Finally a battery we can use!
Discussion in 'Gen 2 Prius Main Forum' started by windstrings, Jan 19, 2009.
  1. windstrings
    6,280
    378
    Central Texas
    Now here's the battery I've been waiting for!
    Can Recharge to 90% in 5 minutes!...... "if you can find that much juice at one time!
    Here's another that does the trick in 2.5 hours.
  2. rigormortis
    rigormortis Active Member
    1,340
    26
    san jose, ca
    this was before lithium ion.
    but i once charged a laptop battery that belgarion gave me with my car battery. i jumped it to the car battery and then let go "when it felt warm", i believe i was able to get 3 charges before it died. heh
    it was charged to 100 % in under 30 seconds if i can remember correctly.
  3. windstrings
    6,280
    378
    Central Texas
    This one has some good features:
  4. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    I was at CES and Toshiba was quoting 90% charge in 10 minutes for SCiB batteries vs. 90 minutes conventional lithium ions batteries.
    I recall them also claiming that after 6000 cycles, they've only lost 20% of their capacity. Most of the other reports and press releases I'm seeing seem to only indicate a 6000 cycle lifetime (which is still VERY impressive) and nothing about the even more impressive 20% capacity loss after 6000 cycles.
  5. clett
    clett New Member
    537
    Scotland
    The Toshiba batteries use lithium-titanate, same as Altairnano's batteries.
    Altair recently showed a 30 kWh (enough for 150 miles EV range) titanate battery being charged from zero to full in under 10 minutes and the pack barely got warm!
    For this rate of charge you need a standard 3-phase 440V connection.
  6. rigormortis
    1,340
    26
    san jose, ca
    that would be neat if they made this into regular laptop battery packs. like something that will fit my old dell 700m
  7. Mike Dimmick
    Mike Dimmick Active Member
    963
    249
    Reading, UK
    The standard in the battery industry is to declare the battery end-of-life when it can no longer charge to more than 80% of capacity. See for example here:
    "The amount of charge a battery can hold gradually decreases due to usage and aging. Specified to deliver 100% capacity when new, the battery should be replaced when the capacity drops to below 80% of the nominal rating. Some organizations may use different end-capacities as a minimal acceptable performance threshold."
    So the other reports are correct but incomplete.
    For an interesting analysis of hybrid and PHEV batteries, see this section of the same site. (I disagree about diesel - but note that Toyota have got improved fuel economy from the 2010 car by improving the engine, not the battery, which is actually identical.)
  8. EZW1
    EZW1 Active Member
    722
    81
    Phoenix, AZ
    2016 Prius v wagon
    Four Touring
    The act of charging any battery creates heat, and heat is what kills a battery. Charge it too fast and it gets too hot - shortening its life. I wonder how they got around this - to be able to charge their lithium-titanate batteries withoug creating so much heat? Do they use some kind of system to remove the heat rapidly?
  9. hill
    8,938
    Ya never know ... it may be that the new chemestry over comes the "heat = deterioration" scenerio. We sunk a bunch into their stock, years ago and the values kept sinking lower & lower into the tank, year after year. We hung onto it anyway. Hopefully this will bring the value of their company back up to 'par' :rolleyes:
  10. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    The "non-heating to destruction" is a function of the battery chemistry and physical construction. e.g. use large interconnection bars.
    NiCad and NiMH cells start to heat up at 80% charge. In other words, they become inefficient at charging and convert about 50% of the charge energy into heat. Which is one reason the Toyota engineers don't charge the Prius battery more than 80% full. These cells are also not as efficient in accepting charge up to 80% full as the new LiIon chemistries.
    -Most- of the improvement is in the chemistry. Some is in the construction.
    We're getting there, slowly. "There" being having batteries that are good enough for practical EV use.
  11. windstrings
    6,280
    378
    Central Texas
    Altairnano - Wikipedia, the free encyclopedia
    Charge a battery in just six minutes - tech - 07 March 2005 - New Scientist
    Substituted lithium titanate spinel compound with improved electron conductivity and methods of making the same invention
    Green Car Congress: Electrode Nanomaterials Reduce Li-ion Recharge Time to Up to One-Sixth
    Batteries have always been the big limiting factor both in cost as well as technology for alternative power stations and forms of collecting from free sources such as the sun etc.
    The next exciting subject is that the cost of solar panels will be dropping to about 1/20th the cost.
    The combination of these two opens up tremendous opportunity for sun farms..... even on a small scale for home users.
    Its exciting to see the technology is actually here.
