2010 Prius Audio System PReview
Discussion in 'Gen 2 Prius Audio and Electronics' started by Doc Willie, Jan 13, 2009.
  1. Doc Willie
    1,717
    144
    Out there, somewhere
    First Impression Review of the Prius 2010 JBL 8 speaker sound system.
    I had the opportunity to listen to the sound system in the 2010 Third-generation Prius at the Reveal of this model.
    First, my qualifications. I am an amateur jazz musician and recording engineer. I have engineered one commercial CD. I do not consider myself an audiophile, but I do like decent sound. I had the 9 speaker JBL system in my 2007 Prius for about 8 months, which was replaced with a custom JL Audio 400 watt system with subwoofer which I have had for about the same length of time.
    I had access to the 2010 Prius for about three hours, during which I got perhaps a half hour of listening in with a Test CD which I had brought with me containing music of various genres selected to test various aspects of the sound system.
    The major limitation was the listening conditions. First I was not actually driving the vehicle and second, most of the listening time was done with rear hatch or some of the doors open. The sound probably would have been tighter with the car closed.
    Visibly, the sound system has clearly been re-designed. The front tweeters have been moved from the door pillars to the front corners of the dashboard, a sonic improvement. The rear tweeters have a larger housing. The middle front speaker which many of us disconnected is gone. The entire dashboard has been rearranged, so the MultiFunction Display (MFD) through which the audio system is accessed has been moved lower in the cockpit.
    Loading CDs is a little counterintinuitive the first time around. Pressing the audio button does not bring up an Eject command. Pressing the Close button does (sort of like clicking the Start button in Windows to shut the computer down). Then a screen appears with the present CD displayed, and and Eject option or two, depending on how many CDs are loaded. Touching Eject on the screen evoked the "wow" factor as the screen moves up and tilts forward, revealing the CD insert/eject slot behind it. After loading CDs, pressing Close restores the screen to its viewing position. MP3 folders and tracknames can be read from the display as in the 2nd Gen Prius, although the graphics and layout are different.
    The next wow factor comes in using the steering wheel mounted switch clusters. Placing your thumb over the switch causes an image of the switch cluster to appear on the dashboard display, beside the speedometer readout. The button that you are touching is illuminated, and will change as you move your thumb around the four quadrants of the switch, so you know exactly which switch you are about to push without looking at the steering wheel. The volume can be changed, and the track being played can be advanced or moved back. Pressing and hold the track advance switch moves to the next CD. In short, the problem of dim steering wheel switches has been solved with a brilliant leap of technology.
    The sound of the system is considerably improved over the previous 9 speaker system. Stereo imaging is improved. It seems to have about the same overall power, which is to say adequate for most listening, but without much reserve. Playing the Introduction of Also Sprach Zarathustra reveals the bass system capable of reaching that note, although some what weakly. The 4th movement of Beethoven's 7th Symphony sounded a little muddied in the complex swirling passages. There was enough punch to the bass drums of several rock and R&B passages. Jazz bass seemed to lack a bit of definition. I am comparing here to the custom sound system in my present Prius.
    Overall, I would say the quality of the sound is better, say by 25%-40% than the old system, but still below my custom system. It should prove adequate for most casual listening. It lacks the sonic excitement of a custom system, and audiophiles will not find it exceptional. Bass addicts will probably want to add a powered sub-woofer. The ergonomics of the system are outstanding.
  2. spwolf
    spwolf Senior Member
    3,156
    440
    Eastern Europe
    thanks for impressions
  3. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    I was watching some of the testing, some of it caused those in the drivers seat to rotate cars <g>, but very nice none the less. Thanks for the impressions.
  4. Tideland Prius
    16,547
    Thanks for the writeup! I was wondering why there was loud music coming from the blue car =P
  5. petteri
    petteri New Member
    203
    Plantation, FL USA
    Any word on iPod integration or what the USB port can do? Thanks!
  6. qbee42
    3,079
    Me too. I looked over there, but couldn't see Doc through the crowd.
  7. jelloslug
    jelloslug It buffed right out!
    813
    55
    Greenville, SC
    The best thing I liked is the fact that the radio is independent of the rest of the instrumentation. This will make integrating an aftermarket system much easier.
  8. zenMachine
    zenMachine Just another Onionhead
    3,355
    300
    Great write up. Thank you.
    For those of us who definitely will have to disintegrate and reintegrate the sound system, how easy/difficult would it be? Is BT so integrated with the amp that we'll have to resort to Cleansweep etc. to bypass the problem?
  9. Doc Willie
    1,717
    144
    Good questions that I didn't ask. I was not even aware that the radio was independent of the rest.
  10. Tideland Prius
    16,547
    I wasn't sure if USB meant USB integration (i.e. using a flash drive) or they mean iPod USB plug.
    Also note that you are able to stream music via Bluetooth Audio
  11. petteri
    petteri New Member
    203
    Plantation, FL USA
    Thanks for the info! Where can I find more about the Bluetooth streaming option? That sounds very interesting!
  12. HTMLSpinnr
    5,341
    920
    251
    Despite being somewhat separate, I didn't catch that the audio system was in any way less integrated. It still displays on the MFD presumably via AVC LAN, and I didn't find any DIN sized trays to install something after market. You still have the same amp on the floor, so I'd suggest that you're no better off w/ this version than before for upgrading.
  13. Tideland Prius
    16,547
    No idea lol. It didn't occur to me to take a photo of the screen nor ask more info (but i'm sure it's just as simple as pairing the laptop/PDA with the car. It has a reserved name called Car MultiMedia)
  14. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    I was in the rear seat of the blue car during a short segment of Doc's testing... sound was incredible.
    It even rendered the Star Trek sounds nicely :)
    The CD load feature invoked an "Ohh, SHINY!" response from me.
  15. qbee42
    3,079
    This is an important point. The new model features "normal" knobs and buttons to make adjustment easier and more familiar for those coming from a "normal" car, but I believe those are just additional inputs into the integrated audio system. In every other respect the audio system appears to be completely entangled into the MFD and AVC LAN.
  16. zenMachine
    3,355
    300
    How disappointing...
  17. HTMLSpinnr
    5,341
    920
    251
    This seems to be a wide-spread trend for mid-grade and higher vehicles.
  18. qbee42
    3,079
    It makes sense from a design and engineering point of view. The only place where it is a problem is for after market upgrades.
  19. Flying White Dutchman
    4,376
    313
    you needed to make a high quality sound recording....
  20. zenMachine
    3,355
    300
    Oftentimes what makes sense from an engineering point of view doesn't make sense from an end user's point of view. There's always a trade-off somewhere.
