multi/Nav display
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jone54, Jan 26, 2009.
  1. jone54
    jone54 New Member
    portland oregon
    I've fractured the outermost screen on the multidisplay,(attached a tom-tom, suction fractured the screen) , what is the fix?
    Thanks
  2. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    Most likely a replacement ($$$).
  3. glenk
    glenk Member
    109
    Fairfield, CA
    You have cracked the conductive surface of the touch screen and it will effect the operation of the touch screen in that area. Other than replacement of the touch screen, there's not much you can do. Toyota will replace the entire MFD and the question is whether or not they will take your old MFD in exchange because of the cracked screen.
    Check with your insurance co whether they will cover this under comprehensive. I know of another person that made the exact same mistake and it was covered and only had to pay their deductible.
    glenk
  4. jelloslug
    jelloslug It buffed right out!
    813
    Greenville, SC
    Find a replacement screen (MFD) on ebay. Make sure it matches your package though. If you have a package 3 and you buy one from a package 2 your Bluetooth won't work anymore unless you swap over your internal electronics from the old MFD.
