for status. I received a quick email response that the ev mod was on backorder and would be shipped when available.
  20. Electric Barbarella
    Electric Barbarella New Member
    Lawrence, MA
    EV is available in both Australia and the UK. They describe 100km/gal in Australia portion of the Prius.com website. They brag about 65.8mpg in the UK portion. I'd like to see a copy of the owner's manual for either of these countries, and see when manual EV is recommended.
    EV and the flaps are on order, with probably more comfort tweaking later. Caught a couple of young ladies rubbernecking to get a better look yesterday.
