Plug in cold weather performance
Discussion in 'Gen 2 Prius Main Forum' started by jackalope, Feb 2, 2009.
  1. jackalope
    jackalope Member
    101
    58
    Connecticut now but from Vermont
    My school has been testing the performance of the plug in Prius in the cold weather here in Vermont.
    The results so far show that 100 MPG is possible.
    CVPS: Green Mountain College
    I have had a chance to ride in the car. It is a slightly older model (the old display monitor). It seemed much like a regular Prius to sit in. I hoping to be able to test it one of these months.
    Cheers
  2. john1701a
    john1701a Prius Guru
    12,840
    5,311
    58
    Where's the temperature information?
  3. jackalope
    jackalope Member
    101
    58
  4. windstrings
    6,280
    378
    Central Texas
    Was it stated anywhere just how big this battery was and what type and how many miles one way it would support before a charge was needed?
    Was the car modified to go faster than 32 on electric only EV mode or was the configuration left the same?
    IN other words, was the only real modification to this car a plugin and bigger battery and/or type?
  5. jackalope
    jackalope Member
    101
    58
    I found one of their initial test program reports here:
    http://www.cvps.com/ProgramsServices/PHEV_CVPS_GMC_Report_1.pdf
    It looks like they are using the hymotion battery (5kw li ion).
    There is a lot of raw data in the report for those of you who like the numbers.
    Here is the homepage for the project: CVPS: Programs & Services
    The car was noted to be quite cold inside the cabin for what it is worth. Perhaps they can issue some blankets with the conversion battery ;)
  6. windstrings
    6,280
    378
    Central Texas
    Looks like having a bigger battery affords the luxury of actually using it!
    It appears just having a bigger battery alone is a 50% increase in mpg "keeping in mind the energy is not free, but from the grid"
    Like everything.. the conversion is not pure, but has losses of course.
    If these numbers are real... thats a fair amount of change each year:
    I wonder what is the life expectancy of actually "using" the LiOn battery as demonstrated in the chart vs. merely maintaining the NiHh at around 60%?
    Lithium can take the charge discharge cycle in stride much better than NiMh.
  7. boxer93
    boxer93 Psyched for PHEV
    155
    22
    Southern NH
    Jack,
    I'm located about 2 hours southeast of you. I have been using my Hymotion this winter. I agree that 100MPG+ (with the electrical charge for the battery) is possible at times, but for me I can't maintain an average that high. With the Ambient Temps <0C most days and a few <-20C this January, I'm averaging ~76MPG. Most of this I have found is from the lack of EV mode which is not possible in the Prius if the Traction Battery Temeratures are <0C.
    I also read the article and the professor did state his mileage was during the fall semester. And I definitely had 100+ average with Temps >10C (and I didn't grill block for some of that timeframe).
    I hope that you have a chance to ride in it. Other than EV mode it's rides like a Prius.
    Chris
  8. PeakOilGarage
    PeakOilGarage Nothing less than 99.9
    334
    Pacific Northwest
    I installed my Hymotion in early October 2008 when the weather was still nice. I easily was able to get 99.9+ mpg after about one week of experience learning the system.
    I had some trouble maintaining my 99.9+ mpg average when the weather first turned cold for winter. But after grill blocking and just gaining more experience, my average is easily back to maxing out the system. According to my gasoline calculations, I am still between 110 to 115 mpg for my most recent two tanks of gasoline in December and January.
    The most effective tips are just to do grill blocking and know your terrain to maximize your EV time. Also doing opportunity recharging during the day is critical. Know where your electric outlets are in parking garages, at work, at stores you visit, etc. Grabbing that extra hour or two recharging during the day can really increase your Hymotion range. I can regularly get 40 to 50 miles of range per day and never go below 3/8 on my battery.
  9. windstrings
    6,280
    378
    Central Texas
    About grill blocking... does there seem to be a magic dimension that seems to work well?
    And do you remove it in the summer?
  10. jackalope
    jackalope Member
    101
    58
    I have ridden in the car a few times but have yet to make it to the top of the list of long-term test drivers. The other drivers are not familiar with P&G and other Prius driving techniques. I am anxious to see if I can improve the averages with a bit of technique.
    As they get more information and release it I will be sure to post it here. I will also suggest that they add a place to plug in on campus (there is no facility now).