    Now if mankind can just keep from blowing ourselves off the planet for a while we may be able to reap some of the benefit and put the power into the hands of the common man instead of the oil cartels and mafia!
  12. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    302
    Northwest VT
    2018 Prius Prime
    Not only that but they are "mucher safer than other types of lithium ion batteries, which are potential fire hazards" :)
    Remains to be seen. Guess we wouldn't need to worry about alternative energy sources if we knew we can not accomplish that.
    Not so standard in the U.S.A. 110 standard household, 220 for big amp appliances like electric cooking stoves and clothes dryers.
  13. windstrings
    6,280
    378
    Central Texas
    I would not want 220 hookup unless I also had 110.
    110 will give me the opportunity to charge in many locations besides just my house.
    I can't see needing to charge fast enough to warrant 440 anyway unless they start rigging gas stations for electric fillup.. but then that negates the whole purpose since I'm sure they will gouge you on the price of electricity.
  14. alanh
    alanh Active Member
    1,175
    99
    Phoenix, AZ
    A typical house has 200 amp service at 240 volts, which is 48kW. This would take 40 minutes to charge a 30kWh battery, assuming no losses. It also assumes you shut off everything else in the house -- A/C, hot water, etc.
    A more realistic value would be 50 amps, which would take 2.7 hours, but probably substantially more time with losses.
    A 15 amp 120v outlet (a standard household outlet) is 2.25kW, or 13.3 hours to charge a 30kWh battery with no losses.
  15. windstrings
    6,280
    378
    Central Texas
    Basically any time I'm at home.. its on the charger!.. but having 220 would be nice too.
    I would just homemake an extension chord for 220 from the breaker box if it were in a better location. I could tap off the hot water heater, but then there would be too much amperage if the H/W heater was on at the same time.
    You would just about have to dedicate a line from the breaker box with its own breaker to make it work, unless you already have an empty 220 or two extra 110 volt breakers to convert.
  16. miscrms
    miscrms Plug Envious Member
    2,079
    527
    Phoenix, AZ
    Very cool, looks like a great battery.
    However, not what I have been waiting for. IMHO what we need isn't a new battery. What we need is someone to make a good quality existing battery in high volume at a low cost. What we need is significant research into charge/discharge and balancing/management algorithms to make batteries last as long as possible under real world conditions. We need to tweak existing chemistries and designs to maximize specific energy, specific power and minimize production costs. There are batteries that are plenty good enough for PHEVs, and good enough for EVs now. Heck, there were batteries good enough for EVs 10 years ago. We will always need newer better batteries for the future, but whats lacking today is implementation and larger scale volume production.
    My 2c, dismounting soap box :)
    Rob
  17. windstrings
    6,280
    378
    Central Texas
    Its agreed that something only taste good if you can taste it!
    Until technology is realized in the real world, it may as well not exist.
    So invention is only good if its also accessible.
    Hence we are bombarded with energy everyday from so many sources thats free, but we still have to pay the man..... just the way the man likes it!
  18. darelldd
    6,059
    389
    Northern CA
    I have many customers who have been waiting for this to happen "next year" for the past six years. I've personally been hearing it for about 15 years. When and how will this excitement come to be?! 1/20th the cost is in the realm of "too cheap to meter."
  19. windstrings
    6,280
    378
    Central Texas
    Sure sounds like the Fat Cats in the reclining leather chairs in that sit in the top of skyscrapers are buying somebody off.
  20. daniel
    14,487
    1,519
    Spokane, WA
    These new battery chemistries are exciting and have great potential. My Xebra has an aftermarket LiFePO4 battery pack (the second link in the OP, but from a different manufacturer) and my Porsche (if it ever comes) will have the same. They are supposed to be good for 2,000 charge-discharge cycles. At present they are so expensive that you use them because you are committed to electric, not because you think you'll "save money," but as economies of scale bring the prices down, and oil becomes scarce, they will become economical.
    Fast charging is important because it helps create the bridge to the electric highway of the future, when you can take road trips, stopping at recharging stations along the way. But with 40 miles of range in my Xebra, I never have to charge it fast. I plug it in when I get home, and it's charged when I need to drive again. The Porsche (if it ever comes) will have a 125-mile range, and I NEVER drive farther than 100 miles in a day except on a road trip when no present-day EV would suffice. Thus overnight charging at home is all it will ever need. It will have a 220-v charger, however. I had no choice on that. It will plug into the dryer circuit, and I won't be able to charge while clothes are drying. Unplugging the car before drying clothes will be a very minor nuisance, but will not be a problem.
