Feature: 2010 Honda Insight vs 2010 Toyota Prius
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Tideland Prius, Jan 26, 2009.
  1. Tideland Prius
    16,553
    At this year’s edition of the North American International Auto Show in Detroit, it was just like old times, as two senior hybrid nameplates squared off from opposite sides of the room. In one corner, the 2010 Toyota Prius, the first mass-produced hybrid, was unveiled in its third generation. And in the other was the 2010 Honda Insight, a name used on the first hybrid to come to North American shores, and now revived on an all-new model.
    Originally the only game in town, the Prius and Insight are no longer alone. Both companies make other hybrids, while General Motors, Ford, Nissan and Chrysler also have models on the market, and other companies have them on the way. The Prius still commands the lion’s share of the gasoline-electric market, to the point that it’s almost become a generic name for hybrids with many customers. Honda, meanwhile, has brought back the name of the cute-n-funky little two-seater that introduced us to the idea, in the hopes that buyers will reconnect with it. So how do the two measure up?
    Full Article
  2. Rybold
    Rybold globally warmed member
    2,760
    322
    Southern California
    Interesting article. Somewhat limited, but still some good stuff.
    Any predictions on whether you could fit a mountain bike in the back of the Insight?
    "the Prius is the larger of the two: a 2700 mm (106.2 inches) wheelbase to the Insight’s 2550 mm (100.3 inches), and a body length of 4460 mm (175.5 inches), to the Insight’s 4376 mm (172.2 inches). The Insight is also smaller than the Honda Civic Hybrid"
    "The Insight’s engine also includes a system called Variable Cylinder Management, or VCM, which stops firing on all four cylinders during deceleration to save fuel and decrease resistance to allow the motor/generator to more efficiently generate electricity and charge the battery."
    I understand how this saves fuel, but I don't understand how it would decrease resistance. Isn't it still engine braking? I'd think the only way to "decrease resistance" would be to disengage the engine from the transmission.
  3. Mike Dimmick
    Mike Dimmick Active Member
    963
    249
    Reading, UK
    The current Civic Hybrid (and presumably the Insight) can leave the valves open through the engine cycle to reduce the pumping loss. It's still moving the piston, obviously, so moving air in and out through the intake and exhaust valves, but no compression occurs. I'm not sure how this is achieved, but my guess would be a special cam on the camshaft that can be selected.
    It's not possible to disengage the engine from the transmission and get regeneration because the motor in Honda's IMA (Integrated Motor Assist, remember) simply takes the place of the flywheel in the engine. There still is a flywheel but it's much smaller.
    The old Insight Central site is still up, and you can read about the IMA system here. The original Insight didn't have the ability to 'disable' cylinders that the HCH and new Insight have. The first generation HCH could disable up to three cylinders, the second generation extends this to all four.
  4. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    I thought VCM disables cylinders by closing the valves.
  5. richard schumacher
    7,664
    1,046
    United States
    Insight: no HSD. 'Nuff said.
  6. qbee42
    3,079
    Yes. Opening the valves increases pumping loss, since air is moved through the cylinders. With closed valves you compress air, but the compressed air pushes back when it uncompresses. The net work is zero, other than frictional losses.
  7. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
  8. MSantos
    MSantos EcoAccelerometry
    588
    257
    Canada, Winnipeg
    2024 Prius Prime
    XSE Premium
    Oh, but it can be at least some of us use it regularly. And the highway or (low speed steady state driving) at the hands of a good driver is where you see the highest gains.
    This is precisely why the Civic Hybrid was selected for the Guinness world record across the US last November (68 MPG in winter like conditions with 3 people + gear on board).
    Of course, the feature is there but rarely leveraged by the "just drive it" and heavy footed crowd. That is why the new Insight's instrumentation is taking it to the next level and prompting/enticing the driver to leverage these and several other features more consistently.
    Cheers;
    MSantos
  9. Rybold
    2,760
    322
    Southern California
    Thank you for the explanations about reducing engine braking. I think closing the valves would work. It would create an adiabatic system that would essentially do what qbee42 said. (I studied the Carnot Cycle (isotherms/adiabats) extensively back in college. It's been several years but I still remember how it works).
    The mountain bike! What about the mountain bike???? Will it fit in the Insight?
    (scroll up to see fancy picture)
  10. JSH
    JSH Senior Member
    2,605
    140
    PDX
    My guess? Yes, with the seat and front wheel removed. That is how I put my bikes in the VW and Prius. You won't know for sure until the Insight shows up in dealerships. The limiting factor will be the height of the hatch opening.
    Here is a picture of the Insight and some bikers:
  11. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    302
    Northwest VT
    2018 Prius Prime
    Hmm, looks like those bikers could ride right inside the Insight ;)
    Now when you say "yes, with seat and front wheel removed" are you talking rear seat backs up or down?
    I can fit my EZ-1 recumbant (73" overall length) in the Prius with the rear seats and the back of the bike seat folded. No need to remove anything.
  12. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    gee... i wonder where Honda got its inspiration for the new insight body style?
  13. JSH
    JSH Senior Member
    2,605
    140
    PDX
    With the rear seats folded down but the bike standing upright like this:
    This is the way my wife and I carry our mountain bikes, side by side standing upright.
    My Rans Recumbent will fit in my TDI fully assembled if I lay it on it's side. Then I but a blanket over my bike and lay my wife's fully assembled roadbike on top of my bike.
    I've not had multiple bikes in the Prius because we normally carry the bikes in my TDI wagon.
  14. Trollbait
    12,517
    The 80's CRX perhaps?
