Question About 15,000 Mile / 18 Month Maintenance
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Kizzy, Dec 30, 2008.
  1. jayman
    jayman Senior Member
    13,439
    640
    Winnipeg Manitoba
    When I took delivery of my Prius, I used a Sharpie to mark the level on the tanks. It has gone down maybe 2mm since
  2. CheapA55
    CheapA55 Junior Member
    Lost Angles
    i highly doubt they "check" the other items... just take a look around and if something is leaking, low, or disconnected, i'd be worried. Unless you are getting a 5k MIL light, i wouldn't be worried.
  3. KJR
    KJR New Member
    I just called my dealer, Pat Lobb Toyota, McKinney, Tx. They quoted me about $350 for the 15K service. I asked them why is was so high compared to what Toyota recommends. They stated they do more; rotate balance tires, fuel injection service, replace air filter, oil change, inspect. I told them the Toyota manual doesn't mention anything like that and I've already replaced the air filter and cabin air filter ($20 for both from eBay). I just want what Toyota recommends.
    Dealers must be really hurting. I hate cars :)
    Kelvin
  4. Bob.H
    Bob.H Junior Member
    Findlay, Ohio
    Here is a cupon I just received from my dealer that expires 6/1/09
    Performance Inspection Plus Oil Change
    Includes Lube, Oil, & Filter Change
    Install premium oil plus additive to enhance oil protection
    Rotate tires & perform tire & brake inspection
    Perform battery health check
    Provide fluid sample analysis
    Complimentary car wash
    Was $62.95... Now just $54.95!
