Scangauge not connecting ?????
Discussion in 'Gen 2 Prius Fuel Economy' started by shar1950, Jan 12, 2009.
  1. shar1950
    shar1950 Junior Member
    merritt, bc canada
    I just got my new scangauge and I plug it in. I first turned on the car,then plug the unit into the obdII plug. It just keeps reading and will not connect and get reading. I tried disconnecting a few time but every time it just reads " connecting " Anyone have this problem and how can it be fixed ?:mad:
  2. Neicy
    Neicy Member
    834
    Wakefield, MA.
    Try connecting before powering up the car. It should have trouble-shooting tips in the back of the manual.
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    My scangauge takes a while to connect. Maybe 20-30 seconds and then its ok. Just be patient and let it sit for a while. Also the phone style connector on mine is loose too so I have to make sure its pushed all the way in.
    Not many reports of bad SG's though.
  4. shar1950
    merritt, bc canada
    what are some of the setting that you use, that the scangauge uses to get it's info ??? that the mode setting ?
  5. shar1950
    merritt, bc canada
    can some one read their mode setting and let me know, I would sure like to have this unit working with a block grill and see what the temp is at.
    thanks if you can help................
