Any unsatisfied claims?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by hobbit, Apr 4, 2006.
  1. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    Just wondering if anyone's purchased the extended warranty
    [via PC or elsewhere] and then had any trouble having a claim
    honored for some reason. In other words, lemme hear your horror
    stories if you've got 'em. Hopefully nobody does!
    _H*
  2. NuShrike
    NuShrike Active Member
    1,378
    <div class='quotetop'>QUOTE(hobbit @ Apr 4 2006, 04:06 PM) [snapback]234955[/snapback]</div>
    Sorry, not yet. This car is too trouble-free.. and I've only just passed 36K.
  3. huncityprius
    huncityprius New Member
    I have a 2008 Prius, it is now 7 months old and I've had a whole host of problems. First it seemed that my dash display lights were not coming on from time to time. Now they disappear at will also my info center has a black line scrolling through it and at times it has been disappearing. I have noticed in the cold weather that the car tends to surge as it changes modes. Is anyone else having these issues or am I the one in a dozen with a lemon???
  4. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Your surging in cold weather during shut down and such is normal and it will get better when the engine warms up and as the vehicle breaks in.
    Someone else recently posted about a horizontal line on the MFD, but it's an issue I'd not heard of until then.
    The dash display may be your dimmer control or it could be a problem with a fuse or connector. Since the car's so new you should be able to get both the MFD and dash things fixed easily.
    I don't hear anything to suggest you have a "lemon", but it's certainly possible you have a couple minor issues that the dealer should fix.
  5. patsparks
    10,664
    567
    Adelaide South Australia
    It's a Toyota, not from the big 3. If you have a lemon it's 1 in 500 to 1000, not one in 12.
  6. butchbs1985
    butchbs1985 Taking things apart is fun!
    232
    ChicagoLand
    2013 Prius v wagon
    I bought the extended warranty from Toyota when I purchased my 2005 used. I have never had bad luck with Toyota at all but I was a bit apprehensive about the hybrid system (Didn't find PC soon enough). I'm approaching 92,000 miles so the warranty appears to have been a waste of money. (100 K warranty).
  7. rigormortis
    rigormortis Active Member
    1,340
    26
    san jose, ca
    48,000 miles
    warranty work so far, cost zero
    replace radio (not really needed, cd changer can cause radio to lose presets)
    alignment
    reinstall the power window switches/pad that fell into door handle last week
    a toyota dealer replaced my 12v battery, bad cell
    stuff i have actually paid for in 48,000 miles
    some rotations
    some oil changes
    4 toyota wheel ornaments
    window tint
    new set of tires @ 24,000 miles, old ones were worn down
    lots of car wash supplies haha
  8. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
    I went to my dealer once to get a wheel alignment under the wheel alignment TSB. My dealer told me that he thought that it still was not covered and that I would have to pay for it. I went back again and told the dealer that the wheel alignment was now expressly warrantied for 12 months/20,000 miles (it says so right in the warranty information booklet). He said he didn't know that.
    I read on PriusChat about someone who tried to get his glovebox fixed under the extended warranty. The dealer said it wasn't covered and that the part in question was in fact expressly excluded under the extended warranty. The PriusChatter went back home, did some research and found that the extended warranty expressly included the "glovebox assembly". He looked at the picture of the "glovebox assembly" and saw the part that the dealer had said was expressly excluded. So he went back to the dealer and made his case for a whole new glovebox assembly, and got everything fixed under the extended warranty.
    I think the morals of the stories are:
    1. The basic warranty and extended warranty are frequently unclear and ambiguous about what's included and what's excluded.
    2. Dealers frequently don't know what they're talking about and/or they flat out lie.
    3. If something goes wrong with your Prius, one should research the problem, including the exact language of the basic warranty and extended warranty, and be prepared to argue your case to the dealer.
  9. richard schumacher
    7,664
    1,045
    United States
    So far the horror stories are mostly the predictable ones: namely, not recovering the cost of the extended warranty :_>
  10. windstrings
    6,280
    378
    Central Texas
    Had a window that had a mind of its own.... bad module deep in the dash.. cost 800.00 to fix and the part was special ordered, but under normal warranty.. I haven't had to use the extended yet.
