It has a flying buttress!
Discussion in 'Gen 3 Prius Main Forum' started by richard schumacher, Jan 12, 2009.
  1. richard schumacher
    7,664
    1,046
    United States
    I'm sold :_>
  2. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    It has a moonroof/sunroof. :p
  3. richard schumacher
    7,664
    1,046
    United States
    The Solar-powered cooling option requires the moonroof, true? Does anyone know the details? For example, does it draw outside air through the cabin air filter? Does the moonroof have to be open to exhaust the air?
  4. EZW1
    EZW1 Active Member
    722
    81
    Phoenix, AZ
    2016 Prius v wagon
    Four Touring
    I doubt very seriously the moon roof need to be opened - that would compromise vehicle security. Every late mosel car on the road has an external vent in the rear with a one-way flapper. It's purpose is to allow you to draw air in through the vents with thw windows rolled up - just like using the defroster in the winter.
  5. richard schumacher
    7,664
    1,046
    United States
    Good point. I was thinking of some distance that would not compromise security, say an inch, and including baffles to prevent line-of-sight and rain entry. Exhausting at the highest point in the cabin would be the most effective.
    The point of a moonroof as opposed to a Sunroof is that it can't be opened enough to admit a person, true? Or am I confused?
  6. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
    I use the terms interchangeably. But I understand that the original distinction was that a moonroof has a sliding glass panel while a sunroof has a sliding metal panel.
  7. Tideland Prius
    16,549
    Yup
  8. richard schumacher
    7,664
    1,046
    United States
    Ah, thanks! So will the moonroof open enough to admit a person?
  9. qbee42
    3,079
    Yes, depending on the size of the person. I could go through, but I'm not sure about Jayman (he would be more likely to tear off the door and eat it).
  10. Boo
    5,051
    488
    97
    Flushing, NY
